Микротик не ходит в интернет
psymode
Нет выхода в сеть с разных машин. микротик rb951ui-2hnd . Причем внешка активно пингуется через терминал в веббоксе, и более того , через cmd в самой винде. Сломал мозг. Хилфе.
 конфиг
add arp=proxy-arp l2mtu=1598 name=bridge_LAN
/ip hotspot user profile
set [ find default=yes ] idle-timeout=none keepalive-timeout=2m
add name=dhcp_pool1 ranges=192.168.88.2-192.168.88.254
add address-pool=dhcp_pool1 disabled=no interface=bridge_LAN name=dhcp1
add bridge=bridge_LAN interface=ether2
add bridge=bridge_LAN interface=ether3
add bridge=bridge_LAN interface=ether4
add bridge=bridge_LAN interface=ether5
add bridge=bridge_LAN interface=wlan1
add address=10.58.2.208/16 interface=ether1
add address=192.168.88.1/24 interface=bridge_LAN
add address=192.168.88.0/24 dns-server=192.168.88.1 gateway=192.168.88.1
set allow-remote-requests=yes servers=78.40.80.165,217.117.80.1,8.8.8.8
/ip firewall address-list
add address=192.168.88.0/24 list=admin_subnet
add address=10.0.0.0/8 comment=Private_Class_A list=bogons
add address=172.16.0.0/12 comment=Private_Class_B list=bogons
add address=0.0.0.0/8 comment=Self_identufication list=bogons
add address=127.0.0.0/16 comment=Loopback list=bogons
add address=169.254.0.0/16 comment=Link_local list=bogons
add address=198.0.2.0/24 comment=Reserved_testnet_1 list=bogons
add address=192.88.99.0/24 comment="6tor4Relay Anycast" list=bogons
add address=198.51.100.0/24 comment=Reserved_Tstnet_2 list=bogons
add address=203.0.113.0/24 comment=Reserved_Testnet_3 list=bogons
add chain=input src-address=192.168.88.0/24
add action=add-src-to-address-list address-list=Syn_Flooder \
    address-list-timeout=30m chain=input connection-limit=30,32 protocol=tcp \
    tcp-flags=syn
add action=drop chain=input src-address-list=Syn_Flooder
add action=add-src-to-address-list address-list=Port_Scanner \
    address-list-timeout=1w chain=input comment=Port_Scanner_Detect protocol=\
    tcp psd=21,3s,3,1
add action=drop chain=input src-address-list=Port_Scanner
add action=jump chain=input jump-target=ICMP protocol=icmp
add action=drop chain=input dst-port=8291 protocol=tcp src-address-list=\
    !admin_subnet
add action=jump chain=forward jump-target=ICMP protocol=icmp
add action=drop chain=forward dst-address-list=bogons
add action=add-src-to-address-list address-list=spammers address-list-timeout=\
    3h chain=forward connection-limit=30,32 dst-port=25,587 limit=30/1m,0 \
    protocol=tcp
add action=drop chain=forward dst-port=25,587 protocol=tcp src-address-list=\
    spammers
add chain=input port=53 protocol=udp
add chain=input port=53 protocol=tcp
add chain=input connection-state=established
add chain=input connection-state=related
add chain=input src-address-list=admin_subnet
add chain=ICMP icmp-options=8:0 limit=1,5 protocol=icmp
add chain=ICMP icmp-options=0:0 protocol=icmp
add chain=ICMP icmp-options=11:0 protocol=icmp
add chain=ICMP icmp-options=3:0-1 protocol=icmp
add chain=ICMP icmp-options=3:4 protocol=icmp
add action=drop chain=ICMP protocol=icmp
add action=jump chain=output jump-target=ICMP protocol=icmp
add action=masquerade chain=srcnat comment="Added by webbox" out-interface=\
    ether1 to-addresses=0.0.0.0
add distance=1 gateway=10.58.0.1
/ip upnp
set allow-disable-external-interface=no enabled=yes
/ip upnp interfaces
add interface=ether1 type=external
add interface=ether2 type=internal
add interface=ether3 type=internal
add interface=ether4 type=internal
add interface=ether5 type=internal
add interface=wlan1 type=internal
add interface=bridge_LAN type=internal
/system script
add name=script1 policy=\
    ftp,reboot,read,write,policy,test,winbox,password,sniff,sensitive,api \
    source="/ip firewall filter\r\
    \nadd action=add-src-to-address-list address-list=Syn_Flooder address-list-t\
