Настройки CAPsMAN wifi-qcom hap ax2
yurchenkoyuriy
Мужики, пожалуйста помогите, несколько дней не могу понять, почему
локальные интерфейсы не получают настройки и соответственно сеть не светит в эфир.
 Конфигурация
# 2025-03-12 10:22:28 by RouterOS 7.18.1
# software id = FK5E-8CPA
# model = C52iG-5HaxD2HaxD
# serial number = HFK09E5N1QC
/interface wifi channel
add band=2ghz-ax disabled=no name=channel1_24
add band=5ghz-ax disabled=no name=channel2_5 skip-dfs-channels=disabled
/interface wifi
# managed by CAPsMAN 6.5.2.8
set [ find default-name=wifi1 ] configuration=cfg2_5 configuration.manager=\
capsman .mode=ap disabled=no
set [ find default-name=wifi2 ] configuration=cfg1_24 configuration.manager=\
/interface wifi cap
set discovery-interfaces=bridge1 enabled=yes
/interface wifi capsman
set enabled=yes package-path="" require-peer-certificate=no upgrade-policy=\
none
/interface wifi configuration
add channel=channel1_24 datapath=datapath1 disabled=no mode=ap name=cfg1_24 \
ssid="\F0\9F\90\BE"
add channel=channel2_5 datapath=datapath1 disabled=no mode=ap name=cfg2_5 \
ssid="\F0\9F\90\BE"
/interface wifi datapath
add bridge=bridge1 disabled=no name=datapath1
/interface wifi provisioning
add action=create-dynamic-enabled disabled=no master-configuration=cfg1_24 \
name-format=local24 supported-bands=2ghz-ax
add action=create-dynamic-enabled disabled=no master-configuration=cfg2_5 \
name-format=local5 supported-bands=5ghz-ax
yurchenkoyuriy
Видимо я сам нашел
 ответ:
Manual provision can be done under /interface/wifi/capsman/remote-cap/provision to provision all radios associated with specific CAPs, it can also be done under /interface/wifi/radio/provision , to provision specific radios.
CAPsMAN cannot manage it's own wifi interfaces using configuration.manager=capsman, it is enough to just set the same configuration profile on local interfaces manually as you would with provisioning rules, and the end result will be the same as if they were CAPs. That being said, it is also possible to provision local interfaces via /interface/wifi/radio menu, it should be noted that to regain control of local interfaces after provisioning, you will need to disable the matching provisioning rules and press "provision" again, which will return local interfaces to an unconfigured state.
Provision must be done only initially, and is done automatically upon CAP joining if there are matching provisioning rules that are enabled.
If you adjust any configuration profile that is linked to the provisioned interface, all changes will be "pushed" as soon as you apply changes to the profile, with no need to re-create the already existing interface.
Provisioning itself is not for sending configuration, it is for essentially creating a new interface. In most cases, there is no reason to perform manual provisioning once you already have CAP interfaces running.
Перевод:
CAPsMAN не может управлять собственными интерфейсами Wi-Fi с помощью configuration.manager=capsman, достаточно просто вручную установить тот же профиль конфигурации на локальных интерфейсах.
Только будет ли бесшовность работать между точкой и основным....
GReK79rus
yurchenkoyuriy писал(а): 12 мар 2025, 12:35 Видимо я сам нашел
 ответ:
Перевод:
Доброго!
Если проблема еще актуально то вот что нашел:
Внимание! Когда мы настраиваем WiFi интерфейсы на самом контроллере (если таковые там имеются), там нужно указать Manager: local, иначе они не поднимутся!
yurchenkoyuriy
GReK79rus писал(а): 15 апр 2025, 14:18
Доброго!
Привет. Спасибо, не актуально, .т.к. они не совместимы, а по вашей инфе - не обязательно указывать Manager, и так работает.
harvester
Так по итогу hap ax 2 не может работать вместе со старыми CAP?
svetogor82
harvester писал(а): 30 май 2025, 22:51 Так по итогу hap ax 2 не может работать вместе со старыми CAP?
На сколько я знаю нет не может
