Периодически падает OSPF
IL76
День добрый.
Почти год микротик отработал практически как по часам, и тут, ни с того ни с сего два дня назад начал валиться OSPF.
Происходит это почему то в течение ночи, затем прекращается.
Девайс День добрый.
Девайс RB1100AHx2, прошивка 6.1
в логах вижу вот это:
 Логи
jul/02 00:04:26 route,ospf,info OSPFv2 neighbor ххх.ххх.204.2: state change from Full to Init
jul/02 00:14:52 route,ospf,info OSPFv2 neighbor ххх.ххх.204.2: state change from Full to Init
jul/02 00:19:17 route,ospf,info Database Description packet has init bit set in middle of an exchange
jul/02 00:19:17 route,ospf,info OSPFv2 neighbor ххх.ххх.204.2: state change from Full to 2-Way
jul/02 00:20:23 route,ospf,info OSPFv2 neighbor ххх.ххх.204.2: state change from Full to Init
jul/02 00:22:37 route,ospf,info Database Description packet has init bit set in middle of an exchange
jul/02 00:22:37 route,ospf,info OSPFv2 neighbor ххх.ххх.204.2: state change from Full to 2-Way
jul/02 00:24:32 route,ospf,info OSPFv2 neighbor ххх.ххх.204.2: state change from Full to Init
jul/02 00:25:28 route,ospf,info OSPFv2 neighbor ххх.ххх.204.2: state change from Full to Init
jul/02 00:36:33 route,ospf,info OSPFv2 neighbor ххх.ххх.204.2: state change from Full to Init
jul/02 00:40:14 route,ospf,info OSPFv2 neighbor ххх.ххх.204.2: state change from Full to Init
jul/02 01:40:17 route,ospf,info Database Description packet has init bit set in middle of an exchange
jul/02 01:40:17 route,ospf,info OSPFv2 neighbor ххх.ххх.204.2: state change from Full to 2-Way
jul/02 01:41:29 route,ospf,info OSPFv2 neighbor ххх.ххх.204.2: state change from Full to Init
jul/02 01:46:06 route,ospf,info OSPFv2 neighbor ххх.ххх.204.2: state change from Full to Init
jul/02 01:47:03 route,ospf,info OSPFv2 neighbor ххх.ххх.204.2: state change from Full to Init
jul/02 01:50:23 route,ospf,info OSPFv2 neighbor ххх.ххх.204.2: state change from Full to Init
ju
jul/02 21:44:18 route,ospf,info OSPFv2 neighbor ххх.ххх.14.2: state change from Full to Init
jul/02 21:46:32 route,ospf,info OSPFv2 neighbor ххх.ххх.204.2: state change from Full to Init
jul/02 21:46:38 route,ospf,info OSPFv2 neighbor ххх.ххх.14.2: state change from Full to Init
jul/02 21:47:28 route,ospf,info OSPFv2 neighbor ххх.ххх.14.2: state change from Full to Init
jul/02 21:56:20 route,ospf,info OSPFv2 neighbor ххх.ххх.204.2: state change from Full to Init
jul/02 21:57:08 route,ospf,info OSPFv2 neighbor ххх.ххх.14.2: state change from Full to Init
jul/02 21:59:28 route,ospf,info OSPFv2 neighbor ххх.ххх.14.2: state change from Full to Init
jul/02 22:20:48 route,ospf,info OSPFv2 neighbor ххх.ххх.14.2: state change from Full to Init
jul/02 22:22:18 route,ospf,info OSPFv2 neighbor ххх.ххх.14.2: state change from Full to Init
jul/02 22:27:54 route,ospf,info OSPFv2 neighbor ххх.ххх.204.2: state change from Full to Init
jul/02 22:29:58 route,ospf,info OSPFv2 neighbor ххх.ххх.204.2: state change from Full to Init
jul/02 22:39:28 route,ospf,info OSPFv2 neighbor ххх.ххх.14.2: state change from Full to Init
jul/03 23:42:22 route,ospf,info OSPFv2 neighbor ххх.ххх.204.2: state change from Full to Init
jul/03 23:45:12 route,ospf,info OSPFv2 neighbor ххх.ххх.204.2: state change from Full to Init
jul/03 23:46:10 route,ospf,info OSPFv2 neighbor ххх.ххх.204.2: state change from Full to Init
jul/03 23:47:06 route,ospf,info OSPFv2 neighbor ххх.ххх.204.2: state change from Full to Init
jul/03 23:48:13 route,ospf,info OSPFv2 neighbor ххх.ххх.204.2: state change from Full to Init
jul/03 23:49:54 route,ospf,info Database Description packet has init bit set in middle of an exchange
jul/03 23:49:54 route,ospf,info OSPFv2 neighbor ххх.ххх.204.2: state change from Full to 2-Way
jul/03 23:51:02 route,ospf,info OSPFv2 neighbor ххх.ххх.204.2: state change from Full to Init
00:06:04 route,ospf,info Database Description packet has init bit set in middle of an exchange
00:06:04 route,ospf,info OSPFv2 neighbor ххх.ххх.204.2: state change from Full to 2-Way
00:06:54 route,ospf,info Database Description packet has init bit set in middle of an exchange
00:06:54 route,ospf,info OSPFv2 neighbor ххх.ххх.204.2: state change from Full to 2-Way
00:09:07 route,ospf,info OSPFv2 neighbor ххх.ххх.204.2: state change from Full to Init
00:16:32 route,ospf,info OSPFv2 neighbor ххх.ххх.204.2: state change from Full to Init
Куда копать? Что делать? Один нейбор - Cisco Catalyst, второй D-Link Switch, прошивка 6.1
я бы предложил следующее
- посмотреть системные ресурсы в момент обрыва
- откатиться на 5.25 и посмотреть на нем будут ли обрывы
- проверить линию, возможно упало качество связи и по-вечерам при пиковой нагрузке рвется осфп
- написать на саппорт*микротик.ком, хотя они портебуют именно прошивку 6.х на устройстве
IL76
iSupport писал(а):- посмотреть системные ресурсы в момент обрыва
1) попробуем
2) буду пробовать если не поможет первое
3) с линией все впорядке. патчкорд длиной в полметра, никаких ошибок на интерфейсе нет
по результатам отпишусь
