Нет доступа к проброшенному порту из внутренней сети.
hravn
На роутере проброшены порты 80 и 443. Из интернета спокойно попадаю на ресурсы. Как только подключаюсь к домашней сети доступ пропадает.
Конфиг в спойлере, по форуму поискал не нашёл ответа.
 Конфиг
# jul/29/2014 11:36:42 by RouterOS 6.17
# software id = 3CLN-3WDI
add admin-mac=4C:5E:0C:40:17:E2 auto-mac=no l2mtu=1598 name=bridge-local
set [ find default-name=ether1 ] name=eth0
set [ find default-name=ether2 ] name=eth1
set [ find default-name=ether3 ] name=eth2
set [ find default-name=ether4 ] name=eth3
set [ find default-name=ether5 ] name=eth4
set [ find default-name=ether6 ] name=eth5-switch
set [ find default-name=ether7 ] master-port=eth5-switch name=eth6-sw
set [ find default-name=ether8 ] master-port=eth5-switch name=eth7-sw
set [ find default-name=ether9 ] mac-address=50:E5:49:CF:1B:7B name=eth8-wan2
set [ find default-name=ether10 ] mac-address=50:E5:49:CF:1B:7B name=\
eth9-wan1
/ip neighbor discovery
set eth0 discover=no
add authentication-types=wpa2-psk mode=dynamic-keys name=WiFi_N \
wpa2-pre-shared-key=
add authentication-types=wpa2-psk management-protection=allowed mode=\
dynamic-keys name=Her wpa2-pre-shared-key=0987654312
band=2ghz-onlyn country=russia disabled=no frequency=2427 l2mtu=2290 \
mode=ap-bridge security-profile=WiFi_N ssid="Home N"
/ip hotspot user profile
mac-cookie-timeout=3d
/ip ipsec proposal
set [ find default=yes ] enc-algorithms=3des
add name=home_pool ranges=192.168.214.10-192.168.214.254
add address-pool=home_pool disabled=no interface=bridge-local name=home_srv
/port
set 0 name=serial0
add bridge=bridge-local interface=eth1
add bridge=bridge-local interface=eth2
add bridge=bridge-local interface=eth3
add bridge=bridge-local interface=eth4
add bridge=bridge-local interface=eth5-switch
add bridge=bridge-local interface=sfp1
add bridge=bridge-local interface=eth0
add address=192.168.214.1/24 comment="default configuration" interface=\
bridge-local network=192.168.214.0
add comment=WAN dhcp-options=hostname,clientid disabled=no interface=\
eth9-wan1
add comment=WAN default-route-distance=0 dhcp-options=hostname,clientid \
disabled=no interface=eth8-wan2
/ip dhcp-server lease
add address=192.168.214.2 mac-address=00:25:90:0E:40:19 server=home_srv
add address=192.168.214.5 mac-address=52:54:00:88:65:F8 server=home_srv
add address=192.168.214.0/24 comment="default configuration" dns-server=\
192.168.214.1 domain= gateway=192.168.214.1
set allow-remote-requests=yes
/ip dns static
add address=192.168.214.1 name=gw
add action=drop chain=input comment="default configuration" in-interface=eth0
add chain=forward comment="default configuration" connection-state=\
established
connection-state=invalid
add action=masquerade chain=srcnat out-interface=eth9-wan1
add action=netmap chain=dstnat comment="ssh nat pc" dst-port=61489 \
in-interface=eth9-wan1 protocol=tcp to-addresses=192.168.214.254 \
to-ports=22
add action=netmap chain=dstnat dst-port=80 in-interface=eth9-wan1 protocol=\
tcp to-addresses=192.168.214.3 to-ports=80
add action=netmap chain=dstnat dst-port=443 in-interface=eth9-wan1 protocol=\
tcp to-addresses=192.168.214.5 to-ports=443
/ip ipsec policy
add template=yes
/ip service
set telnet disabled=yes
set ftp disabled=yes
set www address=0.0.0.0/0 port=4443
set ssh port=61488
set api address=192.168.214.0/24 disabled=yes
set winbox disabled=yes
set api-ssl disabled=yes
/ip traffic-flow
set enabled=yes
/ip upnp
set allow-disable-external-interface=no enabled=yes
/lcd interface pages
set 0 interfaces="sfp1,eth0,eth1,eth2,eth3,eth4,eth5-switch,eth6-sw,eth7-sw,et\
h8-wan2,eth9-wan1"
/system ntp client
set enabled=yes primary-ntp=95.104.193.195 secondary-ntp=88.147.254.232
/tool mac-server0ms;"
add interface=eth1
add interface=eth2
add interface=eth3
add interface=eth4
add interface=eth5-switch
add interface=eth6-sw
add interface=eth7-sw
add interface=eth8-wan2
add interface=sfp1
add interface=wlan1
add interface=bridge-local
/tool mac-server mac-winbox
add interface=eth1
add interface=eth2
add interface=eth3
add interface=eth4
add interface=sfp1
add interface=wlan1
Если пытаетесь подключаться изнутри по внешнему адресу, то у вас конечно ничего не получится. Либо делайте http://wiki.mikrotik.com/wiki/Hairpin_NAT либо подключайтесь по внутреннему адресу.
