# sep/04/2016 21:33:05 by RouterOS 6.34.4
# software id = 1654-R71G
/interface lte
set [ find ] disabled=yes mac-address=1C:49:7B:5E:4F:4B name=lte1
add admin-mac=6C:3B:6B:3B:15:65 auto-mac=no comment=defconf name=bridge
set [ find default-name=ether2 ] name=ether2-master
set [ find default-name=ether3 ] master-port=ether2-master
set [ find default-name=ether4 ] master-port=ether2-master
set [ find default-name=ether5 ] master-port=ether2-master
set [ find default-name=wlan1 ] band=2ghz-b/g/n channel-width=20/40mhz-Ce \
disabled=no distance=indoors frequency=auto mode=ap-bridge ssid=\
MikroTik-3B1569 wireless-protocol=802.11
/ip neighbor discovery
set ether1 discover=no
set bridge comment=defconf
/ip hotspot profile
add name=vpn ranges=192.168.89.2-192.168.89.255
add address-pool=dhcp disabled=no interface=bridge name=defconf
/ppp profile
set *FFFFFFFE local-address=192.168.89.1 remote-address=vpn
/queue simple
add disabled=yes name=queue1 target=8.8.8.8/32
add bridge=bridge comment=defconf interface=ether2-master
/interface l2tp-server server
set enabled=yes ipsec-secret= use-ipsec=yes
/interface pptp-server server
set enabled=yes
/interface sstp-server server
set default-profile=default-encryption enabled=yes
add address=192.168.88.1/24 comment=defconf interface=ether2-master network=\
192.168.88.0
/ip cloud
set ddns-enabled=yes
add comment=defconf dhcp-options=hostname,clientid disabled=no interface=ether1
interface=lte1
set allow-remote-requests=yes
/ip dns static
add chain=input comment="defconf: accept ICMP" in-interface=lte1 protocol=icmp
add chain=input comment="defconf: accept establieshed,related" \
add chain=input protocol=icmp
add chain=input comment="allow l2tp" dst-port=1701 protocol=udp
add chain=input comment="allow pptp" dst-port=1723 protocol=tcp
add chain=input comment="allow sstp" dst-port=443 protocol=tcp
add action=drop chain=input comment="defconf: drop all from WAN" disabled=yes \
in-interface=ether1
add chain=forward comment="defconf: accept established,related" \
add action=drop chain=forward comment="defconf: drop invalid" connection-state=\
invalid disabled=yes
connection-state=new disabled=yes in-interface=ether1
add action=masquerade chain=srcnat comment="defconf: masquerade" out-interface=\
ether1
add action=masquerade chain=srcnat out-interface=lte1
/ppp secret
add name=vpn password=
set time-zone-name=Europe/Samara
/system routerboard settings
set cpu-frequency=650MHz protected-routerboot=disabled
/system watchdog
set automatic-supout=no watch-address=8.8.8.8 watchdog-timer=no
/tool mac-server
add interface=bridge
/tool mac-server mac-winbox
/interface lte
/ip hotspot profile
/ppp profile
/queue simple
set enabled=yes
192.168.88.0
/ip cloud
interface=lte1
/ip dns static
in-interface=ether1
ether1
/ppp secret
/system watchdog
/tool mac-server
