microtic как openvpn server настройка аналогична статье http://trustore.ru/article/complex/199-openvpn-mikrotik
но у меня ошибка при чем мне от этого понятней не становится что ему нужно
1. как расширить вывод ошибок, более детальную информацию или вывод информации так чтоб было понятно.
2. как собственно исправить.
на клиенте
Wed Oct 11 11:18:10 2017 Attempting to establish TCP connection with [AF_INET]ip:443 [nonblock]
Wed Oct 11 11:18:11 2017 TCP connection established with [AF_INET]ip:443
Wed Oct 11 11:18:11 2017 TCPv4_CLIENT link local (bound): [undef]
Wed Oct 11 11:18:11 2017 TCPv4_CLIENT link remote: [AF_INET]ip:443
Wed Oct 11 11:18:11 2017 Connection reset, restarting [0]
Wed Oct 11 11:18:11 2017 SIGUSR1[soft,connection-reset] received, process restarting
Wed Oct 11 11:18:13 2017 SIGTERM[hard,init_instance] received, process exiting
на сервере
так настроен клиент
dev tap
proto tcp-client
cipher AES-256-CBC
auth SHA256
auth SHA1
pull
tls-client
client
resolv-retry infinite
remote ip 443 tcp
lport 0
#указываем имена публичного CA сертификата
ca GW.Cert.crt
# публичного сертификата клиента
cert vpn.crt
# и его закрытый ключ
key vpn.key
ns-cert-type server
passtos
auth-user-pass auth-i.cfg
verb 10
Wed Oct 11 11:38:23 2017 us=675659 Current Parameter Settings:
Wed Oct 11 11:38:23 2017 us=677658 config = 'I.ovpn'
Wed Oct 11 11:38:23 2017 us=677658 mode = 0
Wed Oct 11 11:38:23 2017 us=677658 show_ciphers = DISABLED
Wed Oct 11 11:38:23 2017 us=677658 show_digests = DISABLED
Wed Oct 11 11:38:23 2017 us=677658 show_engines = DISABLED
Wed Oct 11 11:38:23 2017 us=677658 genkey = DISABLED
Wed Oct 11 11:38:23 2017 us=677658 key_pass_file = '[UNDEF]'
Wed Oct 11 11:38:23 2017 us=677658 show_tls_ciphers = DISABLED
Wed Oct 11 11:38:23 2017 us=677658 Connection profiles [default]:
Wed Oct 11 11:38:23 2017 us=677658 proto = tcp-client
Wed Oct 11 11:38:23 2017 us=677658 local = '[UNDEF]'
Wed Oct 11 11:38:23 2017 us=677658 local_port = 0
Wed Oct 11 11:38:23 2017 us=677658 remote = 'ip'
Wed Oct 11 11:38:23 2017 us=677658 remote_port = 443
Wed Oct 11 11:38:23 2017 us=677658 remote_float = DISABLED
Wed Oct 11 11:38:23 2017 us=677658 bind_defined = DISABLED
Wed Oct 11 11:38:23 2017 us=677658 bind_local = ENABLED
Wed Oct 11 11:38:23 2017 us=677658 connect_retry_seconds = 5
Wed Oct 11 11:38:23 2017 us=677658 connect_timeout = 10
Wed Oct 11 11:38:23 2017 us=677658 connect_retry_max = 0
Wed Oct 11 11:38:23 2017 us=677658 socks_proxy_server = '[UNDEF]'
Wed Oct 11 11:38:23 2017 us=677658 socks_proxy_port = 0
Wed Oct 11 11:38:23 2017 us=677658 socks_proxy_retry = DISABLED
Wed Oct 11 11:38:23 2017 us=677658 tun_mtu = 1500
Wed Oct 11 11:38:23 2017 us=677658 tun_mtu_defined = ENABLED
Wed Oct 11 11:38:23 2017 us=677658 link_mtu = 1500
Wed Oct 11 11:38:23 2017 us=677658 link_mtu_defined = DISABLED
Wed Oct 11 11:38:23 2017 us=677658 tun_mtu_extra = 32
Wed Oct 11 11:38:23 2017 us=677658 tun_mtu_extra_defined = ENABLED
Wed Oct 11 11:38:23 2017 us=677658 mtu_discover_type = -1
Wed Oct 11 11:38:23 2017 us=677658 fragment = 0
Wed Oct 11 11:38:23 2017 us=677658 mssfix = 1450
