# oct/29/2018 20:26:25 by RouterOS 6.43.4
# software id = A74V-U5Z3
# model = RBD52G-5HacD2HnD
# serial number = 8FDE0988C4E1
add name=br1-lan
set [ find default-name=ether1 ] name=eth1-wan
set [ find default-name=ether2 ] name=eth2-lan
set [ find default-name=ether3 ] name=eth3-lan
set [ find default-name=ether4 ] name=eth4-lan
set [ find default-name=ether5 ] name=eth5-lan
add authentication-types=wpa-psk,wpa2-psk eap-methods="" group-ciphers=tkip \
management-protection=allowed mode=dynamic-keys name=profile1 \
supplicant-identity="" unicast-ciphers=tkip wpa-pre-shared-key=\
770944982447 wpa2-pre-shared-key=770944982447
set [ find default-name=wlan1 ] band=2ghz-b/g/n disabled=no mode=ap-bridge \
security-profile=profile1 ssid=dlink wireless-protocol=802.11
set [ find default-name=wlan2 ] band=5ghz-a/n/ac disabled=no mode=ap-bridge \
security-profile=profile1 ssid=dlink5
/interface wireless nstreme
set wlan1 enable-polling=no
set wlan2 enable-polling=no
add name=dhcp-pc ranges=192.168.10.100-192.168.10.200
add address-pool=dhcp-pc disabled=no interface=br1-lan lease-time=8h name=\
dhcp-pc
add bridge=br1-lan interface=wlan1
add bridge=br1-lan interface=eth2-lan
add bridge=br1-lan interface=eth3-lan
add bridge=br1-lan interface=eth4-lan
add bridge=br1-lan interface=eth5-lan
add bridge=br1-lan interface=wlan2
add address=192.168.10.1/24 interface=br1-lan network=192.168.10.0
add dhcp-options=hostname,clientid disabled=no interface=eth1-wan
add address=192.168.10.0/24 dns-server=192.168.10.1 gateway=192.168.10.1 \
netmask=24 ntp-server=192.168.10.1
set allow-remote-requests=yes
/ip dns static
add address=8.8.8.8 name=111
add chain=input protocol=icmp
add chain=input connection-state=new dst-port=80,8291,22 in-interface=br1-lan \
protocol=tcp src-address=192.168.10.0/24
add chain=input connection-mark=allow_in connection-state=new dst-port=80 \
in-interface=eth1-wan protocol=tcp
add chain=input connection-state=new dst-port=53,123 protocol=udp \
add chain=input connection-state=established,related
add chain=output connection-state=!invalid
add chain=forward connection-state=established,new in-interface=br1-lan \
out-interface=eth1-wan src-address=192.168.10.0/24
add chain=forward connection-state=established,related in-interface=eth1-wan \
out-interface=br1-lan
add action=drop chain=input
add action=drop chain=output
add action=drop chain=forward
add action=fasttrack-connection chain=forward
/ip firewall mangle
add action=mark-connection chain=prerouting connection-state=new dst-port=\
9999 new-connection-mark=allow_in protocol=tcp
add action=masquerade chain=srcnat out-interface=eth1-wan src-address=\
192.168.10.0/24
add action=redirect chain=dstnat dst-port=9999 protocol=tcp to-ports=80
add action=netmap chain=dstnat dst-port=80 in-interface=eth1-wan protocol=tcp \
to-addresses=192.168.10.20
add action=dst-nat chain=dstnat dst-port=80 in-interface=eth1-wan protocol=\
udp to-addresses=192.168.0.20
add action=netmap chain=dstnat dst-port=62094 in-interface=eth1-wan protocol=\
tcp to-addresses=192.168.10.20 to-ports=62094
/ip service
set telnet disabled=yes
set ftp disabled=yes
set api disabled=yes
set api-ssl disabled=yes
/ip upnp
set enabled=yes
/ip upnp interfaces
add interface=eth1-wan type=external
add interface=br1-lan type=internal
add interface=wlan1 type=internal
add interface=wlan2 type=internal
/system ntp client
set enabled=yes primary-ntp=48.8.40.31 secondary-ntp=91.206.16.3
/system routerboard settings
set silent-boot=no
