В чем может быть проблема?
# 2024-04-25 20:45:22 by RouterOS 7.14.3
# model = C52iG-5HaxD2HaxD
add admin-mac=78:9A:18:E0:48:A4 auto-mac=no comment=defconf name=bridge \
port-cost-mode=short
set [ find default-name=ether1 ] mac-address=74:4D:28:BD:
/interface wifi
set [ find default-name=wifi1 ] channel.skip-dfs-channels=10min-cac \
configuration.country=Russia .mode=ap .ssid=ax5 disabled=no \
security.authentication-types=wpa2-psk
set [ find default-name=wifi2 ] channel.skip-dfs-channels=10min-cac \
configuration.country=Russia .mode=ap .ssid=ax disabled=no \
/interface list
add comment=defconf name=WAN
add comment=defconf name=LAN
add address-pool=default-dhcp interface=bridge lease-time=10m name=defconf
add bridge=bridge comment=defconf interface=ether2 internal-path-cost=10 \
path-cost=10
add bridge=bridge comment=defconf interface=ether3 internal-path-cost=10 \
path-cost=10
add bridge=bridge comment=defconf interface=ether4 internal-path-cost=10 \
path-cost=10
add bridge=bridge comment=defconf interface=ether5 internal-path-cost=10 \
path-cost=10
add bridge=bridge comment=defconf interface=wifi1 internal-path-cost=10 \
path-cost=10
add bridge=bridge comment=defconf interface=wifi2 internal-path-cost=10 \
path-cost=10
set udp-timeout=10s
/interface detect-internet
set detect-interface-list=all internet-interface-list=LAN
/interface list member
add address=192.168.88.1/24 comment=defconf interface=bridge network=\
192.168.88.0
add address=192.168.88.0/24 comment=defconf dns-server=192.168.88.1 gateway=\
192.168.88.1
set allow-remote-requests=yes servers=8.8.8.8
/ip dns static
add address=192.168.88.1 comment=defconf name=router.lan
invalid
"defconf: accept to local loopback (for CAPsMAN)" dst-address=127.0.0.1
in-interface-list=!LAN
ipsec-policy=in,ipsec
ipsec-policy=out,ipsec
connection-state=established,related hw-offload=yes
add action=drop chain=forward comment="defconf: drop invalid" connection-state=\
invalid
add action=drop chain=forward comment="defconf: drop all from WAN not DSTNATed" \
connection-nat-state=!dstnat connection-state=new in-interface-list=WAN
add action=masquerade chain=srcnat comment="defconf: masquerade" ipsec-policy=\
out,none out-interface-list=WAN
/ipv6 firewall address-list
add address=::/128 comment="defconf: unspecified address" list=bad_ipv6
add address=::1/128 comment="defconf: lo" list=bad_ipv6
add address=fec0::/10 comment="defconf: site-local" list=bad_ipv6
add address=::ffff:0.0.0.0/96 comment="defconf: ipv4-mapped" list=bad_ipv6
add address=::/96 comment="defconf: ipv4 compat" list=bad_ipv6
add address=100::/64 comment="defconf: discard only " list=bad_ipv6
add address=2001:db8::/32 comment="defconf: documentation" list=bad_ipv6
add address=2001:10::/28 comment="defconf: ORCHID" list=bad_ipv6
add address=3ffe::/16 comment="defconf: 6bone" list=bad_ipv6
/ipv6 firewall filter
invalid
add action=accept chain=input comment="defconf: accept ICMPv6" protocol=icmpv6
add action=accept chain=input comment="defconf: accept UDP traceroute" port=\
33434-33534 protocol=udp
"defconf: accept DHCPv6-Client prefix delegation." dst-port=546 protocol=\
udp src-address=fe80::/10
add action=accept chain=input comment="defconf: accept IKE" dst-port=500,4500 \
protocol=udp
add action=accept chain=input comment="defconf: accept ipsec AH" protocol=\
ipsec-ah
add action=accept chain=input comment="defconf: accept ipsec ESP" protocol=\
ipsec-esp
"defconf: accept all that matches ipsec policy" ipsec-policy=in,ipsec
"defconf: drop everything else not coming from LAN" in-interface-list=!LAN
invalid
add action=drop chain=forward comment="defconf: drop packets with bad src ipv6" \
src-address-list=bad_ipv6
add action=drop chain=forward comment="defconf: drop packets with bad dst ipv6" \
dst-address-list=bad_ipv6
add action=drop chain=forward comment="defconf: rfc4890 drop hop-limit=1" \
hop-limit=equal:1 protocol=icmpv6
add action=accept chain=forward comment="defconf: accept ICMPv6" protocol=\
icmpv6
add action=accept chain=forward comment="defconf: accept HIP" protocol=139
add action=accept chain=forward comment="defconf: accept IKE" dst-port=500,4500 \
protocol=udp
add action=accept chain=forward comment="defconf: accept ipsec AH" protocol=\
ipsec-ah
add action=accept chain=forward comment="defconf: accept ipsec ESP" protocol=\
ipsec-esp
/system note
set show-at-login=no
/tool mac-server
/tool mac-server mac-winbox
/interface wifi
/interface list
path-cost=10
path-cost=10
path-cost=10
path-cost=10
path-cost=10
path-cost=10
set udp-timeout=10s
192.168.88.0
192.168.88.1
/ip dns static
invalid
invalid
invalid
protocol=udp
ipsec-ah
ipsec-esp
invalid
icmpv6
protocol=udp
ipsec-ah
ipsec-esp
/system note
/tool mac-server