Wed Oct 11 11:38:23 2017 us=677658 explicit_exit_notification = 0
Wed Oct 11 11:38:23 2017 us=677658 Connection profiles END
Wed Oct 11 11:38:23 2017 us=677658 remote_random = DISABLED
Wed Oct 11 11:38:23 2017 us=677658 ipchange = '[UNDEF]'
Wed Oct 11 11:38:23 2017 us=677658 dev = 'tap'
Wed Oct 11 11:38:23 2017 us=677658 dev_type = '[UNDEF]'
Wed Oct 11 11:38:23 2017 us=677658 dev_node = '[UNDEF]'
Wed Oct 11 11:38:23 2017 us=677658 lladdr = '[UNDEF]'
Wed Oct 11 11:38:23 2017 us=677658 topology = 1
Wed Oct 11 11:38:23 2017 us=677658 tun_ipv6 = DISABLED
Wed Oct 11 11:38:23 2017 us=677658 ifconfig_local = '[UNDEF]'
Wed Oct 11 11:38:23 2017 us=677658 ifconfig_remote_netmask = '[UNDEF]'
Wed Oct 11 11:38:23 2017 us=677658 ifconfig_noexec = DISABLED
Wed Oct 11 11:38:23 2017 us=677658 ifconfig_nowarn = DISABLED
Wed Oct 11 11:38:23 2017 us=677658 ifconfig_ipv6_local = '[UNDEF]'
Wed Oct 11 11:38:23 2017 us=677658 ifconfig_ipv6_netbits = 0
Wed Oct 11 11:38:23 2017 us=677658 ifconfig_ipv6_remote = '[UNDEF]'
Wed Oct 11 11:38:23 2017 us=677658 shaper = 0
Wed Oct 11 11:38:23 2017 us=677658 mtu_test = 0
Wed Oct 11 11:38:23 2017 us=677658 mlock = DISABLED
Wed Oct 11 11:38:23 2017 us=677658 keepalive_ping = 0
Wed Oct 11 11:38:23 2017 us=677658 keepalive_timeout = 0
Wed Oct 11 11:38:23 2017 us=677658 inactivity_timeout = 0
Wed Oct 11 11:38:23 2017 us=677658 ping_send_timeout = 0
Wed Oct 11 11:38:23 2017 us=677658 ping_rec_timeout = 0
Wed Oct 11 11:38:23 2017 us=677658 ping_rec_timeout_action = 0
Wed Oct 11 11:38:23 2017 us=677658 ping_timer_remote = DISABLED
Wed Oct 11 11:38:23 2017 us=677658 remap_sigusr1 = 0
Wed Oct 11 11:38:23 2017 us=677658 persist_tun = DISABLED
Wed Oct 11 11:38:23 2017 us=677658 persist_local_ip = DISABLED
Wed Oct 11 11:38:23 2017 us=677658 persist_remote_ip = DISABLED
Wed Oct 11 11:38:23 2017 us=677658 persist_key = DISABLED
Wed Oct 11 11:38:23 2017 us=677658 passtos = ENABLED
Wed Oct 11 11:38:23 2017 us=677658 resolve_retry_seconds = 1000000000
Wed Oct 11 11:38:23 2017 us=677658 username = '[UNDEF]'
Wed Oct 11 11:38:23 2017 us=677658 groupname = '[UNDEF]'
Wed Oct 11 11:38:23 2017 us=677658 chroot_dir = '[UNDEF]'
Wed Oct 11 11:38:23 2017 us=677658 cd_dir = '[UNDEF]'
Wed Oct 11 11:38:23 2017 us=677658 writepid = '[UNDEF]'
Wed Oct 11 11:38:23 2017 us=677658 up_script = '[UNDEF]'
Wed Oct 11 11:38:23 2017 us=677658 down_script = '[UNDEF]'
Wed Oct 11 11:38:23 2017 us=677658 down_pre = DISABLED
Wed Oct 11 11:38:23 2017 us=677658 up_restart = DISABLED
Wed Oct 11 11:38:23 2017 us=677658 up_delay = DISABLED
Wed Oct 11 11:38:23 2017 us=677658 daemon = DISABLED
Wed Oct 11 11:38:23 2017 us=677658 inetd = 0
Wed Oct 11 11:38:23 2017 us=677658 log = ENABLED
Wed Oct 11 11:38:23 2017 us=677658 suppress_timestamps = DISABLED
Wed Oct 11 11:38:23 2017 us=677658 nice = 0
Wed Oct 11 11:38:23 2017 us=677658 verbosity = 10
Wed Oct 11 11:38:23 2017 us=677658 mute = 0
Wed Oct 11 11:38:23 2017 us=677658 gremlin = 0
Wed Oct 11 11:38:23 2017 us=677658 status_file = '[UNDEF]'
Wed Oct 11 11:38:23 2017 us=677658 status_file_version = 1
