Скрипт блокировки ip-адресов, с которых пытаются подобрать пользователей роутера
Здесь выкладываем скрипты
drpioneer
Приветствую всех!
Представляю обновленную версию скрипта блокировки недоброжелателей:
# Script for searching and blocking dangerous addresses
# Script uses ideas by podarok66, evgeniy.demin, Virtue, tgrba, denismikh, MMAXSIM, andrey-d, GregoryGost, Chupaka, Jotne, drPioneer.
# https://forummikrotik.ru/viewtopic.php?p=84017#p84017
# https://github.com/drpioneer/MikrotikBlockDangerAddresses
# tested on ROS 6.49.10
# updated 2023/10/23
:global scriptBlckr;                # flag of the running script(false=>in progress, true=>idle)
:do {
    :local timeoutBL     "8h";      # timeout of blacklist
    :local inIfaceList   "";        # name of input interface list: "internet","WAN",etc=>manual input value; ""=automatic value selection
    :local firewallUsage false;     # checking & installing firewall rules
    :local extremeScan   false;     # setting log scan level: false=>usual option; true=>extremal option
    :local logEntry      false;     # maintaining log entries
    :local staticAddrLst false;     # converting blacklist from dynamic to static
    :local nameBlackList "BlockDangerAddress";           # name of blacklist
    :local nameWhiteList "WhiteList";                    # name of whitelist
    :local commentRuleBL "dropping dangerous addresses"; # comment for blacklist rule
    :local commentRuleWL "white List of IP-addresses";   # comment for whitelist rule
    # function of verifying correctness IP-address v.4 & blacklisting it
    :local DangerIPAddr do={
        :if ($1~"[0-9]{1,3}.[0-9]{1,3}.[0-9]{1,3}.[0-9]{1,3}") do={
            :if ([/ip firewall address-list find address=$1 list=$2]="") do={
                /ip firewall address-list add address=$1 list=$2 timeout=$3;
                :put "$[/system clock get time]\tAdded in BlackList IP-address: $1";
                :if ($4) do={:log warning ">>> Added in BlackList IP: $1"}
                :return true;
        :return false;
    # function of converting decimal numbers to hexadecimal
    :local DecToHex do={
        :if ($1<10) do={:return "*$1"}
        :local tempNumber $1;
        :local result "";
        :local remainder 0;
        :local hexTable [:toarray "0,1,2,3,4,5,6,7,8,9,A,B,C,D,E,F"];
        :while ($tempNumber>0) do={
            :set remainder ($tempNumber%16);
            :set tempNumber [:tonum ($tempNumber>>4)];
            :set result (($hexTable->$remainder).$result);
        :return "*$result";
    # string parsing function
    :local StrParser do={
        :if ([:len [:find $1 $2 -1]]=0) do={:return ""}
        :local startPos ([:find $1 $2 -1]+[:len $2] +1);
        :local stopPos 0;
        :set $stopPos [:find $1 "\"" $startPos];
        :if ($stopPos<$startPos) do={:set stopPos ($startPos+1)}
        :return [:pick $1 $startPos $stopPos];
    # gateway interface-list search function
    :local IfListGWFinder do={
        :local inetGate [/ip route find dst-address=0.0.0.0/0 active=yes];
        :if ($inetGate="") do={:return ""}
        :local gwInface [/ip route get $inetGate vrf-interface];
        :local brdgName [/interface bridge find name=$gwInface];
        :if ([:len $gwInface]>0 && [:len $brdgName]>0) do={
            :local ipAddrGt [/ip route get $inetGate gateway];
            :local macAddrGt [/ip arp get [find address=$ipAddrGt interface=$gwInface] mac-address];
            :set gwInface [/interface bridge host get [find mac-address=$macAddrGt] interface];
        :foreach ifList in=[/interface list member find interface=$gwInface] do={:return [/interface list member get $ifList list]}
    # main body of the script
    :put "$[/system clock get time]\tStart of searching dangerous addresses on '$[/system identity get name]' router";
    :if ([:len $scriptBlckr]=0) do={:set scriptBlckr true}
    :if ($scriptBlckr) do={
        :set scriptBlckr false;
        :if ($extremeScan) do={:put "$[/system clock get time]\tBE CAREFUL!!!!!! Extreme scanning mode is ENABLED!"}
        :set $timeoutBL [:totime $timeoutBL];
        # ----------- checking & installing firewall rules -----------
        :if ($inIfaceList="") do={:set inIfaceList [$IfListGWFinder]; :put "$[/system clock get time]\tVariable 'inIfaceList' is empty -> so value '$inIfaceList' is automatically assigned"}
        :if ([:len [/interface list find name=$inIfaceList]]!=0) do={
            # ----------- checking & installing optional firewall rules -----------
            :if ($firewallUsage) do={
                :local cmmnt "";
                /ip firewall layer7-protocol;
