# model = RouterBOARD 3011UiAS
/caps-man channel
add band=2ghz-g/n extension-channel=disabled name=channel2,4
add band=5ghz-a/n/ac name=channel5
add admin-mac=64:D1:54:40:62:7B auto-mac=no comment=\
"created from master port" name=bridge1 protocol-mode=none
add name=bridge_Guest_WiFi
/caps-man datapath
add bridge=bridge1 client-to-client-forwarding=yes local-forwarding=yes name=\
datapath1
add bridge=bridge_Guest_WiFi client-to-client-forwarding=yes \
local-forwarding=no name=datapath_Guest_WiFi
/caps-man security
add authentication-types=wpa2-psk encryption=aes-ccm group-encryption=aes-ccm \
name=AGRO passphrase=******
name=security_Guest_WiFi passphrase=*******
/caps-man configuration
add channel=channel2,4 datapath=datapath1 mode=ap name=cfg2,4 rx-chains=\
0,1,2,3 security=AGRO ssid=AGRO tx-chains=0,1,2,3
add channel=channel5 datapath=datapath1 mode=ap name=cfg5 rx-chains=0,1,2,3 \
security=AGRO ssid=AGRO5 tx-chains=0,1,2,3
add channel=channel2,4 datapath=datapath_Guest_WiFi mode=ap name=\
cfg2,4_Guest_WiFi rx-chains=0,1,2,3 security=security_Guest_WiFi ssid=\
Guest_WiFi tx-chains=0,1,2,3
add name=POOL-LAN ranges=192.168.0.2-192.168.0.199
add name=POOL_Guest_WiFi ranges=192.168.155.2-192.168.155.254
add address-pool=POOL-LAN authoritative=after-2sec-delay disabled=no \
interface=bridge1 lease-time=1d name=DHCL-LAN
add address-pool=POOL_Guest_WiFi disabled=no interface=bridge_Guest_WiFi \
lease-time=3h10m name=DHCP_Guest-WiFi
/caps-man access-list
add action=accept allow-signal-out-of-range=10s comment=\
"\D0\F3\E4\EE\EC\F1\FC\EA\E0 \ED\EE\F3\F2" disabled=no interface=any \
mac-address=2A:56:5E:87:B4:C9 ssid-regexp=AGRO
add action=reject allow-signal-out-of-range=10s comment=\
"DENY \"AGRO\" ANY ANY" disabled=yes ssid-regexp=AGRO
/caps-man manager
set enabled=yes
/caps-man provisioning
add action=create-dynamic-enabled comment=cfg2.4/guest_wificfg2.4 \
hw-supported-modes=gn master-configuration=cfg2,4 name-format=\
prefix-identity name-prefix=cfg2.4 slave-configurations=cfg2,4_Guest_WiFi
add action=create-dynamic-enabled comment=cfg5an hw-supported-modes=an,a,ac \
master-configuration=cfg5 name-format=prefix-identity name-prefix=cfg5
add action=create-dynamic-enabled comment=cfg4ac disabled=yes \
hw-supported-modes=ac master-configuration=cfg5 name-format=\
add address=192.168.0.1/24 interface=bridge1 network=192.168.0.0
add address=192.168.155.1/24 interface=bridge_Guest_WiFi network=\
192.168.155.0
add address=192.168.0.0/24 dns-server=8.8.8.8 gateway=192.168.0.1 netmask=24
add address=192.168.155.0/24 gateway=192.168.155.1
add action=accept chain=input comment=UnblockCapsman dst-address-type=local \
src-address-type=local
