Стоит простая задача, подключиться роутером(mikrotik rb951ui-2hnd) по PPTP к прокси серверу и раздавать интернет по wifi.
Роутер с прокси соединяется, интернет в роутере появляется, а пользователей подключенных по wifi или к остальным портам бриджа не пускает никуда.
Подскажите пожалуйста, в чем у меня ошибка.
# oct/06/2015 14:00:03 by RouterOS 6.32.2
# software id = G67V-WW9S
add admin-mac=D4:CA:6D:BE:B7:91 auto-mac=no name=bridge-local
set [ find default-name=wlan1 ] band=2ghz-b/g/n channel-width=20/40mhz-ht-above disabled=no distance=indoors frequency=auto l2mtu=2290 mode=ap-bridge ssid=MikroTik-BEB795 wireless-protocol=802.11
set [ find default-name=ether3 ] master-port=ether2-master-local name=ether3-slave-local
set [ find default-name=ether4 ] master-port=ether2-master-local name=ether4-slave-local
set [ find default-name=ether5 ] master-port=ether2-master-local name=ether5-slave-local
/interface pptp-client
add add-default-route=yes connect-to=172.26.114.23 dial-on-demand=yes disabled=no keepalive-timeout=disabled name=pptp-out1 password=zxcvbnm1234567890 user="kemproxy\\MobileUser"
/ip neighbor discovery
add address-pool=dhcp disabled=no interface=bridge-local name=default
add address=192.168.88.1/24 comment="default configuration" interface=ether2-master-local network=192.168.88.0
add comment="default configuration" dhcp-options=hostname,clientid disabled=no interface=ether1-gateway
add address=192.168.88.0/24 comment="default configuration" dns-server=192.168.88.1 gateway=192.168.88.1 netmask=24
set allow-remote-requests=yes
/ip dns static
add chain=forward comment="default configuration" connection-state=established,related
add action=drop chain=forward comment="default configuration" connection-state=invalid
add action=drop chain=forward comment="default configuration" connection-nat-state=!dstnat connection-state=new in-interface=ether1-gateway
add chain=input protocol=icmp
add chain=input connection-state=established
add chain=input connection-state=related
add chain=input in-interface=ether1-gateway
add action=drop chain=input in-interface=ether1-gateway
add action=masquerade chain=srcnat comment="default configuration" out-interface=ether1-gateway
/system leds
set 0 interface=wlan1
/tool mac-server
add interface=wlan1
/tool mac-server mac-winbox
add interface=wlan1
