# jul/09/2020 17:35:18 by RouterOS 6.45.9
# software id = PLT6-2UG0
# model = RouterBOARD 962UiGS-5HacT2HnT
# serial number = 8A77085CDB30
add fast-forward=no name=Lan
set [ find default-name=ether1 ] speed=100Mbps
set [ find default-name=ether2 ] speed=100Mbps
set [ find default-name=ether3 ] speed=100Mbps
set [ find default-name=ether4 ] speed=100Mbps
set [ find default-name=ether5 ] speed=100Mbps
set [ find default-name=sfp1 ] advertise=\
10M-half,10M-full,100M-half,100M-full,1000M-half,1000M-full
set [ find default-name=wlan1 ] antenna-gain=0 band=2ghz-b/g/n country=\
no_country_set disabled=no frequency=auto frequency-mode=manual-txpower \
mode=ap-bridge ssid=MikroTik
set [ find default-name=wlan2 ] antenna-gain=0 band=5ghz-a/n/ac channel-width=\
20/40/80mhz-Ceee country=russia disabled=no distance=indoors frequency=auto \
mode=ap-bridge ssid="MikroTik AC" wmm-support=enabled
set [ find default=yes ] authentication-types=wpa2-psk eap-methods="" mode=\
dynamic-keys supplicant-identity=MikroTik
/ip hotspot profile
add name=pool1 ranges=111.111.1.100-111.111.1.254
add address-pool=pool1 disabled=no interface=Lan name=server1
add bridge=Lan interface=ether2
add bridge=Lan interface=wlan1
add bridge=Lan interface=wlan2
add bridge=Lan interface=ether3
add address=111.111.1.1/24 interface=Lan network=111.111.1.0
add dhcp-options=hostname,clientid disabled=no interface=ether1 use-peer-dns=no
add address=192.168.1.0/24 dns-server=192.168.1.1 gateway=192.168.1.1 netmask=\
24
set allow-remote-requests=yes servers=8.8.8.8,8.8.4.4
add action=masquerade chain=srcnat src-address=111.111.1.0/24
/ip service
set winbox disabled=yes
/ip socks
set enabled=yes max-connections=500 port=3629
/ip socks access
add action=deny src-address=!5.96.0.0/12
/system package update
set channel=long-term
