Доступ извне к SIP АТС в локальной сети через микротик
Sergey.Kovaliov
Здравствуйте,
есть такая схема сети:
/export
[admin@MikroTik] > /export
# jul/30/2018 14:50:16 by RouterOS 6.27
# software id = FMLF-KKU3
add disabled=yes name=bridge1
set [ find default-name=ether1 ] name=inet
set [ find default-name=ether2 ] name=lan172
/ip neighbor discovery
set inet discover=no
set [ find default-name=ether3 ] master-port=lan172 name=ether3-slave-local
set [ find default-name=ether4 ] master-port=lan172 name=ether4-slave-local
set [ find default-name=ether5 ] master-port=lan172 name=ether5-slave-local
add name=dhcp ranges=172.65.120.245-172.65.120.247
add bridge=bridge1 disabled=yes interface=lan172
interface=lan172
interface=inet
set allow-remote-requests=yes servers=192.168.0.1,172.65.120.2
/ip dns static
add chain=forward comment="default configuration" connection-state=\
established,related disabled=yes
add action=drop chain=forward comment="default configuration" connection-state=\
invalid disabled=yes
connection-nat-state=!dstnat connection-state=new disabled=yes \
in-interface=inet
add chain=input disabled=yes protocol=icmp
add chain=input connection-state=established disabled=yes
add chain=input connection-state=related disabled=yes
add action=drop chain=input disabled=yes in-interface=inet
add chain=forward dst-address=192.68.0.108 dst-port=5060 protocol=udp
out-interface=all-ethernet
add action=dst-nat chain=dstnat dst-address=192.168.0.108 protocol=udp \
src-port=5060 to-addresses=172.65.120.7 to-ports=5060
/ip firewall service-port
set sip disabled=yes
add distance=1 gateway=192.168.0.1
/system routerboard settings
set cpu-frequency=850MHz protected-routerboot=disabled
/tool mac-server
add interface=lan172
/tool mac-server mac-winbox
[admin@MikroTik] >
задача при помощи любого (3G,4G..) интернета подключиться к АТС SIP
как ни прописываю проброс портов не получается
interface lan172 локальная сеть с DHCP
interface=inet выход в интернет
с микротиками впервые, два дня читаю инструкции не получается
"Роутер 192.168.0.1" у вас какой модели?
Sergey.Kovaliov
Erik_U писал(а): ↑30 июл 2018, 15:00 "Роутер 192.168.0.1" у вас какой модели?
TP-LINK WR720N
проброс на нем сделал
Больше нигде и не нужно.
У вас на границе с интернетом - TP-LINK, НАТ поднят на нем.
Микротики стоят внутри сети, и только маршрутизируют. SIP пакеты прекрасно маршрутизируются, никаких портов для этого пробрасывать не нужно.
Если у вашей АТС есть доступ в интернет (или пинг до TP-LINK), значит маршрутизация настроена.
Если нет - настройте маршрутизацию (на каждом маршрутизаторе добавьте маршруты до каждой IP сети вашего офиса).
А доступ снаружи будет работать только если у вас есть выделенный "белый" IP адрес.
Если его нет - по сеансовому ничего работать не будет, нужно заставить оператора сделать проброс портов. Дешевле купить белый IP.
Sergey.Kovaliov
IP внешний статический
в соединениях микротика(2)
вижу что при попытке соединится с АТС соединение устанавливается но я так понимаю не перебрасывается на интерфейс локальной сети
Мне нужно чтобы с интерфейса inet пакеты по порту 5060 шли в интерфейс lan172 на IP АТС
Вы на микротике внутри сети подняли нат?
Sergey.Kovaliov
Да, но не уверен что правильно
Зачем?
TP-LINK в режиме моста все бросает на микротик2?
Если нет, из 172.65.120.х до TP-LINK пинги проходят?
Sergey.Kovaliov
на TP-link проброс портов на микротик
Выключите везде проброс SIP порта.
И расскажите, какая у вас конфигурация сети.
НАТ для всей сети поднят где? На микротике2, или на TP-LINK?
Если на TP-LINK, то настройте на микротиках только маршрутизацию, НАТ не поднимайте.
А на TP-LINK проброс SIP порта сделайте сразу на адрес АТС.
