После обновления ROS на 7 ветку не поднимается pppoe
avsess
Очень странный момент.
Стояла 6.49.7
Сделал upgrade на 7.8. И все, pppoe не поднимается. Даже в pppoe scan тишина.
Ресетнул конфиг. Настроил только pppoe. Таже песня.
Сделал downgrade на 6.49.7 Все работает. pppoe scan понятное дело сразу все находит.
Что не так с 7 веткой?
конфиг интерфейсов
admin@MikroTik] > /interface pppoe-client export verbose
 # jan/02/1970 04:22:17 by RouterOS 6.49.7
# software id = 21PY-HM4J
# model = 2011UiAS-2HnD r2
# serial number = 91DE09765D3B
add ac-name="" add-default-route=yes allow=chap default-route-distance=1 dial-on-demand=no disabled=no interface=ether10 keepalive-timeout=10 max-mru=auto max-mtu=auto mrru=disabled name=mts password=TMwfZNp3 profile=default service-name="" \
    use-peer-dns=yes user=ep79282628145_1_serv201
/interface ethernet export verbose
# jan/02/1970 04:22:58 by RouterOS 6.49.7
set [ find default-name=ether1 ] advertise=10M-half,10M-full,100M-half,100M-full,1000M-half,1000M-full arp=enabled arp-timeout=auto auto-negotiation=yes bandwidth=unlimited/unlimited disabled=no full-duplex=yes l2mtu=1598 loop-protect=default \
    loop-protect-disable-time=5m loop-protect-send-interval=5s mac-address=B8:69:F4:A0:1B:F3 mtu=1500 name=ether1 orig-mac-address=B8:69:F4:A0:1B:F3 rx-flow-control=off speed=1Gbps tx-flow-control=off
set [ find default-name=ether2 ] advertise=10M-half,10M-full,100M-half,100M-full,1000M-half,1000M-full arp=enabled arp-timeout=auto auto-negotiation=yes bandwidth=unlimited/unlimited disabled=no full-duplex=yes l2mtu=1598 loop-protect=default \
    loop-protect-disable-time=5m loop-protect-send-interval=5s mac-address=B8:69:F4:A0:1B:F4 mtu=1500 name=ether2 orig-mac-address=B8:69:F4:A0:1B:F4 rx-flow-control=off speed=1Gbps tx-flow-control=off
set [ find default-name=ether3 ] advertise=10M-half,10M-full,100M-half,100M-full,1000M-half,1000M-full arp=enabled arp-timeout=auto auto-negotiation=yes bandwidth=unlimited/unlimited disabled=no full-duplex=yes l2mtu=1598 loop-protect=off \
    loop-protect-disable-time=5m loop-protect-send-interval=5s mac-address=B8:69:F4:A0:1B:F5 mtu=1500 name=ether3 orig-mac-address=B8:69:F4:A0:1B:F5 rx-flow-control=off speed=1Gbps tx-flow-control=off
set [ find default-name=ether4 ] advertise=10M-half,10M-full,100M-half,100M-full,1000M-half,1000M-full arp=enabled arp-timeout=auto auto-negotiation=yes bandwidth=unlimited/unlimited disabled=no full-duplex=yes l2mtu=1598 loop-protect=off \
    loop-protect-disable-time=5m loop-protect-send-interval=5s mac-address=B8:69:F4:A0:1B:F6 mtu=1500 name=ether4 orig-mac-address=B8:69:F4:A0:1B:F6 rx-flow-control=off speed=1Gbps tx-flow-control=off
set [ find default-name=ether5 ] advertise=10M-half,10M-full,100M-half,100M-full,1000M-half,1000M-full arp=enabled arp-timeout=auto auto-negotiation=yes bandwidth=unlimited/unlimited disabled=no full-duplex=yes l2mtu=1598 loop-protect=default \
    loop-protect-disable-time=5m loop-protect-send-interval=5s mac-address=B8:69:F4:A0:1B:F7 mtu=1500 name=ether5 orig-mac-address=B8:69:F4:A0:1B:F7 rx-flow-control=off speed=1Gbps tx-flow-control=off
set [ find default-name=ether6 ] advertise=10M-half,10M-full,100M-half,100M-full arp=enabled arp-timeout=auto auto-negotiation=yes bandwidth=unlimited/unlimited disabled=no full-duplex=yes l2mtu=1598 loop-protect=default loop-protect-disable-time=5m \
    loop-protect-send-interval=5s mac-address=B8:69:F4:A0:1B:F8 mtu=1500 name=ether6 orig-mac-address=B8:69:F4:A0:1B:F8 rx-flow-control=off speed=100Mbps tx-flow-control=off