                find;
                :local fireL7prot [:toarray {
                    "name=CVE-2023-28771 comment=\"IPsec payload missing: SA\" regexp=\";bash -c \\\"curl [0-9]+\\\\.[0-9]+\\\\.[0-9]+\\\\.[0-9]\"";
                :foreach payLoad in=$fireL7prot do={
                    :set $cmmnt [$StrParser [:tostr $payLoad] "comment="];
                    :if ([:len [/ip firewall layer7-protocol find comment=$cmmnt]]=0) do={
                        :put "$[/system clock get time]\tFirewall layer7 protocol with comment '$cmmnt' not found. Added a regular expression";
                        [:parse "/ip firewall layer7-protocol add $payLoad"];
                /ip firewall filter;
                find;
                :local firewallFilterRules [:toarray {
                    "action=accept chain=input comment=\"defconf: accept established,related,untracked\" connection-state=established,related,untracked";
                    "action=drop chain=input comment=\"defconf: drop invalid\" connection-state=invalid";
                    "action=accept chain=input comment=\"accept ICMP from external interface\" in-interface-list=$inIfaceList limit=50/5s,2:packet protocol=icmp";
                    "action=accept chain=input comment=\"defconf: accept ICMP\" disabled=yes protocol=icmp";
                    "action=accept chain=input comment=\"defconf: accept to local loopback (for CAPsMAN)\" dst-address=127.0.0.1";
                    "action=accept chain=forward comment=\"defconf: accept in ipsec policy\" ipsec-policy=in,ipsec";
                    "action=accept chain=forward comment=\"defconf: accept out ipsec policy\" ipsec-policy=out,ipsec";
                    "action=fasttrack-connection chain=forward comment=\"defconf: fasttrack\" connection-state=established,related";
                    "action=accept chain=forward comment=\"defconf: accept established,related, untracked\" connection-state=established,related,untracked";
                    "action=drop chain=forward comment=\"defconf: drop invalid\" connection-state=invalid";
                    "action=drop chain=forward comment=\"defconf: drop all from WAN not DSTNATed\" connection-nat-state=!dstnat connection-state=new in-interface-list=$inIfaceList";
                    "action=jump chain=input comment=\"packet analysis for attacks\" in-interface-list=$inIfaceList jump-target=TARPIT protocol=tcp src-address-list=$nameBlackList";
                    "action=tarpit chain=TARPIT comment=\"slow down attack to router\" limit=10,10:packet protocol=tcp";
                    "action=drop chain=TARPIT comment=\"drop rest of TCP attack\" protocol=tcp";
                    "action=drop chain=input comment=\"drop CVE-2023-28771\" connection-state=\"\" dst-port=500 in-interface-list=$inIfaceList layer7-protocol=CVE-2023-28771 protocol=udp";
                    "chain=input comment=\"allow DNS request\" in-interface-list=$inIfaceList protocol=udp src-port=53";
                    "action=accept chain=input comment=\"accept L2TP/IPSec connections\" connection-state=\"\" dst-port=500,1701,4500 in-interface-list=$inIfaceList protocol=udp";
                    "action=accept chain=input comment=\"accept IPSec-esp connections\" connection-state=\"\" in-interface-list=$inIfaceList protocol=ipsec-esp";
                    "action=accept chain=input comment=\"accept IPSec-ah connections\" connection-state=\"\" in-interface-list=$inIfaceList protocol=ipsec-ah";
                    "action=accept chain=input comment=\"accept SSTP connections\" dst-port=443 in-interface-list=$inIfaceList protocol=tcp";
                    "action=accept chain=input comment=\"accept PPTP TCP connections\" connection-state=\"\" dst-port=1723 in-interface-list=$inIfaceList protocol=tcp";
                    "action=accept chain=input comment=\"accept PPTP GRE connections\" connection-state=\"\" in-interface-list=$inIfaceList protocol=gre";
                    "action=accept chain=input comment=\"accept OVPN connections\" connection-state=\"\" disabled=yes dst-port=1194 in-interface-list=$inIfaceList protocol=tcp";
                    "action=accept chain=forward comment=\"accept SIP UDP packets\" disabled=yes dst-port=5060-5061,5160-5161,10000-20000 in-interface-list=$inIfaceList protocol=udp";
                    "action=accept chain=forward comment=\"accept SIP TCP packets\" disabled=yes dst-port=5060-5061,5160-5161,10000-20000 in-interface-list=$inIfaceList protocol=tcp";
                    "action=accept chain=input comment=\"accept to Minecraft server\" disabled=yes dst-port=25565-25566 in-interface-list=$inIfaceList protocol=tcp";
