Скрипт оповещения в телеграмм
Здесь выкладываем скрипты
Virtue
Кому нужно, выкладываю обновленный скрипт. Переписал его с нуля. Выкинул все лишнее.. за исключением если кому не надо отслеживать вайфай - сотрите topics~"wireless" ||
# BEGIN SETUP
:local scheduleName "LogMikrotik"
:local bot "BOT TELEGRAM ANDA"
:local ChatID "CHAT ID ANDA"
:local startBuf [:toarray [/log find message~"logged in" || topics~"wireless" || topics~"error" || topics~"warning" || topics~"critical"]]
:local removeThese {"telnet"}
:local TimeOFF [:toarray ("00:00","03:00")]
# END SETUP
if ([:len [/system scheduler find name="$scheduleName"]] = 0) do={
/log warning "[LOGMON] ERROR: Schedule does not exist. Create schedule and edit script to match name"
:local name [/system  identity  get name]
:local TimeNow [:pick [/system clock get time] 0 5]
:local lastTime [/system scheduler get [find name="$scheduleName"] comment]
:local currentTime
:local message
:local output
:local keepOutput false
:local logTrue
if ([:len $lastTime] = 0) do={
:set keepOutput true
:foreach i in=$startBuf do={
  :local var true
  :foreach j in=$removeThese do={
    if ([/log get $i message] ~ $j) do={
      :set var false
  if ($var=true) do={:set logTrue ($logTrue, $i)}
:foreach l in=$logTrue do={
  :set currentTime [ /log get $l time ]
  if ([:len $currentTime] = 8 ) do={
    :set currentTime ([:pick [/system clock get date] 0 11]." ".$currentTime)
    } else={
    if ([:len $currentTime] = 15 ) do={
      :set currentTime ([:pick $currentTime 0 6]."/".[:pick [/system clock get date] 7 11]." ".[:pick $currentTime 7 15])
  if ($keepOutput=true) do={
    :set message [/log get $l message]
    if ([/log get $l message] ~ "[0-F][0-F]:[0-F][0-F]:[0-F][0-F]:[0-F][0-F]:[0-F][0-F]:[0-F][0-F]") do={
      :foreach k in=[/ip dhcp-server lease find] do={
        :local mac [/ip dhcp-server lease get $k value-name=mac-address]
        if ([/log get $l message] ~ "$mac") do={
          :set message ($message . " / " . [/ip dhcp-server lease get $k value-name=comment])
  :set output ($output.$currentTime." ".$message."%0A%0A")
    } else={
    if ($currentTime = $lastTime) do={
if (([:len $output] > 0) and ($TimeOFF ~ $TimeNow)) do={
  /system scheduler set [find name="$scheduleName"] comment=$currentTime
  } else={
  if (([:len $output] > 0) and ($currentTime != $lastTime)) do={
    /tool fetch url="https://api.telegram.org/bot$bot/sendmessage?chat_id=$ChatID&text= $name : %0A$output" keep-result=no;
    } else={
    if (([:len $message] > 0) and ($currentTime != $lastTime)) do={
denis.korsachv
Интересно только у меня у одного прыгает загрузка процессора от этого скрипта или это нормально? RB2011 загрузка скачет от 2% до 50%
hulitolku
РКН отменил блокировку, теперь можно не использовать соксы.
Как тренировка, сойдёт. Сегодня отменили, завтра опять начнут блокировать. Это просто заигрывания. Мы должны быть просто в курсе, как сделать.
pavel.komissarov
Добрый день. Подскажите, возникла проблема с отправкой в сообщении телеграм русских символов. Не знает-ли кто как решить это?
Sertik
Нужно перекодировать символы в UTF8
viewtopic.php?f=14&t=13947
pavel.komissarov
Не подскажете команду, которой перекодировать? я не смог найти...
Русские буквы имеются в названиях интерфейсов, которые и хочется отправлять в телеграм.
Да там не команда будет, а целый скрипт. Из-за мелкой хотелки я бы не стал заморачиваться с этим. Вон в соседней теме посмотрите пример перекодировки viewtopic.php?f=14&t=11655 Оно вам надо? Вы готовы переписать всё под себя?
pavel.komissarov
спасибо
Sertik
Чтобы перекодировать кириллицу и спец. симфолы для телеграмма Можно сделать проще чем у Pepelx. Сделаю, сообщу.