Wed Oct 11 11:38:23 2017 us=677658 status_file_update_freq = 60
Wed Oct 11 11:38:23 2017 us=677658 occ = ENABLED
Wed Oct 11 11:38:23 2017 us=677658 rcvbuf = 0
Wed Oct 11 11:38:23 2017 us=677658 sndbuf = 0
Wed Oct 11 11:38:23 2017 us=677658 sockflags = 0
Wed Oct 11 11:38:23 2017 us=677658 fast_io = DISABLED
Wed Oct 11 11:38:23 2017 us=677658 lzo = 0
Wed Oct 11 11:38:23 2017 us=677658 route_script = '[UNDEF]'
Wed Oct 11 11:38:23 2017 us=677658 route_default_gateway = '[UNDEF]'
Wed Oct 11 11:38:23 2017 us=677658 route_default_metric = 0
Wed Oct 11 11:38:23 2017 us=677658 route_noexec = DISABLED
Wed Oct 11 11:38:23 2017 us=677658 route_delay = 5
Wed Oct 11 11:38:23 2017 us=677658 route_delay_window = 30
Wed Oct 11 11:38:23 2017 us=677658 route_delay_defined = ENABLED
Wed Oct 11 11:38:23 2017 us=677658 route_nopull = DISABLED
Wed Oct 11 11:38:23 2017 us=677658 route_gateway_via_dhcp = DISABLED
Wed Oct 11 11:38:23 2017 us=677658 max_routes = 100
Wed Oct 11 11:38:23 2017 us=677658 allow_pull_fqdn = DISABLED
Wed Oct 11 11:38:23 2017 us=677658 management_addr = '127.0.0.1'
Wed Oct 11 11:38:23 2017 us=677658 management_port = 25342
Wed Oct 11 11:38:23 2017 us=677658 management_user_pass = 'stdin'
Wed Oct 11 11:38:23 2017 us=677658 management_log_history_cache = 250
Wed Oct 11 11:38:23 2017 us=677658 management_echo_buffer_size = 100
Wed Oct 11 11:38:23 2017 us=677658 management_write_peer_info_file = '[UNDEF]'
Wed Oct 11 11:38:23 2017 us=677658 management_client_user = '[UNDEF]'
Wed Oct 11 11:38:23 2017 us=677658 management_client_group = '[UNDEF]'
Wed Oct 11 11:38:23 2017 us=677658 management_flags = 6
Wed Oct 11 11:38:23 2017 us=677658 shared_secret_file = '[UNDEF]'
Wed Oct 11 11:38:23 2017 us=677658 key_direction = 0
Wed Oct 11 11:38:23 2017 us=677658 ciphername_defined = ENABLED
Wed Oct 11 11:38:23 2017 us=677658 ciphername = 'AES-256-CBC'
Wed Oct 11 11:38:23 2017 us=677658 authname_defined = ENABLED
Wed Oct 11 11:38:23 2017 us=677658 authname = 'SHA1'
Wed Oct 11 11:38:23 2017 us=677658 prng_hash = 'SHA1'
Wed Oct 11 11:38:23 2017 us=677658 prng_nonce_secret_len = 16
Wed Oct 11 11:38:23 2017 us=677658 keysize = 0
Wed Oct 11 11:38:23 2017 us=677658 engine = DISABLED
Wed Oct 11 11:38:23 2017 us=677658 replay = ENABLED
Wed Oct 11 11:38:23 2017 us=677658 mute_replay_warnings = DISABLED
Wed Oct 11 11:38:23 2017 us=678662 replay_window = 64
Wed Oct 11 11:38:23 2017 us=678662 replay_time = 15
Wed Oct 11 11:38:23 2017 us=678662 packet_id_file = '[UNDEF]'
Wed Oct 11 11:38:23 2017 us=678662 use_iv = ENABLED
Wed Oct 11 11:38:23 2017 us=678662 test_crypto = DISABLED
Wed Oct 11 11:38:23 2017 us=678662 tls_server = DISABLED
Wed Oct 11 11:38:23 2017 us=678662 tls_client = ENABLED
Wed Oct 11 11:38:23 2017 us=678662 key_method = 2
Wed Oct 11 11:38:23 2017 us=678662 ca_file = 'GW.Cert.crt'
Wed Oct 11 11:38:23 2017 us=678662 ca_path = '[UNDEF]'
Wed Oct 11 11:38:23 2017 us=678662 dh_file = '[UNDEF]'
Wed Oct 11 11:38:23 2017 us=678662 cert_file = 'vpn.crt'
Wed Oct 11 11:38:23 2017 us=678662 extra_certs_file = '[UNDEF]'
