# Update 30.08.2018
/system logging action
set 1 disk-file-count=3
/system logging
set 0 action=memory prefix=INFO
set 1 action=memory prefix=ERR
set 2 action=disk prefix=WARN
set 3 action=memory prefix=CRIT
add action=memory prefix=SYN topics=async disabled=yes
:log warning "LOGGING_CHANGED"
:delay 3s
/system routerboard settings
set init-delay=5s
/system routerboard usb
set type=mini-PCIe
:log warning "MINI-PCI ACTIVATED"
:delay 1s
:log warning "SET INITIAL PARAMETER"
:global NUM 0
:global VER [:pick [/system resource get version] 0 4]
:global MODEL [:pick [/system routerboard get model] 0 3]
:global SERIAL [:pick [/system routerboard get serial-number] 7 12]
:log warning "SETTINGS_START_INSTALL"
/system identity
set name=GTX400-953FM2-WiFi
:set $NUM ($NUM+1)
:log warning "STEP_$"NUM"_COMPLETE"
:delay 1s
/interface ppp-client
remove [find name="ppp-out1"]
remove [find name="ppp-out2"]
:set $NUM ($NUM+1)
:delay 1s
/interface lte apn
set [find name="default"] default-route-distance=231
:set $NUM ($NUM+1)
:delay 1s
/interface lte
set [find name="lte1"] comment="WAN"
:set $NUM ($NUM+1)
:delay 1s
/interface list
add name=WAN
/interface list member
add interface=lte1 list=WAN
add interface=lte2 list=WAN
:set $NUM ($NUM+1)
:delay 1s
set [ find default-name=ether1 ] mtu=1500 name="LAN1-eth"
set [ find default-name=ether2 ] mtu=1500 name="LAN2-eth"
set [ find default-name=ether3 ] mtu=1500 name="LAN3-eth"
set [ find default-name=sfp1 ] mtu=1500 name="LAN4-sfp"
set [ find default-name=sfp2 ] mtu=1500 name="LAN5-sfp"
:set $NUM ($NUM+1)
:delay 1s
add name=teleofis authentication-types=wpa2-psk eap-methods="" group-ciphers=aes-ccm \
management-protection=allowed mode=dynamic-keys \
supplicant-identity=TELEOFIS unicast-ciphers=aes-ccm \
wpa2-pre-shared-key=11122233344455566677788899
:set $NUM ($NUM+1)
:delay 2s
set [ find default-name=wlan1 ] name="LAN6-wifi5ghz" antenna-gain=1 band=5ghz-a/n channel-width=\
20/40mhz-Ce disabled=no distance=indoors frequency=auto guard-interval=long \
hw-protection-mode=rts-cts mode=ap-bridge multicast-helper=full frequency-mode=regulatory-domain \
rx-chains=0,1,2 security-profile=teleofis ssid=GTX400-5GHz tx-chains=0,1,2 country=russia \
tx-power-mode=default wireless-protocol=802.11 radio-name="GTX400953BM2$"SERIAL"" \
wps-mode=disabled mtu=1500 wmm-support=enabled adaptive-noise-immunity=ap-and-client-mode
/interface wireless nstreme
set [find name="LAN6-wifi5ghz"] enable-polling=no
:set $NUM ($NUM+1)
:delay 5s
add action=masquerade chain=srcnat comment="LAN to WAN" out-interface-list=WAN src-address=192.168.88.0/24
:set $NUM ($NUM+1)
:delay 1s
add comment="LAN" name="LAN-Bridge" mtu=1500
:set $NUM ($NUM+1)
:delay 1s
add bridge="LAN-Bridge" comment="LAN" interface="LAN1-eth"
add bridge="LAN-Bridge" interface="LAN2-eth"
add bridge="LAN-Bridge" interface="LAN3-eth"
