Всем доброго дня.
Цель. Две сети, сеть WiFi. У каждой сетки свой пул адресов. Все сети должны быть изолированы друг от друга. У всех должен быть интернет. Вроде всё настроил, но инета нет. Что делаю не так?
Прошу помощи. Конфиг ниже. Спасибо.
# oct/06/2020 11:49:48 by RouterOS 6.47
# software id = KBRQ-TLIM
# model = 951Ui-2HnD
# serial number = 643105AF3631
add arp=proxy-arp name=bridge1 protocol-mode=none
add arp=proxy-arp name=bridge2 protocol-mode=none
add arp=proxy-arp name=bridge3 protocol-mode=none
/interface pppoe-client
add add-default-route=yes default-route-distance=10 disabled=no interface=\
ether1 name=pppoe-out1 password=12345 use-peer-dns=yes user=\
12345
set [ find default-name=wlan1 ] antenna-gain=0 band=2ghz-b/g/n country=russia \
disabled=no frequency-mode=manual-txpower mode=ap-bridge ssid=virus \
station-roaming=enabled wireless-protocol=802.11
set [ find default=yes ] authentication-types=wpa-psk,wpa2-psk mode=\
dynamic-keys supplicant-identity=MikroTik wpa-pre-shared-key=12345 \
wpa2-pre-shared-key=12345
add name=network1 ranges=192.168.0.2-192.168.0.254
add name=network2 ranges=192.168.1.2-192.168.1.254
add name=network3 ranges=192.168.2.2-192.168.2.254
set discover-interface-list=discover
add address-pool=network1 disabled=no interface=bridge1 name=dhcp1
add address-pool=network2 disabled=no interface=bridge2 name=dhcp2
add address-pool=network3 disabled=no interface=bridge3 name=dhcp3
add bridge=bridge2 interface=ether3
add bridge=bridge3 interface=wlan1
add address=192.168.0.0/24 interface=bridge1 network=192.168.0.0
add address=192.168.1.0/24 interface=bridge2 network=192.168.1.0
add address=192.168.2.0/24 interface=bridge3 network=192.168.2.0
add disabled=no interface=ether1
add address=192.168.0.0/24 gateway=192.168.0.1
add address=192.168.1.0/24 gateway=192.168.1.1
add address=192.168.2.0/24 gateway=192.168.2.0
# pppoe-out1 not ready
add action=drop chain=input in-interface=pppoe-out1
add action=drop chain=forward in-interface=bridge1 out-interface=bridge2
add action=drop chain=forward in-interface=bridge2 out-interface=bridge1
add action=drop chain=forward in-interface=bridge1 out-interface=bridge3
add action=drop chain=forward in-interface=bridge2 out-interface=bridge3
add action=drop chain=forward in-interface=bridge3 out-interface=bridge1
add action=drop chain=forward in-interface=bridge3 out-interface=bridge2
add action=masquerade chain=srcnat out-interface=pppoe-out1
Несколько сетей на разных портах
Адреса не правильно заданы.
А для третей сети ещё и gateway в настройках dhcp-server network.
Еще не вижу никаких настроек DNS.
И firewall можно сделать проще: добавить все три интерфейса в один интерфейс-лист, и, например, разрешать для этого листа наружу, а всё остальное сбрасывать.
