Вот типичная картина через speedtest
PING ms - 1
UPLOAD Mbps - 86.56
DOWNLOAD Mbps -25.80
В чём может быть проблема и можно ли это исправить?
Ниже прикладываю конфигурацию
# model = 951Ui-2HnD
# serial number = ***
add admin-mac=********* auto-mac=no comment=defconf name=bridge
/interface pppoe-client
add add-default-route=yes disabled=no interface=ether1 name=pppoe-out1 \
password=****** use-peer-dns=yes user=*****
/interface l2tp-client
add add-default-route=yes connect-to=******* mrru=1600 name=\
vpn password=********* user=****
set [ find default-name=wlan1 ] band=2ghz-b/g/n channel-width=20/40mhz-Ce \
country=russia disabled=no distance=indoors mode=ap-bridge ssid=******* \
tx-power=12 tx-power-mode=all-rates-fixed wireless-protocol=802.11
/interface list
add comment=defconf name=WAN
add comment=defconf name=LAN
set [ find default=yes ] authentication-types=wpa-psk,wpa2-psk eap-methods="" \
group-key-update=59m mode=dynamic-keys supplicant-identity=MikroTik \
wpa-pre-shared-key=******* wpa2-pre-shared-key=******
add address-pool=dhcp disabled=no interface=bridge lease-time=4d3h10m name=\
defconf
/interface list member
add address=192.168.88.1/24 comment=defconf interface=ether2 network=\
192.168.88.0
add comment=defconf dhcp-options=hostname,clientid interface=ether1
set allow-remote-requests=yes servers=10.0.0.1,10.0.0.2
/ip dns static
add address=192.168.88.1 name=router.lan
ipsec-policy=in,ipsec
ipsec-policy=out,ipsec
established,related,untracked
connection-state=invalid
ipsec-policy=out,none out-interface=pppoe-out1
add action=masquerade chain=srcnat disabled=yes out-interface=vpn
add action=masquerade chain=srcnat dst-address=10.0.0.0/8 out-interface=\
ether1 out-interface-list=WAN
add action=masquerade chain=srcnat out-interface=pppoe-out1
add distance=1 dst-address=0.0.0.0/8 gateway=10.3.14.3
add distance=1 dst-address=10.0.0.0/8 gateway=10.3.14.3
/ip service
set telnet disabled=yes
set ftp disabled=yes
set www disabled=yes
set ssh disabled=yes
set api disabled=yes
set api-ssl disabled=yes
/ip upnp
set enabled=yes
/ip upnp interfaces
add interface=bridge type=internal
add interface=vpn type=external
add interface=pppoe-out1 type=external
/system ntp client
set enabled=yes primary-ntp=***** secondary-ntp=*******
/system package update
set channel=long-term
/tool mac-server
/tool mac-server mac-winbox
/interface list
defconf
192.168.88.0
/ip dns static
/ip service
/ip upnp
set enabled=yes
/ip upnp interfaces
/system ntp client
/tool mac-server