Wed Oct 11 11:38:23 2017 us=678662 priv_key_file = 'vpn.key'
Wed Oct 11 11:38:23 2017 us=678662 pkcs12_file = '[UNDEF]'
Wed Oct 11 11:38:23 2017 us=678662 cryptoapi_cert = '[UNDEF]'
Wed Oct 11 11:38:23 2017 us=678662 cipher_list = '[UNDEF]'
Wed Oct 11 11:38:23 2017 us=678662 tls_verify = '[UNDEF]'
Wed Oct 11 11:38:23 2017 us=678662 tls_export_cert = '[UNDEF]'
Wed Oct 11 11:38:23 2017 us=678662 verify_x509_type = 0
Wed Oct 11 11:38:23 2017 us=678662 verify_x509_name = '[UNDEF]'
Wed Oct 11 11:38:23 2017 us=678662 crl_file = '[UNDEF]'
Wed Oct 11 11:38:23 2017 us=678662 ns_cert_type = 1
Wed Oct 11 11:38:23 2017 us=678662 remote_cert_ku[i] = 0
Wed Oct 11 11:38:23 2017 us=678662 remote_cert_eku = '[UNDEF]'
Wed Oct 11 11:38:23 2017 us=678662 ssl_flags = 0
Wed Oct 11 11:38:23 2017 us=678662 tls_timeout = 2
Wed Oct 11 11:38:23 2017 us=678662 renegotiate_bytes = 0
Wed Oct 11 11:38:23 2017 us=678662 renegotiate_packets = 0
Wed Oct 11 11:38:23 2017 us=678662 renegotiate_seconds = 3600
Wed Oct 11 11:38:23 2017 us=678662 handshake_window = 60
Wed Oct 11 11:38:23 2017 us=678662 transition_window = 3600
Wed Oct 11 11:38:23 2017 us=678662 single_session = DISABLED
Wed Oct 11 11:38:23 2017 us=678662 push_peer_info = DISABLED
Wed Oct 11 11:38:23 2017 us=678662 tls_exit = DISABLED
Wed Oct 11 11:38:23 2017 us=678662 tls_auth_file = '[UNDEF]'
Wed Oct 11 11:38:23 2017 us=678662 pkcs11_protected_authentication = DISABLED
Wed Oct 11 11:38:23 2017 us=678662 pkcs11_private_mode = 00000000
Wed Oct 11 11:38:23 2017 us=678662 pkcs11_cert_private = DISABLED
Wed Oct 11 11:38:23 2017 us=678662 pkcs11_pin_cache_period = -1
Wed Oct 11 11:38:23 2017 us=678662 pkcs11_id = '[UNDEF]'
Wed Oct 11 11:38:23 2017 us=678662 pkcs11_id_management = DISABLED
Wed Oct 11 11:38:23 2017 us=678662 server_network = 0.0.0.0
Wed Oct 11 11:38:23 2017 us=678662 server_netmask = 0.0.0.0
Wed Oct 11 11:38:23 2017 us=680673 server_network_ipv6 = ::
Wed Oct 11 11:38:23 2017 us=680673 server_netbits_ipv6 = 0
Wed Oct 11 11:38:23 2017 us=680673 server_bridge_ip = 0.0.0.0
Wed Oct 11 11:38:23 2017 us=680673 server_bridge_netmask = 0.0.0.0
Wed Oct 11 11:38:23 2017 us=680673 server_bridge_pool_start = 0.0.0.0
Wed Oct 11 11:38:23 2017 us=680673 server_bridge_pool_end = 0.0.0.0
Wed Oct 11 11:38:23 2017 us=680673 ifconfig_pool_defined = DISABLED
Wed Oct 11 11:38:23 2017 us=680673 ifconfig_pool_start = 0.0.0.0
Wed Oct 11 11:38:23 2017 us=680673 ifconfig_pool_end = 0.0.0.0
Wed Oct 11 11:38:23 2017 us=680673 ifconfig_pool_netmask = 0.0.0.0
Wed Oct 11 11:38:23 2017 us=680673 ifconfig_pool_persist_filename = '[UNDEF]'
Wed Oct 11 11:38:23 2017 us=680673 ifconfig_pool_persist_refresh_freq = 600
Wed Oct 11 11:38:23 2017 us=680673 ifconfig_ipv6_pool_defined = DISABLED
Wed Oct 11 11:38:23 2017 us=680673 ifconfig_ipv6_pool_base = ::
Wed Oct 11 11:38:23 2017 us=680673 ifconfig_ipv6_pool_netbits = 0
Wed Oct 11 11:38:23 2017 us=680673 n_bcast_buf = 256
Wed Oct 11 11:38:23 2017 us=680673 tcp_queue_limit = 64
Wed Oct 11 11:38:23 2017 us=680673 real_hash_size = 256
Wed Oct 11 11:38:23 2017 us=680673 virtual_hash_size = 256
