настройка firewall при pptp клиенте
ig52
Интернета на компьютере то же нет, но pptp подымается, и нет доступа на микрот из вне
через консоль /export сделайте, когда pptp подключен и сюда выложите результат.
ig52
[admin@MikroTik] > /export
# jan/02/1970 17:27:02 by RouterOS 6.5
# software id = N3YW-HH8T
set [ find default-name=ether1 ] mac-address=D4:CA:6D:CF:B5:A6 name=\
ether1-gateway
set [ find default-name=ether2 ] mac-address=D4:CA:6D:CF:B5:A7 name=\
ether2-master-local
set [ find default-name=ether3 ] mac-address=D4:CA:6D:CF:B5:A8 master-port=\
ether2-master-local name=ether3-slave-local
set [ find default-name=ether4 ] mac-address=D4:CA:6D:CF:B5:A9 master-port=\
ether2-master-local name=ether4-slave-local
set [ find default-name=ether5 ] mac-address=D4:CA:6D:CF:B5:AA master-port=\
ether2-master-local name=ether5-slave-local
/interface pptp-client
add connect-to=vpn.local disabled=no max-mru=1400 max-mtu=1400 name=pptp-out1 \
password=xxxxxx user=xxxxxx
/ip neighbor discovery
set pptp-out1 discover=no
/ip hotspot user profile
mac-cookie-timeout=3d
add name=pool ranges=192.168.0.10-192.168.0.254
add address-pool=pool disabled=no interface=ether2-master-local name=dhcp-serv
/system logging action
set 0 memory-lines=100
set 1 disk-lines-per-file=100
add address=192.168.0.1/24 comment="default configuration" interface=\
ether2-master-local network=192.168.0.0
add address=172.25.3.6/32 comment=wan interface=ether1-gateway network=\
172.25.3.1
add address=192.168.0.0/24 comment="default configuration" dns-server=\
192.168.0.1 gateway=192.168.0.1 netmask=24
set allow-remote-requests=yes servers=172.22.0.1
/ip dns static
add chain=input in-interface=ether1-gateway protocol=tcp
add chain=input in-interface=pptp-out1 protocol=tcp
add chain=input protocol=icmp
add action=masquerade chain=srcnat comment=Wan out-interface=ether1-gateway
add action=masquerade chain=srcnat out-interface=pptp-out1
add distance=1 gateway=172.25.3.1
/ip service
set api disabled=yes
[admin@MikroTik] >
Вот, опять два маскарада))
ig52
Как решить?
вы когда создавали pptp клиента, забыли поставить галку add default route
ig52
pptp соединение удалил и заново поставил с этой галкой не помогло
/ip route print
/ip firewall nat print
c подключенным новым соединением
ig52
[admin@MikroTik] > /ip route print
0 A S 0.0.0.0/0 172.25.3.1 1
1 DS 0.0.0.0/0 10.128.0.1 1
2 ADC 10.128.0.1/32 xx.xxx.xx.xxx pptp-out1 0
3 ADC 172.25.3.1/32 172.25.3.6 ether1-gateway 0
4 ADC 192.168.0.0/24 192.168.0.1 ether2-master-l... 0
[admin@MikroTik] >
ig52
[admin@MikroTik] > /ip firewall nat print
0 ;;; Wan
chain=srcnat action=masquerade out-interface=ether1-gateway
1 chain=srcnat action=masquerade out-interface=pptp-out1
[admin@MikroTik] >
