По непонятной причине после обновления прошивки не работает один из интернет каналов (скорость копеешная), второй же работает нормально. Выкладываю конфиги:
/ip firewall mangle
add action=mark-connection chain=input in-interface=pppoe-RT \
new-connection-mark=RTp passthrough=yes
add action=mark-connection chain=prerouting in-interface=pppoe-RT \
add action=mark-connection chain=input in-interface=pppoe-IS \
new-connection-mark=ISp passthrough=yes
add action=mark-connection chain=prerouting in-interface=pppoe-IS \
add action=mark-routing chain=output connection-mark=RTp new-routing-mark=RTr \
passthrough=no
add action=mark-routing chain=output connection-mark=ISp new-routing-mark=ISr \
passthrough=no
add action=mark-routing chain=prerouting new-routing-mark=RTr passthrough=no \
src-address-list=RT_only
add action=mark-routing chain=prerouting new-routing-mark=ISr passthrough=no \
src-address-list=IS_only
add action=mark-routing chain=prerouting connection-mark=ISp \
new-routing-mark=ISr passthrough=no src-address=10.0.0.0/24
add action=mark-routing chain=prerouting connection-mark=RTp \
new-routing-mark=RTr passthrough=no src-address=10.0.0.0/24
add action=mark-routing chain=prerouting new-routing-mark=mixed passthrough=\
add distance=1 gateway=pppoe-RT routing-mark=RTr
add distance=1 gateway=195.98.72.209 routing-mark=ISr
add distance=1 gateway=pppoe-RT,pppoe-IS routing-mark=mixed
Не работает (тормозит) RT