add bridge="LAN-Bridge" interface="LAN4-sfp"
add bridge="LAN-Bridge" interface="LAN5-sfp"
add bridge="LAN-Bridge" interface="LAN6-wifi5ghz"
:set $NUM ($NUM+1)
:delay 1s
/interface list
add name=LAN
add interface="LAN-Bridge" list=LAN comment="LAN"
add interface="LAN1-eth" list=LAN
add interface="LAN2-eth" list=LAN
add interface="LAN3-eth" list=LAN
add interface="LAN4-sfp" list=LAN
add interface="LAN5-sfp" list=LAN
add interface="LAN6-wifi5ghz" list=LAN
:set $NUM ($NUM+1)
:delay 1s
:set $NUM ($NUM+1)
:delay 1s
set allow-remote-requests=yes
:set $NUM ($NUM+1)
:delay 1s
add action=accept chain=input in-interface-list=WAN protocol=udp src-port=53
add action=drop chain=input dst-port=53 in-interface-list=!LAN protocol=udp
:set $NUM ($NUM+1)
:delay 1s
/ip firewall mangle
add action=mark-connection chain=prerouting comment="PREROUTING LAN" dst-address-type=!local in-interface=LAN-Bridge new-connection-mark=lte-out1-in-conn passthrough=yes per-connection-classifier=both-addresses:2/0
add action=mark-routing chain=prerouting connection-mark=lte-out1-in-conn dst-address-type=!local new-routing-mark=lte-out1-out-route passthrough=no
add action=mark-connection chain=prerouting dst-address-type=!local in-interface=LAN-Bridge new-connection-mark=lte-out2-in-conn passthrough=yes per-connection-classifier=both-addresses:2/1
add action=mark-routing chain=prerouting connection-mark=lte-out2-in-conn dst-address-type=!local new-routing-mark=lte-out2-out-route passthrough=no
add action=mark-connection chain=prerouting comment="PREROUTING WAN / OUTPUT WAN" in-interface=lte1 new-connection-mark=lte-out1-in-conn connection-state=new passthrough=yes
add action=mark-routing chain=output connection-mark=lte-out1-in-conn new-routing-mark=lte-out1-out-route passthrough=no
add action=mark-connection chain=prerouting in-interface=lte2 new-connection-mark=lte-out2-in-conn connection-state=new passthrough=yes
add action=mark-routing chain=output connection-mark=lte-out2-in-conn new-routing-mark=lte-out2-out-route passthrough=no
:set $NUM ($NUM+1)
:delay 1s
add distance=1 gateway=lte1 routing-mark=lte-out1-out-route
add distance=2 gateway=lte2 routing-mark=lte-out1-out-route
add distance=1 gateway=lte2 routing-mark=lte-out2-out-route
add distance=2 gateway=lte1 routing-mark=lte-out2-out-route
:set $NUM ($NUM+1)
:delay 1s
set time-zone-autodetect=no time-zone-name=Europe/Moscow
:set $NUM ($NUM+1)
:delay 1s
/ip cloud
set update-time=no
:set $NUM ($NUM+1)
:delay 1s
/system ntp client
set enabled=yes server-dns-names=\
ntp4.stratum2.ru,ntp3.stratum2.ru,ntp5.stratum1.ru,timeserver.ru
:set $NUM ($NUM+1)
:delay 1s
/system note
set note="\
\n TTTTTTTT EEEEEE LL EEEEEE OOOO FFFFFF IIII SSSSS\
\n TT EE LL EE OO OO FF II SS\
\n TT EEEEEE LL EEEEEE OO OO FFFFFF II SSSSS\
\n TT EEEEEE LLLLLL EEEEEE OOOO FF IIII SSSSS\
\n\
