есть два wana и vpn. включен socks, соединения приходящие из vpn нормально проходят через прокси и выходя в инет через wan1. Пытаюсь завернуть
эти соединения в wan 2 через manlge, но упорно не идут. Подскажите где ошибся?
Flags: X - disabled, I - invalid; D - dynamic
0 D ;;; special dummy rule to show fasttrack counters
chain=prerouting action=passthrough
1 D ;;; special dummy rule to show fasttrack counters
chain=forward action=passthrough
2 D ;;; special dummy rule to show fasttrack counters
chain=postrouting action=passthrough
3 chain=prerouting action=mark-connection new-connection-mark=In1 passthrough=yes protocol=tcp
dst-address=10.12.10.2 dst-port=28302 nth=2,1 log=yes log-prefix="udpmark"
4 chain=prerouting action=mark-routing new-routing-mark=SOCS passthrough=no protocol=tcp
connection-mark=In1 nth=2,1 log=yes log-prefix="udpmark"
5 chain=postrouting action=change-ttl new-ttl=set:65 passthrough=no out-interface=lte1 log=no
log-prefix=""
0 ;;; defconf: masquerade
chain=srcnat action=masquerade out-interface=ether1 log=no log-prefix="" ipsec-policy=out,none
1 chain=srcnat action=masquerade out-interface=lte1 log=no log-prefix="" ipsec-policy=out,none
2 X chain=dstnat action=dst-nat to-addresses=192.168.47.97 to-ports=3389 protocol=tcp
in-interface=ether1 src-port="" dst-port=43021 log=yes log-prefix="8443"
3 X chain=dstnat action=netmap to-addresses=192.168.47.11 to-ports=21 protocol=tcp
in-interface=ether1 dst-port=21 log=yes log-prefix="8443"
4 X chain=dstnat action=netmap to-addresses=192.168.47.11 protocol=tcp in-interface=*F log=yes
log-prefix="ggg"
