Вот конфиги основного роутера и точек доступа:
Основной:
/caps-man manager
set enabled=yes
/caps-man channel
add band=2ghz-onlyn control-channel-width=20mhz frequency=2412,2437 name=ch_2.4GHz tx-power=20
add band=5ghz-n/ac frequency=5300 name=ch_5GHz tx-power=20
/caps-man datapath
add bridge=bridge1 client-to-client-forwarding=yes name=datapath1
/caps-man security
add authentication-types=wpa2-psk encryption=aes-ccm group-encryption=aes-ccm name=security1
/caps-man configuration
add channel=ch_2.4GHz datapath=datapath1 mode=ap name=cfg_2.4 rx-chains=0,1,2,3 security=security1 ssid=VESNA tx-chains=0,1,2,3
add channel=ch_5GHz datapath=datapath1 mode=ap name=cfg_5 rx-chains=0,1,2,3 security=security1 ssid=VESNA_5G tx-chains=0,1,2,3
/caps-man provisioning
add action=create-dynamic-enabled hw-supported-modes=gn master-configuration=cfg_2.4 name-format=prefix-identity name-prefix=2G
add action=create-dynamic-enabled hw-supported-modes=ac,an master-configuration=cfg_5 name-format=prefix-identity name-prefix=5G
add disabled=no interface=bridge1
add name=bridge1
add bridge=bridge1 interface=all
/interface wireless cap
set discovery-interfaces=bridge1 enabled=yes interfaces=wlan2,wlan1
Подскажите в какую сторону копать, что за странная проблема. Спасибо!