Wed Oct 11 11:38:23 2017 us=680673 client_connect_script = '[UNDEF]'
Wed Oct 11 11:38:23 2017 us=680673 learn_address_script = '[UNDEF]'
Wed Oct 11 11:38:23 2017 us=680673 client_disconnect_script = '[UNDEF]'
Wed Oct 11 11:38:23 2017 us=680673 client_config_dir = '[UNDEF]'
Wed Oct 11 11:38:23 2017 us=680673 ccd_exclusive = DISABLED
Wed Oct 11 11:38:23 2017 us=680673 tmp_dir = 'C:\Users\user\AppData\Local\Temp\'
Wed Oct 11 11:38:23 2017 us=680673 push_ifconfig_defined = DISABLED
Wed Oct 11 11:38:23 2017 us=680673 push_ifconfig_local = 0.0.0.0
Wed Oct 11 11:38:23 2017 us=680673 push_ifconfig_remote_netmask = 0.0.0.0
Wed Oct 11 11:38:23 2017 us=680673 push_ifconfig_ipv6_defined = DISABLED
Wed Oct 11 11:38:23 2017 us=680673 push_ifconfig_ipv6_local = ::/0
Wed Oct 11 11:38:23 2017 us=680673 push_ifconfig_ipv6_remote = ::
Wed Oct 11 11:38:23 2017 us=680673 enable_c2c = DISABLED
Wed Oct 11 11:38:23 2017 us=680673 duplicate_cn = DISABLED
Wed Oct 11 11:38:23 2017 us=680673 cf_max = 0
Wed Oct 11 11:38:23 2017 us=680673 cf_per = 0
Wed Oct 11 11:38:23 2017 us=680673 max_clients = 1024
Wed Oct 11 11:38:23 2017 us=680673 max_routes_per_client = 256
Wed Oct 11 11:38:23 2017 us=680673 auth_user_pass_verify_script = '[UNDEF]'
Wed Oct 11 11:38:23 2017 us=680673 auth_user_pass_verify_script_via_file = DISABLED
Wed Oct 11 11:38:23 2017 us=680673 client = ENABLED
Wed Oct 11 11:38:23 2017 us=680673 pull = ENABLED
Wed Oct 11 11:38:23 2017 us=680673 auth_user_pass_file = 'auth-i.cfg'
Wed Oct 11 11:38:23 2017 us=680673 show_net_up = DISABLED
Wed Oct 11 11:38:23 2017 us=680673 route_method = 0
Wed Oct 11 11:38:23 2017 us=680673 block_outside_dns = DISABLED
Wed Oct 11 11:38:23 2017 us=680673 ip_win32_defined = DISABLED
Wed Oct 11 11:38:23 2017 us=680673 ip_win32_type = 3
Wed Oct 11 11:38:23 2017 us=680673 dhcp_masq_offset = 0
Wed Oct 11 11:38:23 2017 us=680673 dhcp_lease_time = 31536000
Wed Oct 11 11:38:23 2017 us=680673 tap_sleep = 0
Wed Oct 11 11:38:23 2017 us=680673 dhcp_options = DISABLED
Wed Oct 11 11:38:23 2017 us=680673 dhcp_renew = DISABLED
Wed Oct 11 11:38:23 2017 us=680673 dhcp_pre_release = DISABLED
Wed Oct 11 11:38:23 2017 us=680673 dhcp_release = DISABLED
Wed Oct 11 11:38:23 2017 us=680673 domain = '[UNDEF]'
Wed Oct 11 11:38:23 2017 us=680673 netbios_scope = '[UNDEF]'
Wed Oct 11 11:38:23 2017 us=680673 netbios_node_type = 0
Wed Oct 11 11:38:23 2017 us=680673 disable_nbt = DISABLED
Wed Oct 11 11:38:23 2017 us=680673 OpenVPN 2.3.12 x86_64-w64-mingw32 [SSL (OpenSSL)] [LZO] [PKCS11] [IPv6] built on Aug 23 2016
Wed Oct 11 11:38:23 2017 us=680673 Windows version 6.2 (Windows 8 or greater) 64bit
Wed Oct 11 11:38:23 2017 us=680673 library versions: OpenSSL 1.0.1t 3 May 2016, LZO 2.09
Enter Management Password:
Wed Oct 11 11:38:23 2017 us=680673 WE_INIT maxevents=1 flags=0x00000002
Wed Oct 11 11:38:23 2017 us=680673 WE_INIT maxevents=1 capacity=2
Wed Oct 11 11:38:23 2017 us=681676 MANAGEMENT: TCP Socket listening on [AF_INET]127.0.0.1:25342
Wed Oct 11 11:38:23 2017 us=681676 Need hold release from management interface, waiting...
