настройки произведенные на свитче:
[admin@MikroTik] /interface ethernet switch> ingress-vlan-translation print
0 ports=ether2,ether3,ether4,ether5,ether6,ether7,ether8,ether9,ether10,
ether11,ether12,ether13,ether14,ether15,ether16,ether17,ether18,ether19,
ether20,ether21,ether22,ether23,ether24
service-vlan-format=any customer-vlan-format=any customer-vid=0
new-customer-vid=100 pcp-propagation=no sa-learning=no
1 D ports=sfp1 service-vlan-format=any customer-vlan-format=any
new-customer-vid=4095 pcp-propagation=no sa-learning=no
[admin@MikroTik] /interface ethernet switch> egress-vlan-tag print
# VLAN-ID TAGGED-PORTS
0 2 ether1
1 100 ether1
2 D 4095
[admin@MikroTik] /interface ethernet switch> vlan print
# VLAN-ID PORTS SVL LEARN FLOOD INGRESS-MIRROR QOS-GROUP
0 2 ether1 no yes no no none
1 100 ether1 no yes no no none
ether2
ether3
ether4
ether5
ether6
ether7
ether8
ether9
ether10
ether11
ether12
ether13
ether14
ether15
ether16
ether17
ether18
ether19
ether20
ether21
ether22
ether23
ether24
2 D 4095 sfp1 no no no no none
switch1-cpu
[admin@MikroTik] > ip address print
# ADDRESS NETWORK INTERFACE
0 X.X.X.X/22 X.X.X.X ether1
[admin@MikroTik] > interface ethernet switch port-isolation print
Flags: X - disabled, D - dynamic, I - invalid
0 ports=ether1 type=dst forwarding-type=bridged,routed
traffic-type=unicast,multicast,broadcast
registration-status=known,unknown
protocol-type=arp,nd,dhcpv4,dhcpv6,ripv1 port-profile=1
1 D ports=ether1,ether2,ether3,ether4,ether5,ether6,ether7,ether8,ether9,ether10
ether20,ether21,ether22,ether23,ether24,switch1-cpu
protocol-type=arp,nd,dhcpv4,dhcpv6,ripv1 port-profile=29
2 D ports=switch1-cpu type=dst forwarding-type=bridged,routed
protocol-type=arp,nd,dhcpv4,dhcpv6,ripv1 port-profile=30
Свитч используется для доступа пользователей к Интернет
Абонентский vlan100, подключаются через PPPoE.
В этом же влане приходит IGMP.
Как правильно настроить IGMP на свитче?
помогите настроить IGMP на CRS125-24G-1S
