Groove 52HPn,пропадает связь между устройствами.
Nikolai
Настроен мост 3 км . уровни сигнала 70...99%/70..99%
Переодически клиент отключаеться от базы . Сам подключиться не может . Приходиться его паерезагружать (из розетки). С погодой вроде не связано , может быть помехи ?
Конфигурация , клиента
# jan/02/1970 03:40:42 by RouterOS 5.26
# software id = DUDN-NQ5N
add l2mtu=1600 name=bridge1
add l2mtu=1596 name=bridge2
set 0 adaptive-noise-immunity=ap-and-client-mode antenna-gain=24 band=\
2ghz-b/g/n basic-rates-a/g="" basic-rates-b="" disabled=no frequency=2427 \
ht-ampdu-priorities=0,1,2,3,4,5,6,7 ht-basic-mcs=\
mcs-7,mcs-8,mcs-9,mcs-10,mcs-11,mcs-12,mcs-13,mcs-14,mcs-15 \
ht-guard-interval=long ht-supported-mcs="mcs-7,mcs-8,mcs-9,mcs-10,mcs-11,m\
cs-12,mcs-13,mcs-14,mcs-15,mcs-16,mcs-17,mcs-18,mcs-19,mcs-20,mcs-21,mcs-2\
2,mcs-23" l2mtu=2290 mode=station-bridge nv2-preshared-key=babadafa90 \
nv2-security=enabled radio-name=Client rate-set=configured ssid=kostrisin \
supported-rates-a/g="" supported-rates-b="" wds-default-bridge=bridge1 \
wds-mode=dynamic wireless-protocol=nv2 wmm-support=enabled
/interface wireless nstreme
set wlan1 disable-csma=yes enable-nstreme=yes framer-policy=dynamic-size
/interface vlan
add interface=bridge1 l2mtu=1596 name=Radionet vlan-id=880
set [ find default=yes ] authentication-types=wpa-psk,wpa2-psk eap-methods=\
passthrough group-ciphers=tkip,aes-ccm mode=dynamic-keys \
supplicant-identity=MikroTik unicast-ciphers=tkip,aes-ccm \
wpa-pre-shared-key=babadafa90 wpa2-pre-shared-key=babadafa90
/ip hotspot user profile
set [ find default=yes ] idle-timeout=none keepalive-timeout=2m
add address-pool=default-dhcp disabled=no interface=ether1 name=default
add bridge=bridge2 interface=Radionet
add address=192.168.88.20/24 comment="default configuration" interface=ether1
add address=192.168.180.36/23 interface=bridge2
add comment="default configuration" disabled=no interface=wlan1
add address=192.168.88.0/24 comment="default configuration" dns-server=\
192.168.88.1 gateway=192.168.88.1
/ip dns static
wlan1
add chain=forward comment="default configuration" connection-state=\
established
connection-state=invalid
out-interface=wlan1 to-addresses=0.0.0.0
/ip neighbor discovery
set Radionet disabled=yes
add distance=1 gateway=192.168.180.1
/system identity
set name=kostrisin_client
/system leds
set 0 interface=wlan1
set 1 interface=ether1
/system routerboard settings
set cpu-frequency=600MHz
/tool mac-server
add disabled=no interface=ether1
/tool mac-server mac-winbox
add interface=ether1
это у вас не мост и ничего общего с мостом нет
Ставьте направленные антенны, настраивайте нормальный мост и будет Вам счастье. так же рекомендую посмотреть чего в эфире творится ну и просчитать вашу трассу
Nikolai
Расскажите какими средствами сканировать эфир и на какие цифры обратить внимание ?