Wed Oct 11 11:38:23 2017 us=681676 WE_CTL n=0 ev=00000000005002A8 rwflags=0x0001 arg=0x0
Wed Oct 11 11:38:23 2017 us=681676 WE_WAIT enter n=1 to=1000
Wed Oct 11 11:38:23 2017 us=681676 [0] ev=00000000000000A0 rwflags=0x0001 arg=0x0
Wed Oct 11 11:38:24 2017 us=164715 WE_WAIT leave rwflags=0x0001 arg=0x0
Wed Oct 11 11:38:24 2017 us=164715 MANAGEMENT: Client connected from [AF_INET]127.0.0.1:25342
Wed Oct 11 11:38:24 2017 us=164715 WE_CTL n=0 ev=00000000005002A8 rwflags=0x0001 arg=0x0
Wed Oct 11 11:38:24 2017 us=165686 WE_WAIT enter n=1 to=1000
Wed Oct 11 11:38:24 2017 us=165686 [0] ev=00000000000000A0 rwflags=0x0001 arg=0x0
Wed Oct 11 11:38:24 2017 us=166687 WE_WAIT leave rwflags=0x0001 arg=0x0
Wed Oct 11 11:38:24 2017 us=166687 WE_CTL n=0 ev=00000000005002A8 rwflags=0x0001 arg=0x0
Wed Oct 11 11:38:24 2017 us=166687 WE_WAIT enter n=1 to=1000
Wed Oct 11 11:38:24 2017 us=166687 [0] ev=00000000000000A0 rwflags=0x0001 arg=0x0
Wed Oct 11 11:38:24 2017 us=267715 WE_WAIT leave rwflags=0x0001 arg=0x0
Wed Oct 11 11:38:24 2017 us=267715 MANAGEMENT: CMD 'state on'
Wed Oct 11 11:38:24 2017 us=267715 WE_CTL n=0 ev=00000000005002A8 rwflags=0x0001 arg=0x0
Wed Oct 11 11:38:24 2017 us=267715 WE_WAIT enter n=1 to=1000
Wed Oct 11 11:38:24 2017 us=267715 [0] ev=00000000000000A0 rwflags=0x0001 arg=0x0
Wed Oct 11 11:38:24 2017 us=268692 WE_WAIT leave rwflags=0x0001 arg=0x0
Wed Oct 11 11:38:24 2017 us=268692 MANAGEMENT: CMD 'log all on'
Wed Oct 11 11:38:24 2017 us=277692 WE_CTL n=0 ev=00000000005002A8 rwflags=0x0001 arg=0x0
Wed Oct 11 11:38:24 2017 us=278692 WE_WAIT enter n=1 to=1000
Wed Oct 11 11:38:24 2017 us=278692 [0] ev=00000000000000A0 rwflags=0x0001 arg=0x0
Wed Oct 11 11:38:24 2017 us=426702 MANAGEMENT: CMD 'hold off'
Wed Oct 11 11:38:24 2017 us=426702 WE_WAIT leave rwflags=0x0001 arg=0x0
Wed Oct 11 11:38:24 2017 us=426702 WE_CTL n=0 ev=00000000005002A8 rwflags=0x0001 arg=0x0
Wed Oct 11 11:38:24 2017 us=426702 WE_WAIT enter n=1 to=1000
Wed Oct 11 11:38:24 2017 us=426702 [0] ev=00000000000000A0 rwflags=0x0001 arg=0x0
Wed Oct 11 11:38:25 2017 us=426761 WE_CTL n=0 ev=00000000005002A8 rwflags=0x0001 arg=0x0
Wed Oct 11 11:38:25 2017 us=426761 WE_WAIT enter n=1 to=1000
Wed Oct 11 11:38:25 2017 us=426761 [0] ev=00000000000000A0 rwflags=0x0001 arg=0x0
Wed Oct 11 11:38:26 2017 us=426820 WE_CTL n=0 ev=00000000005002A8 rwflags=0x0001 arg=0x0
Wed Oct 11 11:38:26 2017 us=426820 WE_WAIT enter n=1 to=1000
Wed Oct 11 11:38:26 2017 us=426820 [0] ev=00000000000000A0 rwflags=0x0001 arg=0x0