                    "action=jump chain=input comment=\"brute force protection on specified ports\" connection-state=new dst-port=8291 in-interface-list=$inIfaceList jump-target=BruteForce protocol=tcp";
                    "action=return chain=BruteForce comment=\"packet analysis for brute force on the specified ports\" dst-limit=4/1m,1,src-address/1m40s";
                    "action=add-src-to-address-list chain=BruteForce comment=\"add to BlackList attacker who used specified ports\" address-list=$nameBlackList address-list-timeout=$timeoutBL";
                    "action=accept chain=input comment=\"accept WinBox\" dst-port=8291 protocol=tcp in-interface-list=$inIfaceList";
                    "action=add-src-to-address-list chain=input comment=\"add to BlackList attacker who used unopened ports\" address-list=$nameBlackList address-list-timeout=$timeoutBL dst-address-type=!broadcast in-interface-list=$inIfaceList";
                    "action=drop chain=input comment=\"drop rest of packets\" in-interface-list=$inIfaceList";
                :foreach payLoad in=$firewallFilterRules do={
                    :if ([:len [/ip firewall filter find comment=$cmmnt]]=0) do={
                        :put "$[/system clock get time]\tFirewall filter rule with comment '$cmmnt' not found. Added a missing rule";
                        [:parse "/ip firewall filter add $payLoad"];
                /ip firewall raw;
                find;
                :local firewallRawRules [:toarray {
                    "action=drop chain=prerouting comment=\"drop NetBIOS parasit traffic\" dst-port=137,138,139 protocol=udp in-interface-list=$inIfaceList";
                    "action=drop chain=prerouting comment=\"drop DNS parasit traffic\" dst-port=53 protocol=udp in-interface-list=$inIfaceList";
                :foreach payLoad in=$firewallRawRules do={
                    :if ([:len [/ip firewall raw find comment=$cmmnt]]=0) do={
                        :put "$[/system clock get time]\tFirewall raw rule with comment '$cmmnt' not found. Added a missing rule";
                        [:parse "/ip firewall raw add $payLoad"];
            } else={:put "$[/system clock get time]\tATTENTION!!! Firewall rule checking is DISABLED (firewallUsage = false). Recommended to ENABLE (firewallUsage = true)"}
            # ----------- checking & installing mandatory firewall rules -----------
            :local ruleID "";
            :if ([/ip firewall address-list find list=$nameWhiteList]="") do={/ip firewall address-list add address="input_your_address" list=$nameWhiteList}
            :local firewallFlt [find];
            :if ([:len $firewallFlt]=0) do={
                add chain=input comment=$commentRuleWL src-address-list=$nameWhiteList disabled=no;
            } else={
                :if ([find src-address-list=$nameWhiteList]="") do={
                    :if ([find action~"passthrough" dynamic=yes]="") do={
                        add chain=input comment=$commentRuleWL src-address-list=$nameWhiteList disabled=no place-before=($firewallFlt->0);
                    } else={
                        :set ruleID [$StrParser [:tostr [get [find action~"passthrough" dynamic=yes]]] ".nextid"];
                        :if ($ruleID!="") do={add chain=input comment=$commentRuleWL src-address-list=$nameWhiteList disabled=no place-before=$ruleID}
            :if ([find src-address-list=$nameWhiteList disabled=yes]!="") do={enable [find src-address-list=$nameWhiteList disabled=yes]}
            /ip firewall raw;
            :local firewallRaw [find];
            :if ([:len $firewallRaw]=0) do={
                add action=accept chain=prerouting comment=$commentRuleWL src-address-list=$nameWhiteList disabled=no;
            } else={
                        add action=accept chain=prerouting comment=$commentRuleWL src-address-list=$nameWhiteList disabled=no place-before=($firewallRaw->0);
                    } else={
                        :if ($ruleID!="") do={add action=accept chain=prerouting comment=$commentRuleWL src-address-list=$nameWhiteList disabled=no place-before=$ruleID}
            :if ([find src-address-list=$nameBlackList]="") do={add action=drop chain=prerouting comment=$commentRuleBL src-address-list=$nameBlackList in-interface-list=$inIfaceList protocol=!tcp disabled=yes}
            :if ([find src-address-list=$nameBlackList disabled=yes]!="") do={
                :put "$[/system clock get time]\tATTENTION!!! RAW-rule for blocking dangerous IP-addresses is DISABLED. Check rule properties in 'IP-Firewall-Raw'";
                :log warning "ATTENTION!!! Rule for blocking dangerous IP-addresses is DISABLED.";
