[admin@home-router] > ip firewall filter print
0 chain=input action=accept src-address="remote LAN" dst-address="router LAN IP"
1 chain=output action=accept src-address="router LAN IP" dst-address="remote LAN"
2 chain=forward action=accept src-address="remote LAN" dst-address="local LAN"
3 chain=forward action=accept src-address="local LAN" dst-address="remote LAN"
4 ;;; block access to internal WEB-proxy from WAN
chain=input action=drop protocol=tcp src-address=0.0.0.0 in-interface=wan dst-port=8080
5 chain=input action=accept protocol=udp src-port=500
6 chain=input action=accept protocol=ipsec-esp
7 chain=input action=accept protocol=tcp dst-port=80
8 ;;; default configuration
9 ;;; default configuration
chain=input action=accept connection-state=established
10 ;;; default configuration
chain=input action=accept connection-state=related
11 ;;; default configuration
chain=input action=drop in-interface=wan
[admin@home-router] > ip firewall nat print
0 chain=srcnat action=accept src-address="local LAN" dst-address="remote LAN"
1 chain=dstnat action=accept src-address="local LAN" dst-address="remote LAN"
2 X ;;; exclude external WEB-proxy from redirecting
chain=dstnat action=accept protocol=tcp src-address="external proxy in local LAN IP" dst-port=80,443
3 X ;;; redirect WEB-requests to external WEB-proxy
chain=dstnat action=dst-nat to-addresses="external proxy in local LAN IP" to-ports=8080 protocol=tcp src-address="local LAN" dst-port=80,443
4 X ;;; exclude internal WEB-proxy from redirecting
chain=dstnat action=accept protocol=tcp src-address="router LAN IP" dst-port=80,443
5 X ;;; redirect WEB-requests to internal WEB-proxy
chain=dstnat action=redirect to-addresses="external proxy in local LAN IP" to-ports=8080 protocol=tcp src-address="local LAN" dst-port=80,443
6 ;;; forward DNS querys for remote LAN to remote LAN dns-server IP
chain=dstnat action=dst-nat to-addresses="remote LAN dns-server IP" connection-mark=mtrele.ru-forward
7 ;;; default configuration
chain=srcnat action=masquerade out-interface=wanПрошу обратить внимание на правило №5 для NAT (оно отключено, но и во включенном состоянии то же самое). У меня в веб-интерфейсе УСТАНОВЛЕН ИМЕННО РЕДИРЕКТ на порт 8080, а консоль зачем-то выдаёт ещё и "to-addresses="external proxy in local LAN IP"!!! Что это такое - вообще ума не приложу! Кто врёт? Может, микротик ещё где-то со мной так же "шутит"?
WinBox показывает то же, что и веб-интерфейс, т.е. редирект на 8080 (без to-addresses). При включении этого правила редирект идёт, как и полагается, на Web Proxy микротика, а не на внешний.
так у меня ведь точно так и прописаны правила. Не работает... Для внутреннего - работает, для внешнего - нет. Повторюсь: с внешним прокси всё в порядке. Через браузер напрямую на него всё работает. И в цепочке с внутренним прокси микротика он тоже работает...
