Потеря пакетов при высокой нагрузке.
isp55
Установлен RB3011UiAS. За ним 2 неуправляемых свитча гигабитных на 24 порта. Порядка 35 компьютеров. Интернет 300Мегабит/с.
Конфиг крайне простой:
# 2024-05-09 15:16:07 by RouterOS 7.10.2
# software id = PFH3-RU29
# model = RB3011UiAS
# serial number = XXXXX
add admin-mac=2C:C8:1B:0C:45:43 auto-mac=no comment=defconf name=bridge \
    protocol-mode=none
set [ find default-name=ether1 ] comment=WAN
set [ find default-name=ether2 ] comment="tp-link small switch"
set [ find default-name=ether3 ] disabled=yes
set [ find default-name=ether4 ] disabled=yes
set [ find default-name=ether5 ] disabled=yes
set [ find default-name=ether6 ] disabled=yes
set [ find default-name=ether7 ] disabled=yes
set [ find default-name=ether8 ] comment=nvr
set [ find default-name=ether9 ] comment=switch_big
set [ find default-name=ether10 ] comment="lan cache"
/interface list
add comment=defconf name=WAN
add comment=defconf name=LAN
/interface lte apn
set [ find default=yes ] ip-type=ipv4 use-network-apn=no
add address-pool=default-dhcp interface=bridge lease-time=10m name=defconf
/port
set 0 name=serial0
/queue type
add kind=pcq name=pcq-download pcq-classifier=dst-address \
    pcq-dst-address6-mask=64 pcq-src-address6-mask=64
add kind=pcq name=pcq-upload pcq-classifier=src-address \
/queue simple
add dst=ether1 max-limit=250M/250M name=queue1 priority=1/1 queue=\
    pcq-upload-default/pcq-download-default target=192.168.88.0/24 \
    total-queue=default
/routing bgp template
set default disabled=no output.network=bgp-networks
/routing ospf instance
add disabled=no name=default-v2
/routing ospf area
add disabled=yes instance=default-v2 name=backbone-v2
add bridge=bridge comment=defconf ingress-filtering=no interface=ether2
add bridge=bridge comment=defconf ingress-filtering=no interface=ether3
add bridge=bridge comment=defconf ingress-filtering=no interface=ether4
add bridge=bridge comment=defconf ingress-filtering=no interface=ether5
add bridge=bridge comment=defconf ingress-filtering=no interface=ether6
add bridge=bridge comment=defconf ingress-filtering=no interface=ether7
add bridge=bridge comment=defconf ingress-filtering=no interface=ether8
add bridge=bridge comment=defconf ingress-filtering=no interface=ether9
add bridge=bridge comment=defconf ingress-filtering=no interface=ether10
/ip settings
set max-neighbor-entries=8192
/ipv6 settings
set disable-ipv6=yes max-neighbor-entries=8192
/interface list member
/interface ovpn-server server
set auth=sha1,md5
add address=192.168.88.1/24 comment=LAN interface=bridge network=192.168.88.0
add address=XXX.XXX.XX.XX/30 comment=WAN interface=ether1 network=\
    XX.XX.XXX.XXX
/ip dhcp-server lease
add address=192.168.88.236 mac-address=2C:F0:5D:CD:91:07 server=defconf
add address=192.168.88.225 mac-address=2C:F0:5D:DE:F4:1B server=defconf
add address=192.168.88.226 mac-address=2C:F0:5D:DE:DF:38 server=defconf
add address=192.168.88.227 mac-address=2C:F0:5D:DE:F3:6C server=defconf
add address=192.168.88.228 mac-address=2C:F0:5D:CD:7F:34 server=defconf
add address=192.168.88.229 mac-address=2C:F0:5D:DE:F2:EA server=defconf
add address=192.168.88.231 mac-address=1C:3B:F3:0F:55:07 server=defconf
add address=192.168.88.233 mac-address=2C:F0:5D:DE:F3:63 server=defconf
add address=192.168.88.232 mac-address=54:E1:40:DD:B6:12 server=defconf
add address=192.168.88.234 mac-address=2C:F0:5D:CD:7F:19 server=defconf
add address=192.168.88.235 mac-address=2C:F0:5D:CD:8A:B6 server=defconf
add address=192.168.88.237 mac-address=2C:F0:5D:CD:91:0E server=defconf
add address=192.168.88.238 mac-address=2C:F0:5D:D0:73:45 server=defconf
add address=192.168.88.239 mac-address=2C:F0:5D:D0:73:3E server=defconf
add address=192.168.88.240 mac-address=2C:F0:5D:CD:91:1A server=defconf
add address=192.168.88.245 mac-address=2C:F0:5D:CD:89:11 server=defconf
add address=192.168.88.246 mac-address=2C:F0:5D:D0:73:41 server=defconf
add address=192.168.88.247 mac-address=2C:F0:5D:DE:F4:45 server=defconf
add address=192.168.88.248 mac-address=2C:F0:5D:DE:F3:B4 server=defconf