Wed Oct 11 11:38:27 2017 us=426880 WE_CTL n=0 ev=00000000005002A8 rwflags=0x0001 arg=0x0
Wed Oct 11 11:38:27 2017 us=426880 WE_WAIT enter n=1 to=1000
Wed Oct 11 11:38:27 2017 us=426880 [0] ev=00000000000000A0 rwflags=0x0001 arg=0x0
Wed Oct 11 11:38:28 2017 us=426958 WE_CTL n=0 ev=00000000005002A8 rwflags=0x0001 arg=0x0
Wed Oct 11 11:38:28 2017 us=426958 WE_WAIT enter n=1 to=1000
Wed Oct 11 11:38:28 2017 us=426958 [0] ev=00000000000000A0 rwflags=0x0001 arg=0x0
Wed Oct 11 11:38:29 2017 us=426999 WE_CTL n=0 ev=00000000005002A8 rwflags=0x0001 arg=0x0
Wed Oct 11 11:38:29 2017 us=426999 WE_WAIT enter n=1 to=1000
Wed Oct 11 11:38:29 2017 us=426999 [0] ev=00000000000000A0 rwflags=0x0001 arg=0x0
Wed Oct 11 11:38:30 2017 us=427059 WE_CTL n=0 ev=00000000005002A8 rwflags=0x0001 arg=0x0
Wed Oct 11 11:38:30 2017 us=427059 WE_WAIT enter n=1 to=1000
Wed Oct 11 11:38:30 2017 us=427059 [0] ev=00000000000000A0 rwflags=0x0001 arg=0x0
Wed Oct 11 11:38:31 2017 us=427119 WE_CTL n=0 ev=00000000005002A8 rwflags=0x0001 arg=0x0
Wed Oct 11 11:38:31 2017 us=427119 WE_WAIT enter n=1 to=1000
Wed Oct 11 11:38:31 2017 us=427119 [0] ev=00000000000000A0 rwflags=0x0001 arg=0x0
Wed Oct 11 11:38:32 2017 us=427179 WE_CTL n=0 ev=00000000005002A8 rwflags=0x0001 arg=0x0
Wed Oct 11 11:38:32 2017 us=427179 WE_WAIT enter n=1 to=1000
Wed Oct 11 11:38:32 2017 us=427179 [0] ev=00000000000000A0 rwflags=0x0001 arg=0x0
Wed Oct 11 11:38:33 2017 us=427266 WE_CTL n=0 ev=00000000005002A8 rwflags=0x0001 arg=0x0
Wed Oct 11 11:38:33 2017 us=427266 WE_WAIT enter n=1 to=1000
Wed Oct 11 11:38:33 2017 us=427266 [0] ev=00000000000000A0 rwflags=0x0001 arg=0x0
Wed Oct 11 11:38:34 2017 us=427316 WE_CTL n=0 ev=00000000005002A8 rwflags=0x0001 arg=0x0
Wed Oct 11 11:38:34 2017 us=427316 WE_WAIT enter n=1 to=1000
Wed Oct 11 11:38:34 2017 us=427316 [0] ev=00000000000000A0 rwflags=0x0001 arg=0x0
Wed Oct 11 11:38:35 2017 us=427358 WE_CTL n=0 ev=00000000005002A8 rwflags=0x0001 arg=0x0
Wed Oct 11 11:38:35 2017 us=427358 WE_WAIT enter n=1 to=1000
Wed Oct 11 11:38:35 2017 us=427358 [0] ev=00000000000000A0 rwflags=0x0001 arg=0x0
Wed Oct 11 11:38:36 2017 us=427418 WE_CTL n=0 ev=00000000005002A8 rwflags=0x0001 arg=0x0
Wed Oct 11 11:38:36 2017 us=427418 WE_WAIT enter n=1 to=1000
Wed Oct 11 11:38:36 2017 us=427418 [0] ev=00000000000000A0 rwflags=0x0001 arg=0x0
Wed Oct 11 11:38:37 2017 us=427503 WE_CTL n=0 ev=00000000005002A8 rwflags=0x0001 arg=0x0
Wed Oct 11 11:38:37 2017 us=427503 WE_WAIT enter n=1 to=1000
Wed Oct 11 11:38:37 2017 us=427503 [0] ev=00000000000000A0 rwflags=0x0001 arg=0x0
