Постоянно клиенты Wi-Fi теряют интернет 4G
trucker
Настройка предельно простая: внешний 4G-модем и Wi-Fi точка доступа. Клиенты переодически теряют интернет соединение, 4G-модем доступен по IP адресу. Для эксперимента разделил точки доступа 5GHz и 2.4GHz, так вот когда теряется соединение на 2.4 после переключения на 5 интернет продолжает работать. Помогите разобраться.
Прикрепляю конфиг:
[admin@MikroTik] > export
# jul/18/2019 19:33:49 by RouterOS 6.44.3
# software id = FER1-ZMV6
# model = RB952Ui-5ac2nD
# serial number = 9EXXXXXXXXXXX
/interface lte
set [ find ] mac-address=0C:XX:XX:XX:XX:XX name=lte1
add admin-mac=B8:XX:XX:XX:XX:XX auto-mac=no comment=defconf name=bridge
set [ find default-name=ether1 ] advertise=10M-half,10M-full,100M-half,100M-full,1000M-half,1000M-full
set [ find default-name=ether2 ] advertise=10M-half,10M-full,100M-half,100M-full,1000M-half,1000M-full name=ether2-master
set [ find default-name=ether3 ] advertise=10M-half,10M-full,100M-half,100M-full,1000M-half,1000M-full
set [ find default-name=ether4 ] advertise=10M-half,10M-full,100M-half,100M-full,1000M-half,1000M-full
set [ find default-name=ether5 ] advertise=10M-half,10M-full,100M-half,100M-full,1000M-half,1000M-full
set [ find default-name=wlan1 ] band=2ghz-b/g/n channel-width=20/40mhz-Ce country=russia disabled=no distance=indoors frequency=auto frequency-mode=regulatory-domain mode=\
    ap-bridge ssid=fssp wireless-protocol=802.11 wps-mode=disabled
set [ find default-name=wlan2 ] band=5ghz-a/n/ac channel-width=20/40/80mhz-Ceee country=russia disabled=no distance=indoors frequency=auto mode=ap-bridge ssid=fssp5 \
/interface list
add comment=defconf name=WAN
add comment=defconf name=LAN
set [ find default=yes ] authentication-types=wpa-psk,wpa2-psk mode=dynamic-keys supplicant-identity=MikroTik wpa-pre-shared-key=XXXXXXXXXXX wpa2-pre-shared-key=XXXXXXXXXXXX
/ip hotspot profile
add address-pool=dhcp disabled=no interface=bridge lease-time=10h name=defconf
add bridge=bridge comment=defconf interface=ether2-master
add bridge=bridge comment=defconf interface=wlan2
add bridge=bridge interface=ether3
add bridge=bridge interface=ether4
add bridge=bridge interface=ether5
set discover-interface-list=discover
/interface list member
add address=192.168.88.1/24 comment=defconf interface=ether2-master network=192.168.88.0
add address=192.168.1.0/24 comment=router2 disabled=yes interface=bridge network=192.168.1.0
add comment=defconf dhcp-options=hostname,clientid disabled=no interface=ether1
add dhcp-options=hostname,clientid disabled=no interface=lte1
set allow-remote-requests=yes servers=8.8.8.8,8.8.4.4
/ip dns static
add address=192.168.88.1 name=router.lan
add address=8.8.8.8 disabled=yes name=ggl
add action=accept chain=output comment="allow lan my, counting but not going thru\?" protocol=icmp
add action=drop chain=forward comment="defconf:  drop all from WAN not DSTNATed" connection-nat-state=!dstnat connection-state=new in-interface-list=WAN
add action=accept chain=input connection-state=established,related,untracked in-interface=lte1
add action=masquerade chain=srcnat comment="defconf: masquerade" disabled=yes ipsec-policy=out,none out-interface-list=WAN
add action=masquerade chain=srcnat out-interface=lte1
add action=accept chain=input disabled=yes in-interface=lte1
/ip firewall service-port
set ftp disabled=yes
set tftp disabled=yes
set irc disabled=yes
set h323 disabled=yes
set sip disabled=yes
set dccp disabled=yes
set sctp disabled=yes
/ip route rule
add action=lookup-only-in-table dst-address=192.168.88.0/24 table=main
add action=lookup-only-in-table dst-address=192.168.1.0/24 table=main
/ip service
set telnet disabled=yes
set www address=192.168.0.0/16
set ssh address=192.168.0.0/16
set api disabled=yes
set winbox disabled=yes
set api-ssl disabled=yes
/system package update
set channel=long-term
/tool bandwidth-server
set enabled=no
/tool mac-server
set allowed-interface-list=none
/tool mac-server mac-winbox
/tool mac-server ping
set enabled=no
Скан эфира на 2.4 сделайте и покажите
trucker
Ca6ko писал(а): 19 июл 2019, 09:54 Скан эфира на 2.4 сделайте и покажите
можете подсказать как это сделать?
Потом скрин сюда
trucker
на самом деле от Wi-Fi не отваливается, а именно теряет интернет и при переключении на вторую сеть всё нормально (т.е. дело не в 4G модеме).
