2 WAN Mikrotik PPC LoadBalansing and VPN Server problem
Alexybg
Hello,
Sorry for my English but think not understand well Russian, u can write as u wish
I have Mikrotik with PCC Load Balancing working good
5 port
eth1 - WAN1 - PPPOE GW - 85.91.151.8
eth2 - WAN2 - DHCP from other ruter GW - 192.168.0.1
eth3 - bridge for my local network - 192.168.3.3 DHCP for local 192.168.3.4-192.168.3.100
I have VPN PPPT and L2TP Server Standard configuration- connected is successfully throw WAN1
whit different Pools
PPTP Pool - 192.168.4.61-192.168.4.100
L2TP Pool - 192.168.5.61-192.168.5.100
I set mangle prerouting accept for this IP and can ping it from Mikrotik Terminal
The problem became then I decide to make router to me 2 WAN Load Balansing. Before It was only with 1 WAN and VPN was working without problem, I have internet and see local PC
My problem is that then connect from my laptop from different locations don't have Internet throw VPN and can't ping my local network PC
VPN take example 192.168.4.61 for Local and 192.168.4.62 for Remote IP
Can someone help me whit this problem.
Regards
Alexybg
I found my problem in mangle
problem Solved
Regards
Наш форум обладает магической силой!!! :)
Нет, просто хороший пример пользователя, не ждущего помощи в бездействии. Активная жизненная позиция помогает всегда и во всём.
