Офис 1 в нём сервер voip:
# jun/27/2018 02:05:34 by RouterOS 6.42
# software id = 6ESD-JJ22
# model = RouterBOARD 3011UiAS
# serial number = 780E0675B9D2
add fast-forward=no name=bridge1
set [ find default-name=ether1 ] name=ether1-Wan
/interface sstp-server
add name="OpenVPN for Stroymarket" user=Stroymarket
/interface vlan
add interface=ether2 name=vlan100_2 vlan-id=100
/interface list
add name=WAN
add name=LAN
/ppp profile
add name=ovpn use-encryption=required
/queue simple
add max-limit=10M/10M name=queue1 queue=\
pcq-upload-default/pcq-download-default target=bridge1
add bridge=bridge1 interface=vlan100_2
/interface list member
add interface=ether1-Wan list=WAN
add list=LAN
/interface ovpn-server server
set certificate=server.crt_0 cipher=aes128 default-profile=ovpn enabled=yes \
require-client-certificate=yes
add address=188.170.23х.хх/30 interface=ether1-Wan network=188.170.23х.хх
add address=10.10.40.1/24 interface=ether4 network=10.10.40.0
add address=10.10.10.3/24 interface=bridge1 network=10.10.10.0
add address=10.10.40.0/24 gateway=10.10.40.1
set allow-remote-requests=yes servers=83.149.52.хх,83.149.53.хх
add action=accept chain=input comment="Accept Established & Related" \
add action=drop chain=output comment="Drop Invalid" connection-state=invalid
add action=accept chain=input comment="Accept ICMP" protocol=icmp
add action=accept chain=input comment="Accept OpenVPN" dst-port=1194 \
in-interface=ether1-Wan protocol=tcp
add action=drop chain=input comment="Drop all Wan" in-interface=ether1-Wan
add action=accept chain=forward comment="Accept Established &Related" \
add action=accept chain=forward comment="Internet from Lan" in-interface=\
bridge1
add action=drop chain=forward comment="Drop Invalid" connection-state=invalid
add action=drop chain=forward comment="Drop all from Wan except DST-NAT" \
connection-nat-state=!dstnat in-interface=ether1-Wan
add action=masquerade chain=srcnat out-interface=all-ppp
add action=masquerade chain=srcnat out-interface=ether1-Wan
add action=dst-nat chain=dstnat dst-port=80 in-interface=ether1-Wan protocol=\
tcp to-ports=80
add action=dst-nat chain=dstnat dst-port=443 in-interface=ether1-Wan \
protocol=tcp to-ports=443
add distance=1 gateway=188.170.23х.хх
add distance=1 dst-address=10.20.0.0/16 gateway=10.0.0.2 pref-src=10.0.0.1
add distance=1 dst-address=172.16.0.0/16 gateway=10.10.10.1
add distance=1 dst-address=172.17.0.0/16 gateway=10.0.0.2
add distance=1 dst-address=172.20.128.0/24 gateway=10.10.10.1
/ip service
set telnet disabled=yes
set ftp disabled=yes
set ssh disabled=yes
set api disabled=yes
set api-ssl disabled=yes
/ppp secret
add local-address=10.0.0.1 name=Stroymarket password=ххх profile=ovpn \
remote-address=10.0.0.2 service=ovpn
set time-zone-autodetect=no time-zone-name=Etc/GMT-11
/system identity
set name=Olimpik
/system ntp client
set enabled=yes primary-ntp=89.175.20.7 secondary-ntp=85.30.248.246
/system routerboard settings
set silent-boot=no
# jun/27/2018 02:06:39 by RouterOS 6.42
# software id = WI1A-QVYA
# serial number = 783D085D2D16
set [ find default-name=ether9 ] name="ether9(WiFi)"
/interface vlan
/interface ovpn-client
add certificate=client.crt_0 cipher=aes128 connect-to=188.170.23х.хх \
mac-address=02:71:47:92:26:F2 name=ovpn-out1 password=ххх user=\
Stroymarket
/interface list
add name=WAN
add name=LAN
add name=dhcp_pool1 ranges=10.20.200.50-10.20.200.254
add address-pool=dhcp_pool1 disabled=no interface="ether9(WiFi)" name=dhcp1
/queue simple
add max-limit=1M/1M name=queue2 queue=pcq-upload-default/pcq-download-default \
target="ether9(WiFi)"
/interface l2tp-server server
set enabled=yes
add list=LAN
/interface pptp-server server
set enabled=yes
add address=10.20.10.2/24 interface=ether2 network=10.20.10.0
add address=10.20.200.1/24 interface="ether9(WiFi)" network=10.20.200.0
add address=10.20.200.0/24 gateway=10.20.200.1
add action=accept chain=input comment="Accept Establishe & Related" \
add action=accept chain=forward comment="Accept Estabished & Related" \
add action=accept chain=forward comment="Internet from WiFi" in-interface=\
"ether9(WiFi)"
add action=accept chain=forward in-interface=bridge1
add action=masquerade chain=srcnat disabled=yes out-interface=ovpn-out1
add check-gateway=ping distance=1 gateway=188.170.23х.хх
add distance=1 dst-address=10.10.0.0/16 gateway=10.0.0.1 pref-src=10.0.0.2
add distance=1 dst-address=172.16.0.0/16 gateway=10.0.0.1
add distance=1 dst-address=172.17.0.0/16 gateway=10.20.10.1
/ip service
/ppp secret
add local-address=10.20.200.50 name=iam password=iam remote-address=\
10.20.200.254
/system identity
set name=StroyMarket
/system ntp client
set silent-boot=no
Как настраивалась сеть изначально указано в этом посту: viewtopic.php?f=3&t=8861
