Настройки Wi-Fi Hap ax3
seregaelcin
Да тут особо то и нечего конфигурить. Вот мой конфиг
/interface wifi channel
add band=2ghz-ax disabled=no frequency=2447 name=WiFi2-channel width=20/40mhz-eC
add band=5ghz-ax disabled=no frequency=5260,5300 name=WiFi5-channel width=20/40/80mhz
/interface wifi security
add authentication-types=wpa2-psk disabled=no group-key-update=30m management-protection=allowed name=Security
/interface wifi configuration
add chains=0,1 channel=WiFi2-channel country=Russia disabled=no mode=ap multicast-enhance=enabled name=WiFi2_BASE security=Security ssid=MikroTik tx-power=10
add channel=WiFi5-channel country=Russia disabled=no mode=ap multicast-enhance=enabled name=WiFi5_BASE security=Security ssid=Mikrotik5 tx-power=17
/interface wifi
set [ find default-name=wifi1 ] configuration=WiFi5_BASE configuration.mode=ap disabled=no
set [ find default-name=wifi2 ] configuration=WiFi2_BASE configuration.mode=ap disabled=no
Скорости на 2,4ГГц - 135-140 Мбит/с, на 5ГГц - 280 Мбит/с