\n Teleofis for MikroTik RouterOS $"VER" (c) 2004-2018
http://teleofis.ru/\
\n DO NOT UPDATE FIRMWARE:\
\n Stable operation of modules only on firmware $"VER"\
\n\
\n"
:set $NUM ($NUM+1)
:delay 1s
/system scheduler
add comment="TELEOFIS Scripts" interval=15m name=watchdog on-event="# Script W\
atchdog\r\
\n# Connection validation script\r\
\n# Company developer: TELEOFIS (tm) [
https://teleofis.ru/]\r\
\n#\r\
\n\r\
\n# Update IP addresses\r\
\n:do {:set \$IP1 [:resolve yandex.ru]} on-error={:set \$IP1 77.88.8.8}\r\
\n:do {:set \$IP2 [:resolve google.com]} on-error={:set \$IP2 8.8.8.8}\r\
\n\r\
\n# Init variables\r\
\n:global IFACE1\r\
\n:global IFACE2\r\
\n:global IP1\r\
\n:global IP2\r\
\n:global ITER1 0\r\
\n:global ITER2 0\r\
\n:global PINGA1\r\
\n:global PINGA2\r\
\n:global PINGB1\r\
\n:global PINGB2\r\
\n:global ACTIFACE1\r\
\n:global ACTIFACE2\r\
\n\r\
\n:set \$IFACE1 [:tostr [/interface lte get 0 name]]\r\
\n:set \$IFACE2 [:tostr [/interface lte get 1 name]]\r\
\n\r\
\n# Start while checking\r\
\n:while (true) do={\r\
\n \r\
\n # Check modems in ports\r\
\n :if ([/system resource usb print count-only where vendor!=\"Linux 3.3\
.5 ehci_hcd\"] != 2) do={\r\
\n :log error \"watchdog: not found one or more mini-PCIe modems\"\r\
\n /system reboot\r\
\n :delay 1s\r\
\n }\r\
\n \r\
\n # Check act LTE1\r\
\n :if ([/interface lte print count-only where name=\"lte1\" disabled=ye\
s] = 1) do={\r\
\n :log warning \"watchdog: \$\"IFACE1\" the interface is turned off.\
\_Turn on the interface.\"\r\
\n /interface enable \$IFACE1\r\
\n :delay 15s\r\
\n }\r\
\n # Check act LTE2\r\
\n :if ([/interface lte print count-only where name=\"lte2\" disabled=ye\
s] = 1) do={\r\
\n :log warning \"watchdog: \$\"IFACE2\" the interface is turned off.\
\n /interface enable \$IFACE2\r\
\n :delay 15s\r\
\n }\r\
\n \r\
\n # Check ping first interface\r\
\n :set \$PINGA1 [ /ping count=10 interface=\$IFACE1 address=\$IP1 ]\r\
\n :if ( \$PINGA1 > 0 ) do={\r\
\n :log debug \"watchdog: PINGA1 \$\"IFACE1\" - ok\"\r\
\n :log debug \"watchdog: PINGA1 count = \$\"PINGA1\"\"\r\
\n :set \$ACTIFACE1 true\r\
\n :set \$ITER1 0\r\
\n } else={\r\
\n :log warning \"watchdog: PINGA1 \$\"IFACE1\" - no ping\"\r\
\n :set \$ACTIFACE1 false\r\
\n }\r\
\n :if ( \$ACTIFACE1 != true ) do={\r\
\n :set \$PINGA2 [ /ping count=10 interface=\$IFACE1 address=\$IP2 ]\
\r\
\n :if ( \$PINGA2 > 0 ) do={\r\
\n :log debug \"watchdog: PINGA2 \$\"IFACE1\" - ok\"\r\
\n :log debug \"watchdog: PINGA2 count = \$\"PINGA2\"\"\r\
\n } else={\r\
\n :log warning \"watchdog: PINGA2 \$\"IFACE1\" - no ping\"\r\
\n }\r\
\n }\r\
\n \r\
\n # Check ping two interface\r\
\n :set \$PINGB1 [ /ping count=10 interface=\$IFACE2 address=\$IP1 ]\r\
\n :if ( \$PINGB1 > 0 ) do={\r\
\n :log debug \"watchdog: PINGB1 \$\"IFACE2\" - ok\"\r\
\n :log debug \"watchdog: PINGB1 count = \$\"PINGB1\"\"\r\