                :log warning "Check rule properties in 'IP-Firewall-Raw'.";
        } else={:put "$[/system clock get time]\tATTENTION!!! Not found input list interfaces named '$inIfaceList'. Check it 'Interfaces-Interface List'. Protection does not work!!!"}
        #----------- stage of searching for failed login attempts -----------
        :local isDetected false;
        :foreach dangerString in=[:log find topics~"system" message~"login failure for user"] do={
            :local stringTemp [:log get $dangerString message];
            :local dangerIP [:pick $stringTemp ([:find $stringTemp "from"] +5) ([:find $stringTemp "via"] -1)];
            :if [$DangerIPAddr $dangerIP $nameBlackList $timeoutBL $logEntry] do={:set $isDetected true}
        #----------- stage of searching for login attempts from unknown networks  -----------
        :foreach dangerString in=[:log find topics~"warning" message~"denied winbox/dude connect from"] do={
            :local dangerIP [:pick $stringTemp ([:find $stringTemp "from"] +5) ([:len $stringTemp])];
        #----------- stage of searching for attempts to enter through an IPsec password -----------
        :foreach dangerString in=[:log find topics~"ipsec" message~"parsing packet failed, possible cause: wrong password"] do={
            :local dangerIP [:pick $stringTemp 0 ([:find $stringTemp "parsing"] -1)];
        #----------- stage of searching for attempts to enter through IPSec proposal -----------
        :foreach dangerString in=[:log find topics~"ipsec" message~"failed to pre-process ph1 packet"] do={
            :local dangerIP [:pick $stringTemp 0 ([:find $stringTemp "failed"] -1)];
        #----------- stage of searching for attempts to enter through L2TP -----------
        :foreach dangerString in=[:log find topics~"l2tp" message~ "user" message~"authentication failed"] do={
            :local dangerIP [:pick $stringTemp ([:find $stringTemp "<"] +1) [:find $stringTemp ">"]];
        #----------- stage of searching for attempts to establish TCP connection -----------
            :foreach dangerString in=[:log find message~"TCP connection established from"] do={
                :local dangerIP [:pick $stringTemp ([:find $stringTemp "from"] +5) [:len $stringTemp]];
        } else={
        #----------- stage of searching for attempts to enter through PPTP -----------
            :local dangerString1 [:toarray [:log find topics~"pptp" message~"authentication failed"]];
            :local dangerString2 [:toarray [:log find topics~"pptp" message~"TCP connection established from"]];
            :foreach dangerString in=$dangerString2 do={
                :local string2 [:log get $dangerString message];
                :local stringId2 ("0x".[:pick $dangerString ([:find $dangerString "*"] +1) [:len $dangerString]]);
                :local stringId1 "$[$DecToHex ([:tonum ($stringId2)] +1)]";
                :if ([:len [:find $dangerString1 $stringId1]]!=0) do={
                    :local dangerIP [:pick $string2 ([:find $string2 "from"] +5) [:len $string2]];
        #----------- stage of searching for attempts to enter through OVPN  -----------
            :local dangerString1 [:toarray [:log find topics~"ovpn" topics~"error" message~"unknown msg" or message~"msg too short"]];
            :local dangerString2 [:toarray [:log find topics~"ovpn" message~"TCP connection established from"]];
        #----------- stage of converting Blacklist from dynamic to static -----------
        :if ($staticAddrLst) do={
            :foreach idx in=[/ip firewall address-list find dynamic=yes list=$nameBlackList] do={
                :local ipaddress [/ip firewall address-list get $idx address];
                /ip firewall address-list remove $idx;
                /ip firewall address-list add list=$nameBlackList address=$ipaddress;
        # ----------- script completion -----------
        :if (!$isDetected) do={:put "$[/system clock get time]\tNo new dangerous IP-addresses were found"};
        :set scriptBlckr true;
    } else={:put "$[/system clock get time]\tScript already being executed..."}
    :put "$[/system clock get time]\tEnd of searching dangerous addresses script";
} on-error={
    # ----------- script error -----------
    :put "Script of blocking dangerous IP addresses worked with errors";
    :log warning "Script of blocking dangerous IP addresses worked with errors";
Кратко напомню, что работа скрипта сводится к формированию чёрного списка адресов и их последующей блокировке.
Формирование чёрного списка производится путём анализа записей журнала и работы специально настроенных правил Firewall.