    imeout=30m chain=input \\\r\
    \nconnection-limit=30,32 disabled=no protocol=tcp tcp-flags=syn\r\
    \nadd action=drop chain=input disabled=no src-address-list=Syn_Flooder\r\
    \nadd action=add-src-to-address-list address-list=Port_Scanner address-list-\
    timeout=1w chain=input comment=\"Port_Scanner_Detect\"\\\r\
    \ndisabled=no protocol=tcp psd=21,3s,3,1\r\
    \nadd action=drop chain=input disabled=no src-address-list=Port_Scanner\r\
    \nadd action=jump chain=input disabled=no jump-target=ICMP protocol=icmp\r\
    \nadd action=drop chain=input\\\r\
    \ndisabled=no dst-port=8291 protocol=tcp src-address-list=!admin_subnet\r\
    \nadd action=jump chain=forward disabled=no jump-target=ICMP protocol=icmp\r\
    \nadd action=drop chain=forward disabled=no dst-address-list=bogons\r\
    \nadd action=add-src-to-address-list address-list=spammers address-list-time\
    out=3h chain=forward\\\r\
    \nconnection-limit=30,32 disabled=no dst-port=25,587 limit=30/1m,0 protocol=\
    tcp\r\
    \nadd action=drop chain=forward disabled=no dst-port=25,587 protocol=tcp src\
    -address-list=spammers\r\
    \nadd action=accept chain=input disabled=no port=53 protocol=udp\r\
    \nadd action=accept chain=input disabled=no port=53 protocol=tcp\r\
    \nadd action=accept chain=input connection-state=established disabled=no\r\
    \nadd action=accept chain=input connection-state=related disabled=no\r\
    \nadd action=accept chain=input disabled=no src-address-list=admin_subnet\r\
    \nadd action=drop chain=input disabled=no\r\
    \nadd action=accept chain=ICMP disabled=no icmp-options=8:0 limit=1,5 protoc\
    ol=icmp\r\
    \nadd action=accept chain=ICMP disabled=no icmp-options=0:0 protocol=icmp\r\
    \nadd action=accept chain=ICMP disabled=no icmp-options=11:0 protocol=icmp\r\
    \nadd action=accept chain=ICMP disabled=no icmp-options=3:0-1 protocol=icmp\
    \r\
    \nadd action=accept chain=ICMP disabled=no icmp-options=3:4 protocol=icmp\r\
    \nadd action=drop chain=ICMP disabled=no protocol=icmp\r\
    \nadd action=jump chain=output disabled=no jump-target=ICMP protocol=icmp"
[admin@MikroTik] >
DeLL
Ну Вы любители писать конфиги по примерам из инета))
У вас прописана внешка и шлюз:
Далее ВЕСЬ этот диапазон адресов внесен в список bogons:
А в файрволе Вы блокируете прохождение трафика в сторону этих адресов, то есть в сторону шлюза
Как-то странно все это)
psymode
Спасибо за замечание, и вправду опростоволосился. удалил из списка.но увы в инет все равно не пускает. вторые сутки война...
DeLL
Странно. Это должно было решить проблему.
Если ни у кого больше нет вариантов - тогда остается один единственный способ. Сбросить в нулевую конфигурацию (без загрузки заводских) и настроить все заново)
А отключить ВСЕ правила в firewall filter не пробовали?
И не понял, от прова к Вам адрес фиксированный? Не по DHCP получаете. А то клиента я не увидел...
psymode
podarok66 инет по статичному ip.
правила все в фаерволе выключал. делал настройку со сбросом дефолтных настроек ( и не один раз уже блин ) обновился с 6.0 на 6.27 затем откатился на 5.6 ( если не вру)
локал работает, пинги идут. интернета нет.
Идет третья ночь войны...
NAT нужен.
Если ната нет - на маршрутизаторах оператора нужно объявлять твою внутреннюю сеть и прописывать до нее маршруты. Они же ее не знают.
Нужен НАТ
psymode
Нат сделан таким макаром /ip firewall nat
реакции ноль.
еще пинги с потерями всетаки идут. через раз без потерь.
DeLL
Если пинги с потерями - смотри трассировку где они пропадают. Тогда можно будет судить где проблемы - кабель менять, брак микротика или провайдер над тобой прикалывается)
Вообще, если пинги с потерями, однозначно первое, что проверяется - обжим коннекторов. Уже неоднократно проходили здесь на форуме...