\n :set \$ACTIFACE2 true\r\
\n :set \$ITER2 0\r\
\n } else={\r\
\n :log warning \"watchdog: PINGB1 \$\"IFACE2\" - no ping\"\r\
\n :set \$ACTIFACE2 false\r\
\n }\r\
\n :if ( \$ACTIFACE2 != true ) do={\r\
\n :set \$PINGB2 [ /ping count=10 interface=\$IFACE2 address=\$IP2 ]\
\r\
\n :if ( \$PINGB2 > 0 ) do={\r\
\n :log debug \"watchdog: PINGB2 \$\"IFACE2\" - ok\"\r\
\n :log debug \"watchdog: PINGB2 count = \$\"PINGB2\"\"\r\
\n } else={\r\
\n :log warning \"watchdog: PINGB2 \$\"IFACE2\" - no ping\"\r\
\n }\r\
\n }\r\
\n \r\
\n # All is good. Exit from while\r\
\n :if ( (\$ACTIFACE1 = true) && (\$ACTIFACE2 = true) ) do={\r\
\n :log info \"watchdog: Watchdog OK\"\r\
\n :quit;\r\
\n }\r\
\n \r\
\n # Next...\r\
\n # Check Iteration\r\
\n :if ( (\$ACTIFACE1 != true) && (\$ACTIFACE2 != true) && (\$ITER1 >= 2\
) && (\$ITER2 >= 2) ) do={\r\
\n :log error \"watchdog: No ping - connection down - Reboot!!!\"\r\
\n :delay 120s\r\
\n }\r\
\n \r\
\n # First interface work, but no internet\r\
\n :if ( (\$ACTIFACE1 = false) && (\$ITER1 < 2)) do={\r\
\n :log warning \"watchdog: Reconnect \$\"IFACE1\" interface\"\r\
\n /interface disable \$IFACE1\r\
\n :delay 15s\r\
\n :set \$ITER1 (\$ITER1+1)\r\
\n :log warning \"watchdog: Reconnect \$\"IFACE1\" interface complet\
e\"\r\
\n }\r\
\n :if (\$ITER1 >= 2) do={\r\
\n :log warning \"watchdog: No ping interface \$\"IFACE1\" - Resettin\
g modem\"\r\
\n /system routerboard usb power-reset bus=1 duration=10\r\
\n :delay 30s\r\
\n :quit;\r\
\n }\r\
\n \r\
\n # Two interface work, but no internet\r\
\n :if ( (\$ACTIFACE2 = false) && (\$ITER2 < 2)) do={\r\
\n :log warning \"watchdog: Reconnect \$\"IFACE2\" interface\"\r\
\n /interface disable \$IFACE2\r\
\n :delay 15s\r\
\n :set \$ITER2 (\$ITER2+1)\r\
\n :log warning \"watchdog: Reconnect \$\"IFACE2\" interface - compl\
ete\"\r\
\n }\r\
\n :if (\$ITER2 >= 2) do={\r\
\n :log warning \"watchdog: No ping interface \$\"IFACE2\" - Resettin\
g modem\"\r\
\n /system routerboard usb power-reset bus=2 duration=10\r\
\n :delay 30s\r\
\n :quit;\r\
\n }\r\
\n}\r\
\n\r\
\n# END" policy=\
ftp,reboot,read,write,policy,test,password,sniff,sensitive start-time=\
startup
add name=init on-event="# Script Init\r\
\n# Initialisation variables\r\
\n#\r\
\n\r\
\n:delay 20s\r\
\n\r\
\n# Variables\r\
\n:global PINGA1 0\r\
\n:global PINGA2 0\r\
\n:global PINGB1 0\r\
\n:global PINGB2 0\r\
\n:global ACTIFACE1 false\r\
\n:global ACTIFACE2 false\r\
\n:global IFACE1 [:tostr [/interface lte get 0 name]]\r\
\n:global IFACE2 [:tostr [/interface lte get 1 name]]\r\
\n\r\
\n\r\
\n# END" policy=\
startup
add interval=1m name=lte_signal_changer on-event="# Script LTE Signal\r\
\n# Changer Lte signal for lte interfaces\r\
\n# Developer company: TELEOFIS (tm) (
https://teleofis.ru)\r\
\n#\r\
\n\r\
\n# Find LED LTE\r\
\n:if ([/system leds print count-only where type=modem-signal] < 1) do={\r\