Чёрный и белый списки расположены в 'IP/Firewall/Address Lists'.
Первые запуски скрипта настоятельно рекомендуется производить вручную из окна терминала, это нужно для чтения отчёта о состоянии и при необходимости внесения правок в настройки. Запуск настроенного скрипта должен производиться по расписанию.
В обновлённой версии особое внимание уделено контролю Firewall для облегчения настройки роутера "с нуля".
По умолчанию контроль Firewall отключен, это сделано из соображения, что Firewall может быть уже настроен и вмешательство в его работу не желательно.
Для включения контроля Firewall необходимо присвоить значение 'true' переменной 'firewallUsage', после чего скрипт будет производить проверку установки набора правил Firewall при каждом запуске. При отсутствии любого из правил происходит его автоматическое добавление. Поиск правил производится по комментариям. Работа ведётся со списками: 'Firewall/Filter Rules', 'Firewall/Raw', 'Firewall/Layer7 Protocols'. После установки правил Firewall пользователю необходимо их расположить вручную согласно своим предпочтениям. Для исключения неожиданной блокировки при установке новых правил, правила блокировки устанавливаются ОТКЛЮЧЕННЫМИ (!!!). Перемещение и включение правил блокировки пользователь производит ВРУЧНУЮ, рекомендуется это делать в режиме 'Safe Mode', для того чтобы в случае потери связи с роутером, когда режим 'Safe Mode' отключился, все настройки вернулись как были. Важно не забыть отключить 'Safe Mode' после настройки. Если правила блокировки оставить отключенными - скрипт будет оповещать об этом.
Известные проблемы:
  • работа скрипта может завершаться ошибкой, при включенном контроле правил Firewall и наличии в списке одинаковых правил с отличающимися комментариями.
  • для предотвращения блокировки скриптом адресов, влияющих на работоспособность сетевого оборудования (DNS провайдера, адрес вышестоящего узла, адрес сервера времени и т.п.), имеет смысл заранее внести их в белый список.
Код не идеален и в нём обязательно найдутся косяки и упущения, по этой причине готов принять замечания и пожелания.
Этот же скрипт выложил на альтернативном ресурсе.
Приятного использования!
Последний раз редактировалось drpioneer 09 ноя 2023, 09:07, всего редактировалось 3 раза.
Tandem
Доброго времени суток!
Я только осваиваю microtik, поэтому если вопросы покажутся глупыми - прошу снисхождения.
Настроил скрипт под свои хотелки, но не совсем понимаю для чего нужно правило fasttrack?
Можно как то описание работы скрипта прочитать? Не совсем понимаю как он работает.
За три часа работы >25000 адресов в черном списке. Хотя по логам были попытки брутфорсить L2TP+IPSec ну и 8291.
Там не более 500-600 адресов было. До этого использовал такие правила в Filter Rules:
add action=drop chain=input comment="Drop WinBox brute forcers" connection-state=new dst-port=8291 log=yes log-prefix="###########DROP WinBox brute forcer " protocol=tcp src-address-list=#BlockList-WinBox#
add action=add-src-to-address-list address-list=#BlockList-WinBox# address-list-timeout=10d chain=input connection-state=new dst-port=8291 protocol=tcp src-address-list=#WinBox-Step-3#
add action=add-src-to-address-list address-list=#WinBox-Step-3# address-list-timeout=3m chain=input comment="WinBox last attempt" connection-state=new dst-port=8291 protocol=tcp src-address-list=#WinBox-Step-2#
add action=add-src-to-address-list address-list=#WinBox-Step-2# address-list-timeout=3m chain=input comment="WinBox 2nd attempt" connection-state=new dst-port=8291 protocol=tcp src-address-list=#WinBox-Step-1#
add action=add-src-to-address-list address-list=#WinBox-Step-1# address-list-timeout=3m chain=input comment="WinBox initial 1st attempt" connection-state=new dst-port=8291 protocol=tcp
add action=drop chain=input comment="Drop L2TP brute forcers" log=yes log-prefix="***********DROP L2TP brute forcer " protocol=udp src-address-list=#BlockList-L2TP#
add action=add-dst-to-address-list address-list=#BlockList-L2TP# address-list-timeout=10d chain=output content="M=bad" dst-address-list=#L2TP-Step-3#
add action=add-dst-to-address-list address-list=#L2TP-Step-3# address-list-timeout=2m chain=output comment="L2TP last attempt" content="M=bad" dst-address-list=#L2TP-Step-2#
add action=add-dst-to-address-list address-list=#L2TP-Step-2# address-list-timeout=2m chain=output comment="L2TP 2nd attempt" content="M=bad" dst-address-list=#L2TP-Step-1#
add action=add-dst-to-address-list address-list=#L2TP-Step-1# address-list-timeout=2m chain=output comment="L2TP initial 1st attempt" content="M=bad"
drpioneer
Приветствую!