set [ find default-name=ether7 ] advertise=10M-half,10M-full,100M-half,100M-full arp=enabled arp-timeout=auto auto-negotiation=yes bandwidth=unlimited/unlimited disabled=no full-duplex=yes l2mtu=1598 loop-protect=default loop-protect-disable-time=5m \
    loop-protect-send-interval=5s mac-address=B8:69:F4:A0:1B:F9 mtu=1500 name=ether7 orig-mac-address=B8:69:F4:A0:1B:F9 rx-flow-control=off speed=100Mbps tx-flow-control=off
set [ find default-name=ether8 ] advertise=10M-half,10M-full,100M-half,100M-full arp=enabled arp-timeout=auto auto-negotiation=yes bandwidth=unlimited/unlimited disabled=no full-duplex=yes l2mtu=1598 loop-protect=default loop-protect-disable-time=5m \
    loop-protect-send-interval=5s mac-address=B8:69:F4:A0:1B:FA mtu=1500 name=ether8 orig-mac-address=B8:69:F4:A0:1B:FA rx-flow-control=off speed=100Mbps tx-flow-control=off
set [ find default-name=ether9 ] advertise=10M-half,10M-full,100M-half,100M-full arp=enabled arp-timeout=auto auto-negotiation=yes bandwidth=unlimited/unlimited disabled=no full-duplex=yes l2mtu=1598 loop-protect=default loop-protect-disable-time=5m \
    loop-protect-send-interval=5s mac-address=B8:69:F4:A0:1B:FB mtu=1500 name=ether9 orig-mac-address=B8:69:F4:A0:1B:FB rx-flow-control=off speed=100Mbps tx-flow-control=off
set [ find default-name=ether10 ] advertise=10M-half,10M-full,100M-half,100M-full arp=enabled arp-timeout=auto auto-negotiation=yes bandwidth=unlimited/unlimited disabled=no full-duplex=yes l2mtu=1598 loop-protect=default loop-protect-disable-time=\
    5m loop-protect-send-interval=5s mac-address=B8:69:F4:A0:1B:FC mtu=1500 name=ether10 orig-mac-address=B8:69:F4:A0:1B:FC poe-out=off poe-priority=0 power-cycle-interval=none !power-cycle-ping-address power-cycle-ping-enabled=no \
    !power-cycle-ping-timeout rx-flow-control=off speed=100Mbps tx-flow-control=off
set [ find default-name=sfp1 ] advertise=10M-half,10M-full,100M-half,100M-full,1000M-half,1000M-full arp=enabled arp-timeout=auto auto-negotiation=yes bandwidth=unlimited/unlimited disabled=no full-duplex=yes l2mtu=1598 loop-protect=default \
    loop-protect-disable-time=5m loop-protect-send-interval=5s mac-address=B8:69:F4:A0:1B:F2 mtu=1500 name=sfp1 orig-mac-address=B8:69:F4:A0:1B:F2 rx-flow-control=off sfp-rate-select=high sfp-shutdown-temperature=95C speed=1Gbps tx-flow-control=off
/interface ethernet switch
set 0 cpu-flow-control=yes mirror-source=none mirror-target=none name=switch1
set 1 cpu-flow-control=yes mirror-source=none mirror-target=none name=switch2
/interface ethernet switch port
set 0 default-vlan-id=auto vlan-header=leave-as-is vlan-mode=disabled
set 1 default-vlan-id=auto vlan-header=leave-as-is vlan-mode=disabled
set 2 default-vlan-id=auto vlan-header=leave-as-is vlan-mode=disabled
set 3 default-vlan-id=auto vlan-header=leave-as-is vlan-mode=disabled
set 4 default-vlan-id=auto vlan-header=leave-as-is vlan-mode=disabled
set 5 default-vlan-id=auto vlan-header=leave-as-is vlan-mode=disabled
set 6 default-vlan-id=0 vlan-header=leave-as-is vlan-mode=disabled
set 7 default-vlan-id=0 vlan-header=leave-as-is vlan-mode=disabled
set 8 default-vlan-id=0 vlan-header=leave-as-is vlan-mode=disabled
set 9 default-vlan-id=0 vlan-header=leave-as-is vlan-mode=disabled
set 10 default-vlan-id=0 vlan-header=leave-as-is vlan-mode=disabled
set 11 default-vlan-id=auto vlan-header=leave-as-is vlan-mode=disabled
set 12 default-vlan-id=0 vlan-header=leave-as-is vlan-mode=disabled
Sergafan10
Ростелеком. Такая же ботва на 951G. Откатился.
Mobistek
это глюк 7.8 может?