Wed Oct 11 11:38:38 2017 us=427538 WE_CTL n=0 ev=00000000005002A8 rwflags=0x0001 arg=0x0
Wed Oct 11 11:38:38 2017 us=427538 WE_WAIT enter n=1 to=1000
Wed Oct 11 11:38:38 2017 us=427538 [0] ev=00000000000000A0 rwflags=0x0001 arg=0x0
Wed Oct 11 11:38:39 2017 us=427598 WE_CTL n=0 ev=00000000005002A8 rwflags=0x0001 arg=0x0
Wed Oct 11 11:38:39 2017 us=427598 WE_WAIT enter n=1 to=1000
Wed Oct 11 11:38:39 2017 us=427598 [0] ev=00000000000000A0 rwflags=0x0001 arg=0x0
Wed Oct 11 11:38:40 2017 us=427657 WE_CTL n=0 ev=00000000005002A8 rwflags=0x0001 arg=0x0
Wed Oct 11 11:38:40 2017 us=427657 WE_WAIT enter n=1 to=1000
Wed Oct 11 11:38:40 2017 us=427657 [0] ev=00000000000000A0 rwflags=0x0001 arg=0x0
Wed Oct 11 11:38:41 2017 us=427717 WE_CTL n=0 ev=00000000005002A8 rwflags=0x0001 arg=0x0
Wed Oct 11 11:38:41 2017 us=427717 WE_WAIT enter n=1 to=1000
Wed Oct 11 11:38:41 2017 us=427717 [0] ev=00000000000000A0 rwflags=0x0001 arg=0x0
Wed Oct 11 11:38:42 2017 us=427777 WE_CTL n=0 ev=00000000005002A8 rwflags=0x0001 arg=0x0
Wed Oct 11 11:38:42 2017 us=427777 WE_WAIT enter n=1 to=1000
Wed Oct 11 11:38:42 2017 us=427777 [0] ev=00000000000000A0 rwflags=0x0001 arg=0x0
Wed Oct 11 11:38:43 2017 us=427839 WE_CTL n=0 ev=00000000005002A8 rwflags=0x0001 arg=0x0
Wed Oct 11 11:38:43 2017 us=427839 WE_WAIT enter n=1 to=1000
Wed Oct 11 11:38:43 2017 us=427839 [0] ev=00000000000000A0 rwflags=0x0001 arg=0x0
Wed Oct 11 11:38:44 2017 us=427896 WE_CTL n=0 ev=00000000005002A8 rwflags=0x0001 arg=0x0
Wed Oct 11 11:38:44 2017 us=427896 WE_WAIT enter n=1 to=1000
Wed Oct 11 11:38:44 2017 us=427896 [0] ev=00000000000000A0 rwflags=0x0001 arg=0x0
Wed Oct 11 11:38:45 2017 us=427968 WE_CTL n=0 ev=00000000005002A8 rwflags=0x0001 arg=0x0
Wed Oct 11 11:38:45 2017 us=427968 WE_WAIT enter n=1 to=1000
Wed Oct 11 11:38:45 2017 us=427968 [0] ev=00000000000000A0 rwflags=0x0001 arg=0x0
Wed Oct 11 11:38:46 2017 us=428049 WE_CTL n=0 ev=00000000005002A8 rwflags=0x0001 arg=0x0
Wed Oct 11 11:38:46 2017 us=428049 WE_WAIT enter n=1 to=1000
Wed Oct 11 11:38:46 2017 us=428049 [0] ev=00000000000000A0 rwflags=0x0001 arg=0x0
Wed Oct 11 11:38:47 2017 us=428101 WE_CTL n=0 ev=00000000005002A8 rwflags=0x0001 arg=0x0
Wed Oct 11 11:38:47 2017 us=428101 WE_WAIT enter n=1 to=1000
Wed Oct 11 11:38:47 2017 us=428101 [0] ev=00000000000000A0 rwflags=0x0001 arg=0x0
Wed Oct 11 11:38:48 2017 us=428148 Signal received from management interface, exiting
Wed Oct 11 11:38:48 2017 us=428148 PKCS#11: pkcs11_terminate - entered
Wed Oct 11 11:38:48 2017 us=428148 PKCS#11: pkcs11_terminate - return
