Делал полный сброс, но ничего не помогло, со временем ошибка повторяется.
/export hide-sensitive :
# nov/05/2019 01:15:16 by RouterOS 6.45.3
# software id = ERGR-V55T
# model = RouterBOARD 952Ui-5ac2nD
# serial number = *
add admin-mac==***.***.***.*** auto-mac=no comment=defconf name=bridge
set [ find default-name=ether1 ] name=Net
set [ find default-name=ether2 ] name=ether2PC
set [ find default-name=wlan1 ] band=2ghz-b/g/n channel-width=20/40mhz-Ce \
country=russia disabled=no distance=indoors frequency=auto mode=ap-bridge \
name=2G ssid=**** wireless-protocol=802.11 wps-mode=disabled
set [ find default-name=wlan2 ] band=5ghz-a/n/ac channel-width=20/40/80mhz-Ceee \
country=russia disabled=no distance=indoors frequency=auto frequency-mode=\
superchannel hw-protection-mode=rts-cts mode=ap-bridge multicast-helper=\
full name=5G ssid=**** wireless-protocol=802.11 wmm-support=\
enabled
/interface wireless nstreme
set "5G" enable-polling=no
/interface list
add comment=defconf name=WAN
add comment=defconf name=LAN
set [ find default=yes ] authentication-types=wpa-psk,wpa2-psk mode=\
dynamic-keys supplicant-identity=MikroTik
/ip hotspot profile
add name=dhcp ranges=192.168.48.4-192.168.48.99
add add-arp=yes address-pool=dhcp always-broadcast=yes disabled=no interface=\
bridge name=defconf use-radius=accounting
add bridge=bridge comment=defconf interface=ether2PC
add bridge=bridge comment=defconf interface=2G
add bridge=bridge comment=defconf interface=5G
/interface list member
add comment=defconf interface=Net list=WAN
/interface wireless access-list
add authentication=no interface=2G mac-address=***.***.***.*** vlan-mode=\
no-tag
add address=192.168.48.1/24 comment=defconf interface=bridge network=\
192.168.48.0
/ip arp
add address=192.168.48.6 disabled=yes interface=bridge mac-address=\
add comment=defconf dhcp-options=hostname,clientid disabled=no interface=Net
/ip dhcp-server lease
add address=192.168.48.5 client-id=1:***.***.***.*** mac-address=\
***.***.***.*** server=defconf
add address=192.168.48.4 client-id=1:***.***.***.*** mac-address=\
add address=192.168.48.8 client-id=1:***.***.***.*** mac-address=\
add address=192.168.48.6 client-id=1:***.***.***.*** mac-address=\
add address=192.168.48.0/24 comment=defconf gateway=192.168.48.1 netmask=24
set allow-remote-requests=yes
/ip dns static
add address=192.168.48.1 name=router.lan
invalid
in-interface-list=!LAN
ipsec-policy=in,ipsec
ipsec-policy=out,ipsec
add action=drop chain=forward comment="defconf: drop invalid" connection-state=\
invalid
add action=masquerade chain=srcnat comment="defconf: masquerade" ipsec-policy=\
out,none out-interface-list=WAN
add action=dst-nat chain=dstnat dst-port=3389 in-interface=Net port="" \
protocol=tcp to-addresses=192.168.48.4 to-ports=3389
add action=dst-nat chain=dstnat dst-port=4321 in-interface=Net protocol=udp \
to-addresses=192.168.48.7 to-ports=9
add action=dst-nat chain=dstnat dst-address=***.***.***.*** dst-port=4949 \
in-interface=Net protocol=tcp to-addresses=192.168.48.4 to-ports=4949
add action=dst-nat chain=dstnat dst-address=***.***.***.*** dst-port=49152-65535 \
in-interface=Net port="" protocol=tcp to-addresses=192.168.48.4 to-ports=\
49152-65535
add action=dst-nat chain=dstnat dst-address=***.***.***.*** dst-port=8080 \
in-interface=Net protocol=tcp src-port="" to-addresses=192.168.48.14 \
to-ports=8080
/ip ssh
set allow-none-crypto=yes forwarding-enabled=remote
/ip upnp
set enabled=yes
/ip upnp interfaces
add interface=bridge type=internal
add interface=Net type=external
set time-zone-name=Asia/Novosibirsk
/tool bandwidth-server
set enabled=no
/tool mac-server
/tool mac-server mac-winbox
Никакик особенных настроек нету, только РДП до одного компа, стандартные настройки WiFi, но скорость падает также и по кабелю.
