[admin@MikroTik] > /export compact
# nov/20/2019 22:54:23 by RouterOS 6.45.7
# software id = D1DG-NPYY
# model = RouterBOARD 962UiGS-5HacT2HnT
# serial number = 8A770950024B
add igmp-snooping=yes name=bridge1
/interface pppoe-client
add add-default-route=yes disabled=no interface=ether1 name=pppoe-out1 \
password=5c6136a6 use-peer-dns=yes user=22758
set [ find default-name=wlan1 ] country=russia disabled=no mode=ap-bridge \
multicast-helper=full ssid=Zef2G wireless-protocol=802.11
set [ find default-name=wlan2 ] country=russia disabled=no mode=ap-bridge \
multicast-helper=full ssid=Zef5G wireless-protocol=802.11
/interface list
add name=WAN
add name=LAN
set [ find default=yes ] authentication-types=wpa-psk,wpa2-psk mode=\
dynamic-keys supplicant-identity=MikroTik wpa-pre-shared-key=7896541236987 \
wpa2-pre-shared-key=7896541236987
/ip hotspot profile
add name=dhcp ranges=192.168.0.10-192.168.0.100
# DHCP server can not run on slave interface!
add address-pool=dhcp disabled=no interface=ether2 name=dhcp1
add address-pool=dhcp disabled=no interface=bridge1 name=dhcp2
add bridge=bridge1 interface=wlan2
/interface list member
add list=LAN
add address=192.168.0.1/24 interface=ether2 network=192.168.0.0
add address=192.168.0.0/24 gateway=192.168.0.1 netmask=24
add action=masquerade chain=srcnat out-interface-list=WAN
/ip upnp
set enabled=yes
/ip upnp interfaces
add interface=ether2 type=internal
add interface=pppoe-out1 type=external
add interface=bridge1 type=internal
/routing igmp-proxy
set quick-leave=yes
/routing igmp-proxy interface
add alternative-subnets=0.0.0.0/0 interface=bridge1 upstream=yes
/system routerboard settings
set auto-upgrade=yes
/tool mac-server
/tool mac-server mac-winbox
/tool traffic-generator
set test-id=1