add address=192.168.88.251 mac-address=2C:F0:5D:CD:88:9F server=defconf
add address=192.168.88.253 mac-address=2C:F0:5D:DE:F4:66 server=defconf
set servers=192.168.88.90,192.168.88.91,192.168.88.92,192.168.88.93
    invalid
add action=accept chain=input comment=WinBOX dst-port=8291 in-interface=\
    ether1 protocol=tcp
    "defconf: accept to local loopback (for CAPsMAN)" dst-address=127.0.0.1
    in-interface-list=!LAN
    ipsec-policy=in,ipsec
    ipsec-policy=out,ipsec
    connection-state=invalid
add action=src-nat chain=srcnat comment=srcnat ipsec-policy=out,none \
    out-interface-list=WAN to-addresses=XX.XX.XX.XX
add disabled=no dst-address=0.0.0.0/0 gateway=XX.XX.XX.XX
/ip service
set telnet disabled=yes
set ftp disabled=yes
set www disabled=yes
set ssh disabled=yes
set api disabled=yes
set winbox port=8291
set api-ssl disabled=yes
/lcd
set default-screen=interfaces touch-screen=disabled
/lcd interface
set ether2 disabled=yes
set ether3 disabled=yes
set ether4 disabled=yes
set ether5 disabled=yes
set sfp1 disabled=yes
set ether6 disabled=yes
set ether7 disabled=yes
set ether8 disabled=yes
set ether9 disabled=yes
set ether10 disabled=yes
/routing bfd configuration
add disabled=no interfaces=all min-rx=200us min-tx=200us multiplier=5
/system note
set show-at-login=no
/tool mac-server
/tool mac-server mac-winbox
На wan интерфейсе статический IP от провайдера.
Был настроен примитивный QoS в виде Simple Queues (ограничение 250Мегабит) для равномерного распределения скорости между пользователями.
Так же в сети присутствует lancache сервер, который так же выполняет роль DNSа (подключен в 1гигабитный порт)
Периодически происходят проблема: один из пользователей начинает что-то качать (например, обновления WoT). Качает на скорости порядка 150Мегабит/c. По статистике в torch видно что ему не вся полоса отдается, но у остальных пользователей проиходит ухудшение пинга вплоть до потери пакетов. Загрузка CPU порядка 90%. По profile в меню CPU видно, что процессоры (2ядра, вкладка All) загружены от networking ~40%, firewall ~20% и queuing ~30%. Ошибок и дропов по портам нет.
Можно как-то улучшить ситуацию или роутер слабоват?
Правильно ли настроен QoS или лучше по каждому пользователю ограничивать скорость?
Спасибо!
В каком месте потери происходят?
Качает из интернета? И у остальных пользователей ухудшается пинг ресурсов в интернете?
Если пинговать ресурсы в своей сети, ухудшения есть?
По конфигу вопросы есть.
1. На 1 порт адрес назначен руками и DHCP клиентом
XX.XX.XXX.XXX
2. Адреса ДНС серверов есть в пуле DHCP. Однажды он их выдаст, и будет конфликт
isp55
Erik_U писал(а): 09 май 2024, 16:19 В каком месте потери происходят?
Скачивание из интернета. И у остальных плохо
Пропадают пинги до 8.8.8.8 и яндекса. Отваливался на пинг и 192.168.88.90
Erik_U писал(а): 09 май 2024, 16:30 По конфигу вопросы есть.
XX.XX.XXX.XXX
1. На WAN интерфейсе белая статика от провайдера. dhcp-client выключил
2. 192.168.88.90,192.168.88.91,192.168.88.92,192.168.88.93 статикой настроены в конфиге lancache
Какой тип очереди у вас используется? Попробуйте pcq. 3011 довольно мощная железка.
Ну и ответьте толком, что выше спросили: пропадают ли пинги на локальные ресурсы в момент проблемы?
isp55 писал(а): 09 май 2024, 16:39
или уберите эти адреса из пула, или создайте для них статические записи, чтобы у DHCP сервера они были заняты.
попробуйте временно отключить правила QoS, и посмотрите ушла ли проблема.
isp55
gmx писал(а): 09 май 2024, 16:43 Какой тип очереди у вас используется? Попробуйте pcq. 3011 довольно мощная железка.
1. PCQ и использую
/queue simple
    total-queue=default
2. Ответил выше. Да, до того же ланкэш 192.168.88.90 при высокой нагрузке пинг пропадал. Загрузка процессора около 100%
isp55
Erik_U писал(а): 09 май 2024, 16:57
1. Убрал. На компьютерах так же везде статика. DHCP не особо используется.
2. При отключение все только хуже. Прилетают обновления на игры и один человек занимает всю полосу.
isp55 писал(а): 09 май 2024, 17:17
а что при этом с загрузкой процессора?
isp55
Erik_U писал(а): 09 май 2024, 17:25
Проверю этот момент. Вопрос в другом, как скорость тогда делить равномерно?
