Mikrotik+bridge+pptp+eoip
mighty44
Господа профессионалы, проверьте пожалуйста правильность написания конфигурации Mikrotik'ов в сети организации:
PPTP+EoIP подняли для шифрования канала;
Каналы организованы путем аренды каналов у оператора интернета;
Главный офис - CCR1009;
Дополнительные офисы (5 штук) RB850Gx2;
CCR1009
# oct/18/2016 09:44:29 by RouterOS 6.36.3
# software id = W5P5-7SDN
add name=ria-bridge
/interface eoip
add !keepalive mac-address=bl:ab:la:bl:ab:la name=ria-EoIP-A remote-address=192.168.100.3 tunnel-id=513
add !keepalive mac-address=bl:ab:la:bl:ab:la name=ria-EoIP-D remote-address=192.168.100.2 tunnel-id=512
add !keepalive mac-address=bl:ab:la:bl:ab:la name=ria-EoIP-R remote-address=192.168.100.5 tunnel-id=515
add !keepalive mac-address=bl:ab:la:bl:ab:la name=ria-EoIP-X remote-address=192.168.100.6 tunnel-id=516
add !keepalive mac-address=bl:ab:la:bl:ab:la name=ria-EoIP-Y remote-address=192.168.100.4 tunnel-id=514
/ppp profile
set *0 bridge=ria-bridge dns-server=192.168.100.66 local-address=192.168.1.222
add bridge=ria-bridge interface=ether2
add bridge=ria-bridge interface=ether3
add bridge=ria-bridge interface=ether4
add bridge=ria-bridge interface=ether5
add bridge=ria-bridge interface=ether6
add bridge=ria-bridge interface=ether7
add bridge=ria-bridge interface=ether8
/interface pppoe-server server
add disabled=no interface=<l2tp> service-name=service1
/interface pptp-server server
set enabled=yes
add address=192.168.100.1/24 interface=ether1 network=192.168.100.0
set allow-remote-requests=yes servers=192.168.100.66
add distance=1 gateway=192.168.100.66
/ppp secret
add local-address=192.168.100.1 name=ria-D password=ytw remote-address=192.168.100.2 service=pptp
add local-address=192.168.100.1 name=ria-A password=ytw remote-address=192.168.100.3 service=pptp
add local-address=192.168.100.1 name=ria-Y password=ytw remote-address=192.168.100.4 service=pptp
add local-address=192.168.100.1 name=ria-R password=ytw remote-address=192.168.100.5 service=pptp
add local-address=192.168.100.1 name=ria-X password=ytw remote-address=192.168.100.6 service=pptp
set time-zone-name=Asia/Krasnoyarsk
/system identity
set name=OWNER
/system routerboard settings
set protected-routerboot=disabled
/tool graphing interface
add
/tool graphing queue
add
/tool graphing resource
add
На всех остальных офисах RB850Gx2 cfg (соответственно IP адреса и номера туннелей разные, а все остальное одинаковое):
[admin@Y] > export compact
# oct/18/2016 09:51:43 by RouterOS 6.34.3
# software id = 7DCC-FYUS
add name=ria-bridge
set [ find default-name=ether2 ] name=ether2-master
/interface pptp-client
add connect-to=192.168.100.1 disabled=no name=ria-tunnel password=ytw user=ria-Y
/interface eoip
add !keepalive mac-address=bl:ab:la:bl:ab:la name=ria-EoIP remote-address=192.168.100.1 tunnel-id=514
/ip neighbor discovery
set ether1 discover=no
add bridge=ria-bridge interface=ether1
add bridge=ria-bridge interface=ether2-master
add bridge=ria-bridge interface=ria-EoIP
add address=192.168.100.4/24 comment=defconf interface=ether2-master network=192.168.100.0
set allow-remote-requests=yes servers=192.168.100.66,192.168.1.66
set time-zone-autodetect=no time-zone-name=Asia/Krasnoyarsk
/system identity
set name=Y
set cpu-frequency=533MHz protected-routerboot=disabled
/tool mac-server
add interface=ether2-master
/tool mac-server mac-winbox
При этом клиент PPTP (RB) все время реконнектиться к серверу PPTP (CCR1009)
И вообще почему-то CCR1009 не пингуется когда PPTP-Client подключен, пингуется когда отключается PPTP-Client от сервера:
[admin@A] > ping 192.168.100.1
  SEQ HOST                                     SIZE TTL TIME  STATUS
    0 192.168.100.1                                           timeout
    1 192.168.100.1                                           timeout
    2 192.168.100.1                                           timeout
    3 192.168.100.1                              56  64 0ms
    4 192.168.100.1                              56  64 0ms
    5 192.168.100.1                              56  64 0ms
    sent=6 received=3 packet-loss=50%
ОТОРВИТЕ МНЕ РУКИ, ЕСЛИ ЧТО НЕ ТАК!!! :-)
Последний раз редактировалось mighty44 18 окт 2016, 09:13, всего редактировалось 1 раз.
Если вы каналы у оператора арендуете то зачем огород городить?
Хотите шифровать так прикрутите IPSec и шифруйте наздоровъе
mighty44
vqd писал(а):Если вы каналы у оператора арендуете то зачем огород городить?
С IPSec'ом что-то у меня не срослось, EoIP удобнее оказался, огород городим чтобы тараканы не полезли во все щели :-)
В будущем планируем построить свой беспроводной канал.
Посмотрите пожалуйста что не так в конфиге :smu:sche_nie:
IpSec и EoIP совершенно разные вещи...
mighty44
vqd писал(а):IpSec и EoIP совершенно разные вещи...
Спасибо за уточнение, так Вы сможете проверить мою конфигурацию?
у вас на CCR1009 eoip в бридж не добавленны
mighty44
vqd писал(а):у вас на CCR1009 eoip в бридж не добавленны
Я когда их добавляю образовывается петля, и соответственно сеть пропадает в некоторых офисах.
ну вы же нагородил огород, вот и ищите откуда петля возникает
Да еще и с ВПН не разобрались. Раз уж вы решили такой вот костыль делать
ТО как минимум нужно учитывать что в другой точке:
В общем дерзайте ))
mighty44
vqd писал(а):ну вы же нагородил огород, вот и ищите откуда петля возникает
В общем дерзайте ))
Прошу прощения, но я Вас не понял, в чем здесь косяк?
KARaS'b
Чот прям трэш. Я бы начал с нуля и для начала попытался бы завязать только один RB850Gx2, а не сразу 5.
Опять таки, опишите цель и условия, подробно, почему выбрали именно EOIP, зачем оно вам, может ваша задача решается более элегантно и правильно.
