Stompol
Сообщения: 19 Зарегистрирован: 08 сен 2016, 14:31
09 сен 2016, 12:01
Это конфиг от еще одного юзера, который желает настраивать Микротик, не имея сил|способностей|желания разобраться с парочкой тэгов. Думаю, и с Микротиком будет то же...
interface bridge add admin-mac=6C:3B:6B:00:8C:3B auto-mac=no comment=defconf name=bridge /interface wireless set [ find default-name=wlan1 ] band=2ghz-b/g/n channel-width=20/40mhz-Ce \ country=russia disabled=no distance=indoors frequency=auto mode=ap-bridge \ ssid=Gate3 wireless-protocol=802.11 /interface ethernet set [ find default-name=ether1 ] comment="\D1\EF\E0\F0\EA" set [ find default-name=ether2 ] arp=proxy-arp comment=\ "\CB\EE\EA\E0\EB\FC\ED\E0\FF \D1\E5\F2\FC" name=ether2-master set [ find default-name=ether3 ] master-port=ether2-master set [ find default-name=ether5 ] master-port=ether2-master /interface pppoe-client add add-default-route=yes interface=ether1 max-mru=1480 max-mtu=1480 mrru=\ 1600 name=pppoe-out1 password=***** user=***** /interface l2tp-server add name="L2TP to Client" user=user1 add name=l2tp-in1 user=user2 /interface pptp-client add allow=mschap1,mschap2 connect-to=****** mrru=1600 name=stom3 \ password=***** user=**** /interface pptp-server add name=pptp-in1 user= add name=pptp-in2 user=vvv /ip neighbor discovery set ether1 comment="\D1\EF\E0\F0\EA" discover=no set ether2-master comment="\CB\EE\EA\E0\EB\FC\ED\E0\FF \D1\E5\F2\FC" set bridge comment=defconf /interface ethernet set [ find default-name=ether4 ] arp=proxy-arp master-port=ether2-master \ name=RTK /interface ovpn-client add certificate=us2stom3.crt_0 cipher=aes192 connect-to=***** \ disabled=yes mac-address=02:0E:50:3C:AA:7C name=ovpn-out1 user=****** /interface wireless security-profiles set [ find default=yes ] authentication-types=wpa-psk,wpa2-psk mode=\ dynamic-keys wpa-pre-shared-key=******** wpa2-pre-shared-key=\ ******* /ip ipsec policy group set add name=group1 /ip ipsec proposal set [ find default=yes ] enc-algorithms=aes-256-cbc,aes-256-ctr,3des /ip pool add name=default-dhcp ranges=192.168.88.10-192.168.88.254 add name=Vpn ranges=192.168.42.10-192.168.42.100 add name=Ovpn ranges=192.168.89.1-192.168.89.254 add name=PooL ranges=172.16.30.102-172.16.30.253 /ip dhcp-server add address-pool=default-dhcp interface=bridge name=defconf /ppp profile set *0 only-one=no add change-tcp-mss=yes dns-server=10.0.0.20 local-address=172.16.30.101 name=\ L2pt remote-address=PooL wins-server=10.0.0.20 add bridge=bridge change-tcp-mss=yes local-address=10.0.0.5 name=GSP \ remote-address=Vpn use-compression=no use-mpls=no add local-address=Ovpn name=Ovpn remote-address=Ovpn set *FFFFFFFE local-address=192.168.89.1 only-one=no remote-address=Vpn /interface bridge port add bridge=bridge comment=defconf interface=ether2-master add bridge=bridge comment=defconf interface=wlan1 /interface l2tp-server server set authentication=mschap2 enabled=yes ipsec-secret=****** /interface pptp-server server set enabled=yes /interface sstp-server server set default-profile=default-encryption /ip address add address=10.0.0.5/24 comment=defconf interface=ether2-master network=\ 10.0.0.0 add address=******* interface=ether1 network=******* /ip dhcp-client add comment=defconf dhcp-options=hostname,clientid interface=ether1 /ip dhcp-server network add address=10.0.0.0/24 comment=defconf gateway=10.0.0.5 netmask=24 /ip dns set allow-remote-requests=yes /ip dns static add address=10.0.0.5 name=router /ip firewall filter add action=fasttrack-connection chain=forward connection-state=\ established,related src-address=10.0.0.6 add chain=input dst-port=1701 protocol=udp add chain=input dst-port=1723 protocol=tcp add chain=input protocol=icmp add chain=input dst-port=8291 in-interface=ether1 protocol=tcp add chain=input protocol=gre add action=fasttrack-connection chain=forward comment="defconf: fasttrack" \ connection-state=established,related add chain=forward comment="defconf: accept established,related" \ connection-state=established,related add action=drop chain=forward comment="defconf: drop invalid" \ connection-state=invalid add action=drop chain=forward comment=\ "defconf: drop all from WAN not DSTNATed" connection-nat-state=!dstnat \ connection-state=new in-interface=ether1 add chain=input connection-state=established add chain=forward disabled=yes p2p=fasttrack protocol=!tcp add chain=input connection-state=related add action=drop chain=input in-interface=ether1 /ip firewall nat add action=masquerade chain=srcnat comment="defconf: masquerade" \ out-interface=ether1 add action=masquerade chain=srcnat comment="masq. vpn traffic" src-address=\ 10.0.0.0/24 add action=netmap chain=dstnat comment= dst-port=**** in-interface=\ ether1 protocol=tcp to-addresses=10.0.0.1 to-ports=8081 add action=masquerade chain=srcnat comment="masq. vpn traffic" src-address=\ 192.168.89.0/24 /ip ipsec peer add address=0.0.0.0/0 comment=client-to-site enc-algorithm=\ aes-256,aes-128,3des exchange-mode=main-l2tp generate-policy=port-strict \ local-address=0.0.0.0 policy-template-group=group1 secret="\DB\E5\F9\FC" \ send-initial-contact=no /ip route add distance=1 gateway=****** add distance=1 dst-address=192.168.40.0/22 gateway=****** /ip service set telnet disabled=yes set ftp disabled=yes set ssh disabled=yes /ip upnp set enabled=yes /ip upnp interfaces add interface=bridge type=internal add interface=ether1 type=external add interface=pppoe-out1 type=external /ppp secret add name=vpn password=****** add name=user1 password=***** profile=L2pt service=l2tp add local-address=192.168.89.2 name=Home password=******* profile=GSP \ remote-address=192.168.1.120 service=pptp add local-address=192.168.89.5 name=stat1 password=***** profile=GSP \ remote-address=192.168.1.122 service=pptp add name=vvv password=**** profile=GSP service=pptp add local-address=192.168.89.4 name=gsp password=***** profile=GSP \ remote-address=192.168.1.123 service=pptp add local-address=10.0.0.5 name=alex password=***** profile=GSP \ remote-address=192.168.1.126 service=pptp add name=user2 password=***** profile=L2pt service=l2tp /system clock set time-zone-name=Europe/Moscow /system leds set 0 interface=wlan1 /system routerboard settings set protected-routerboot=disabled /tool mac-server set [ find default=yes ] disabled=yes add interface=ether2-master add interface=wlan1 /tool mac-server mac-winbox set [ find default=yes ] disabled=yes add interface=ether2-master add interface=wlan1
Stompol
09 сен 2016, 13:40
пробовал, эффект тот же
Это еще один конфиг от того же юзера, который желает настраивать Микротик, не имея сил|способностей|желания разобраться с парочкой тэгов. Думаю, и с Микротиком будет то же...
Сообщения: 3280 Зарегистрирован: 01 окт 2012, 14:48
09 сен 2016, 14:13
1. Выключить временно ВСЕ правила фаерволла!!! И включать только то, что действительно нужно. 2. Удалить все PPtP, L2tp, ovpn и так далее. 3. Удалить все лишнее из конфига, нафиг!!! 4. Убрать все лишнее из маскараднга. Оставить только scr-nat и masquerade, без указания подсетей и интерфейсов. То есть сделать это правило как можно более общим. Глядишь, все и заведется...
Stompol
12 сен 2016, 09:52
Результата тот же - один пользователь подключается, остальные нет.
12 сен 2016, 13:11
Увы, но удаленно трудно помочь. Собака зарыта где-то глубже.
Stompol
13 сен 2016, 10:00
Но проблема то не нова, в сети куча подобных вопросов, но только ни одного дельного ответа, разве никто не сталкивался?
13 сен 2016, 10:09
Ни разу не сталкивался. Все работает, правда у меня больше 10 одновременных клиентов не было, но и с ними никаких проблем не было и нет. На пальцах - обычно, когда клиент долго висит и не может подключиться, то это проблемы в получении IP адреса. Вот отсюда и нужно копать. Проблема может быть не только в микротике, но и в клиенте. Антивирус, фаерволл и так далее. Если есть где-то другой микротик в эксплуатации, попробуйте на нем поднять несколько коннектов к проблемному микротику и смотрите логи на обеих.