Tandem писал(а): 26 окт 2023, 06:19 Настроил скрипт под свои хотелки, но не совсем понимаю для чего нужно правило fasttrack?
Про FastTrack можно почитать здесь.
Tandem писал(а): 26 окт 2023, 06:19 Можно как то описание работы скрипта прочитать? Не совсем понимаю как он работает.
Для формирования чёрного списка адресов скрипт настраивает Firewall по принципу: "запрещено всё, что не разрешено" и попутно проверяет журнал устройства на наличие попыток несанкционированного подключения к роутеру. Все абоненты, попавшие в чёрный список, глушатся блокирующим правилом Firewall на заданное в скрипте время. Проверка наличия правил Firewall, заданных в скрипте, производится при каждом его запуске и в случае если эти правила не были обнаружены, скрипт производит их установку.
Таким образом, все обращения к роутеру, которые не прошли проверку Firewall или отразились в журнале устройства, как попытки несанкционированного доступа, временно блокируются.
Как-то так...
drpioneer
Приветствую всех!
Скрипт обновился и в очередной версии было уделено особое внимание работе с журналом устройства: расширился список фраз, указывающих на невалидные попытки подоить роутер.
# Script for searching and blocking dangerous IP-addresses
# https://forummikrotik.ru/viewtopic.php?p=91464#p91464
# https://github.com/drpioneer/MikrotikBlockDangerAddresses/blob/master/danger.rsc
# tested on ROS 6.49.10 & 7.12
# updated 2023/12/01
:do {
    # --------------------------------------------------------------------------------- # function of verifying correctness IP-address v.4 & blacklisting it
    # $1 - IP-addr; $2 - nameBlackList; $3 - timeoutBL; $4 - logEntry; $5 - name of attack
    :global IPAddrDNG do={
        :if ($1~"((25[0-5]|2[0-4][0-9]|[0-1]?[0-9][0-9]?)[.]){3}(25[0-5]|2[0-4][0-9]|[0-1]?[0-9][0-9]?)") do={
                :put "$[/system clock get time]\tAdded in BlackList IP-addr $1 ($5)";
                :if ($4) do={:log warning ">>> Added in BlackList IP: $1 ($5)"}
                :return true;
        :return false;
    # --------------------------------------------------------------------------------- # function of converting decimal numbers to hexadecimal
    :global DecToHexDNG do={
        :local tempNumber $1; :local result ""; :local remainder 0;
        :return "*$result";
    # --------------------------------------------------------------------------------- # string parsing function
        :local stopPos 0;
    # --------------------------------------------------------------------------------- # gateway interface-list search function
        :local routeISP [/ip route find dst-address=0.0.0.0/0 active=yes];
        :if ([:len $routeISP]=0) do={:return ""}
        :local gwIface [/ip route get $routeISP vrf-interface];
        :local brdgName [/interface bridge find name=$gwIface];
        :if ([:len $gwIface]>0 && [:len $brdgName]>0) do={
            :local ipAddrGt [/ip route get $routeISP gateway];
            :local macAddrGt [/ip arp get [find address=$ipAddrGt interface=$gwIface] mac-address];
            :set gwIface [/interface bridge host get [find mac-address=$macAddrGt] interface];
        :local ifList [/interface list member find interface=$gwIface];
        :if ([:len $ifList]!=0) do={
            :foreach gwList in=$ifList do={:return [/interface list member get $gwList list]}
        :return ""
    # --------------------------------------------------------------------------------- # function of dangerous IP finder in LOG
    :local IpFinder do={                                    # $1 - prev string; $2 - curr string; $3 - next string;
        :global DecToHexDNG;                                # $4 - begin pattern by dangerous IP-addr; $5 - end pattern by dangerous IP-addr
        :global IPAddrDNG;                                  # $6 - name of attack; $7 - nameBlackList; $8 - timeoutBL; $9 - logEntry
        :local isDang false;        # sign of detected danger
        :local prevLen [:len $1]; :local currLen [:len $2]; :local nextLen [:len $3];
        :if ($currLen=0 or ($prevLen!=0 && $nextLen!=0)) do={:return $isDang};                          # quick exit with incorrect input parameters
        :local bgnPtrn [:len $4]; :local endPtrn [:len $5]; :local dangIP "";
