Низкая скорость по wifi
06 авг 2013, 12:00
Да в целом ничего сверхестественного. Диапозон 20/40Mhz, HT Rx и Tx раскиданы по отдельности на chain0 и chain1. Одна антена Rx, вторая Tx.
Вроде все.
set 0 adaptive-noise-immunity=none allow-sharedkey=no antenna-gain=0 antenna-mode=rxa-txb area="" arp=enabled band=2ghz-b/g/n \
basic-rates-a/g=6Mbps basic-rates-b="" bridge-mode=enabled channel-width=20/40mhz-ht-below compression=no country=russia \
default-ap-tx-limit=0 default-authentication=yes default-client-tx-limit=0 default-forwarding=yes dfs-mode=none \
disable-running-check=no disabled=no disconnect-timeout=3s distance=indoors frame-lifetime=0 frequency=2462 frequency-mode=\
superchannel frequency-offset=0 hide-ssid=no ht-ampdu-priorities=0 ht-amsdu-limit=8192 ht-amsdu-threshold=8192 ht-basic-mcs=\
mcs-0,mcs-1,mcs-2,mcs-3,mcs-4,mcs-5,mcs-6,mcs-7 ht-guard-interval=any ht-rxchains=1 ht-supported-mcs="mcs-0,mcs-1,mcs-2,mcs-3,\
mcs-4,mcs-5,mcs-6,mcs-7,mcs-8,mcs-9,mcs-10,mcs-11,mcs-12,mcs-13,mcs-14,mcs-15,mcs-16,mcs-17,mcs-18,mcs-19,mcs-20,mcs-21,mcs-22\
,mcs-23" ht-txchains=0 hw-fragmentation-threshold=disabled hw-protection-mode=none hw-protection-threshold=0 hw-retries=7 \
l2mtu=2290 mac-address=D4:CA:6D:52:58:0D max-station-count=100 mode=ap-bridge mtu=1492 multicast-helper=default name=wlan1 \
noise-floor-threshold=default nv2-cell-radius=30 nv2-noise-floor-offset=default nv2-preshared-key="" nv2-qos=default \
nv2-queue-count=2 nv2-security=disabled on-fail-retry-time=100ms periodic-calibration=enabled periodic-calibration-interval=\
10 preamble-mode=both proprietary-extensions=post-2.9.25 radio-name=D4CA6D52580D rate-selection=advanced rate-set=default \
scan-list=default security-profile=default ssid=MikroTik station-bridge-clone-mac=00:00:00:00:00:00 supported-rates-a/g=\
6Mbps,9Mbps,12Mbps,18Mbps,24Mbps,36Mbps,48Mbps,54Mbps supported-rates-b="" tdma-period-size=2 tx-power-mode=default \
update-stats-interval=disabled wds-cost-range=50-150 wds-default-bridge=none wds-default-cost=100 wds-ignore-ssid=no \
wds-mode=disabled wireless-protocol=802.11 wmm-support=disabled
Barvinok
27 ноя 2013, 23:20
Вот в этом руководстве уверенно заявляется, что
При установки пункта Antenna Mode в режим antenna A работают встроенные антенны устройства, для включения внешней антенны нужно установить antenna B и снять галочки с канала chain0.
Таким образом, настройка antenna-mode=rxa-txb применима только в случае, когда у вас подключена внешняя антенна.
Если её нет, нужно ставить antenna-mode=ant-a.
Разве не так?