\n :log warning \"lte_signal_changer: LTE LED not found...\"\r\
\n :quit;\r\
\n}\r\
\n\r\
\n# Init LTE Interface\r\
\n:local INT1 [/interface lte get 0 name]\r\
\n:local INT2 [/interface lte get 1 name]\r\
\n:local INTNOW [/system leds get [find type=modem-signal] interface]\r\
\n\r\
\n:if ([/interface lte get \$INT1 running] = true and [/interface lte get \
\$INT2 running] = true) do={\r\
\n :if (\$INTNOW = \$INT1) do={\r\
\n #:log info \"lte_signal_changer: Change to \$\"INT2\"\"\r\
\n /system leds set [find type=modem-signal] interface=\$INT2\r\
\n } else={\r\
\n #:log info \"lte_signal_changer: Change to \$\"INT1\"\"\r\
\n /system leds set [find type=modem-signal] interface=\$INT1\r\
\n }\r\
\n} else={\r\
\n :if ([/interface lte get \$INT1 running] = true and [/interface lte g\
et \$INT2 running] = false) do={\r\
\n }\r\
\n :if ([/interface lte get \$INT2 running] = true and [/interface lte g\
et \$INT1 running] = false) do={\r\
\n }\r\
\n}" policy=\
ftp,reboot,read,write,policy,test,password,sniff,sensitive,romon \
start-time=startup
:set $NUM ($NUM+1)
:delay 5s
:global LEDSTATUS [/system leds find disabled=no]
:if ($LEDSTATUS != "") do={
/system leds
set 0 interface="LAN-Bridge" leds=user-led type=interface-transmit
add interface=lte1 leds=led1,led2,led3,led4,led5 modem-signal-treshold=-105 type=modem-signa
} else={
/system leds
add interface="LAN-Bridge" leds=user-led type=interface-transmit
:set $NUM ($NUM+1)
:delay 1s
add name=dhcp-pool1 ranges=192.168.88.10-192.168.88.250
:set $NUM ($NUM+1)
:delay 1s
add address=192.168.88.0/24 comment="For Local Bridge" dns-server=192.168.88.1 gateway=192.168.88.1 netmask=24
:set $NUM ($NUM+1)
:delay 1s
add add-arp=yes address-pool=dhcp-pool1 bootp-lease-time=lease-time bootp-support=dynamic disabled=no interface="LAN-Bridge" lease-time=3d name=dhcp-server1
:set $NUM ($NUM+1)
:delay 1s
add address=192.168.88.1/24 comment="Local Bridge" interface="LAN-Bridge" network=192.168.88.0
:set $NUM ($NUM+1)
:delay 1s
#:global GPSSTATUS [/system package find name="gps"]
#:if ($GPSSTATUS != "") do={
# :log warning "GPS_ENABLE"
# /system gps
# set channel=0 enabled=yes port=usb3 set-system-time=no
# :set $NUM ($NUM+1)
# :log warning "STEP_$"NUM"_COMPLETE"
# :delay 1s
#} else={
# :log warning "GPS_NOT_USED"
# :delay 1s
/system backup
save name="initial_gtx400wf_$"MODEL"fm2_$"VER""
:log warning "CREATED_BACKUP_FILE_initial_gtx400wf_$"MODEL"fm2_$"VER"";
:set $NUM ($NUM+1)
:delay 1s
/file
remove [ find type="directory" ]
remove [ find type="package" ]
remove [ find type=".fwf file" ]
remove [ find type=".rif file" ]
remove [ find type="web-proxy store" ]
:set $NUM ($NUM+1)
:delay 1s
/system routerboard upgrade
:delay 0s
:set $NUM ($NUM+1)
:delay 1s
:log warning "SETTINGS_INSTALL_END"
:log warning "REBOOT"
/system reboot
:delay 0s