        :local arrPrevId [[:parse $1]]; :local arrCurrId [[:parse $2]]; :local arrNextId [[:parse $3]];
        :local lenPrevId [:len $arrPrevId]; :local lenCurrId [:len $arrCurrId]; :local lenNextId [:len $arrNextId];
        :if ($lenCurrId=0 or ($prevLen!=0 && lenPrevId=0) or ($nextLen!=0 && $lenNextId=0)) do={:return $isDang}; # quick exit when specified string is not found
        :foreach currId in=$arrCurrId do={                                                              # selecting current id string
            :local str [:log get $currId message]; :local strLen [:len $str];                           # text of current string
            :if ($strLen<200) do={        # filtering out very long strings
                :local currHexId ("0x".[:pick $currId ([:find $currId "*"] +1) [:len $currId]]);        # hex id of current string
                :local prevId "$[$DecToHexDNG ([:tonum ($currHexId)] -1)]";                             # id of previous string
                :local nextId "$[$DecToHexDNG ([:tonum ($currHexId)] +1)]";                             # id of next string
                :local findPrev 0; :set findPrev [:len [:find $arrPrevId $prevId]];
                :local findNext 0; :set findNext [:len [:find $arrNextId $nextId]];
                :if (($prevLen=0 && $nextLen=0 && $lenCurrId!=0) or ($prevLen!=0 && $nextLen=0 && $findPrev!=0) or ($prevLen=0 && $nextLen=!0 && $findNext!=0)) do={
                    :if ($bgnPtrn!=0) do={:set dangIP [:pick $str ([:find $str $4]+$bgnPtrn) $strLen]} else={:set dangIP $str}; # begin of dangerous IP-addr
                    :if ($endPtrn!=0) do={:set dangIP [:pick $dangIP 0 [:find $dangIP $5]]};            # end   of dangerous IP-addr
                    :if ([$IPAddrDNG $dangIP $7 $8 $9 $6]) do={:set isDang true};                       # sending suspicious address to verification
        :return $isDang;
    # --------------------------------------------------------------------------------- # main body of the script
                :local cmmnt "";
                find;
                    "name=CVE-2023-28771 comment=\"IPsec payload missing: SA\" regexp=\";bash -c \\\"(curl|wget) (http:\\\\/\\\\/|)[0-9]+\\\\.[0-9]+\\\\.[0-9]+\\\\.[0-9]\"";
                find;
                /ip firewall raw;
                find;
            :local ruleID "";
            } else={
                    } else={
            /ip firewall raw;
            } else={
                    } else={
        } else={:put "$[/system clock get time]\tATTENTION!!! Not found list external interfaces named '$inIfaceList'. Check it 'Interfaces-Interface List'. Firewall protection may not work!!!"}
        #----------- stage of analysis device log -----------
        :local dataBase {
            {name="login failure";prev="";curr="[/log find topics~\"system\" message~\"login failure for user\"]";next="";bgn="from ";end=" via";};
            {name="denied connect";prev="";curr="[/log find topics~\"warning\" message~\"denied winbox/dude connect from\"]";next="";bgn="from ";end=""};
            {name="L2TP auth failed";prev="";curr="[/log find topics~\"l2tp\" message~\"user\" message~\"authentication failed\"]";next="";bgn="<";end=">"};
            {name="IPsec wrong passwd";prev="";curr="[/log find topics~\"ipsec\" message~\"parsing packet failed, possible cause: wrong password\"]";next="";bgn="";end="parsing"};
            {name="IPSec failed proposal";prev="";curr="[/log find topics~\"ipsec\" message~\"failed to pre-process ph1 packet\"]";next="";bgn="";end=" failed"};
            {name="IPsec ph1 failed due to time up";prev="[/log find topics~\"ipsec\" topics~\"info\" message~\"respond new phase 1 \"]";curr="[/log find topics~\"ipsec\" topics~\"error\" message~\"phase1 negotiation failed due to time up\"]";next="";bgn="<=>";end="["};
            {name="IKEv2 ident not found";prev="[/log find topics~\"ipsec\" topics~\"error\" message~\"identity not found\"]";curr="[/log find topics~\"ipsec\" message~\"killing ike2 SA\"]";next="";bgn="]-";end="["};
            {name="IKEv2 payload missing";prev="";curr="[/log find topics~\"firewall\" message~\"payload missing\"]";next="";bgn="proto UDP, ";end=":"};
            {name="OVPN peer disconn";prev="[/log find topics~\"ovpn\" topics~\"info\" message~\"connection established from\"]";curr="[/log find topics~\"ovpn\" message~\"disconnected <peer disconnected>\"]";next="";bgn="<";end=">"};
            {name="OVPN unknown opcode";prev="[/log find topics~\"ovpn\" topics~\"error\" message~\"unknown opcode received\"]";curr="[/log find topics~\"ovpn\" message~\"disconnected <bad packet received>\"]";next="";bgn="<";end=">"};
            {name="OVPN unknown MSG";prev="[/log find topics~\"ovpn\" topics~\"error\" message~\"unknown msg\" or message~\"msg too short\"]";curr="[/log find topics~\"ovpn\" message~\"TCP connection established from\"]";next="";bgn="from ";end=""};
            {name="PPTP auth failed";prev="";curr="[/log find topics~\"pptp\" message~\"TCP connection established from\"]";next="[/log find topics~\"pptp\" message~\"authentication failed\"]";bgn="from ";end=""};
            {name="TCP conn establ";prev="";curr="[/log find message~\"TCP connection established from\"]";next="";bgn="from ";end="";extr=true};
            {name="IPsec due to time up";prev="";curr="[/log find topics~\"ipsec\" message~\"phase1 negotiation failed due to time up\"]";next="";bgn="<=>";end="[";extr=true};
        :foreach dangObj in=$dataBase do={
            :if (([:len ($dangObj->"extr")]=0) || ($extremeScan=($dangObj->"extr"))) do={
                :if [$IpFinder ($dangObj->"prev") ($dangObj->"curr") ($dangObj->"next") ($dangObj->"bgn") ($dangObj->"end") ($dangObj->"name") $nameBlackList $timeoutBL $logEntry] do={:set isDetected true};
    } else={
        :put "$[/system clock get time]\tScript already being executed...";
    /system script environment remove [find name~"DNG"];                # clearing memory
} on-error={
Предлагаю всем заинтересованным погонять эту версию скрипта и обозначить свои замечания.
Зеркало
mxmandr
Зачем правило input-accept-src.adress.list добавляется и в filter rules и raw?
И правило по блокировке адресов (dropping dangerous addresses), почему protocol !tcp ?
И в последний версии, попытки авторизации с топиком ipsec, то же начали в blacklist добавляться. За это +.
vladislav.granovskiy
а где поменять количество раз залогиниться для занесения в чс.
drpioneer
Приветствую!
mxmandr писал(а): 18 янв 2024, 18:34 Зачем правило input-accept-src.adress.list добавляется и в filter rules и raw?
Опишите подробнее, что на Ваш взгляд сделано не правильно?
mxmandr писал(а): 18 янв 2024, 18:34 И правило по блокировке адресов (dropping dangerous addresses), почему protocol !tcp ?
Уж и не вспомню, почему так :)
Помоему, если ' !tcp' убрать, тогда начинаются проблемы с мессенджерами во внутренней сети...
vladislav.granovskiy писал(а): 26 янв 2024, 16:42 а где поменять количество раз залогиниться для занесения в чс.
Нигде.
drpioneer
Скрипт обновился. Код причёсан на предмет снижения размера скрипта. Просьба отписать о замеченных проблемах в работе скрипта.
xan
drpioneer писал(а): 04 мар 2024, 11:06 Скрипт обновился. Код причёсан на предмет снижения размера скрипта. Просьба отписать о замеченных проблемах в работе скрипта.
Поставил, нет доступа к удалённым клиентам по WireGuard , SSTP.
В белый список можно добавить внешний ip, но клиент перезагрузит микрот и привет...
Также не работает Cloud, вычислил его ip добавил в белый список, не известно на долго ли...
drpioneer
xan писал(а): 09 мар 2024, 20:38 Поставил, нет доступа к удалённым клиентам по WireGuard , SSTP.
С предыдущей версией скрипта подобные сложности возникали?
Из перечисленного Вами: Wireguard, SSTP и Cloud я использую только SSTP и в его работе совместно со скриптом у себя сложностей не наблюдаю.
Каждый конкретный случай имеет свои особенности настройки сетевого оборудования, по этой причине разбираться с Вашим случаем придётся только Вам. Предлагаю по завершении диагностики поделиться своими мыслями: что и почему можно или нужно исправить в скрипте, чтобы впредь с такой проблемой не сталкиваться. Таким образом Вы внесете свой вклад в развитие скрипта, как это делают другие форумчане.
Здесь описание работы скрипта в хронологическом порядке:
viewtopic.php?p=84698#p84698
viewtopic.php?p=85250#p85250
viewtopic.php?p=91125#p91125
А отсюда я использовал идеи по настройке Firewall:
https://gregory-gost.ru/sozdanie-domash ... a-dostupa/
Удачи!
