поддержка 1G SFP в CRS226-24G-2S+IN
lka82
Согласно документации 1 порт SFP+ в CRS226-24G-2S+IN поддерживает скорость 1G. Пытаюсь соединить CRS226 с CCR-1016 (через 1G порт), SFP - Mikrotik S-35/53LC20D. Линк не появляется. Если подключать CCR-1016 к другим устройствам через эти же SFP все работает. Нужны ли какие-нибудь настройки на CRS226, чтобы порт работал на скорости 1G? Выставлять жестко скорость и дуплекс пробовал
# jan/02/1970 00:21:52 by RouterOS 6.9
# software id = DJZK-K7SM
add l2mtu=1588 name=bridge1
set [ find default-name=ether1 ] name=ether1-master-local
set [ find default-name=ether2 ] master-port=ether1-master-local name=ether2-slave-local
set [ find default-name=ether3 ] master-port=ether1-master-local name=ether3-slave-local
set [ find default-name=ether4 ] master-port=ether1-master-local name=ether4-slave-local
set [ find default-name=ether5 ] master-port=ether1-master-local name=ether5-slave-local
set [ find default-name=ether6 ] master-port=ether1-master-local name=ether6-slave-local
set [ find default-name=ether7 ] master-port=ether1-master-local name=ether7-slave-local
set [ find default-name=ether8 ] master-port=ether1-master-local name=ether8-slave-local
set [ find default-name=ether9 ] master-port=ether1-master-local name=ether9-slave-local
set [ find default-name=ether10 ] master-port=ether1-master-local name=ether10-slave-local
set [ find default-name=ether11 ] master-port=ether1-master-local name=ether11-slave-local
set [ find default-name=ether12 ] master-port=ether1-master-local name=ether12-slave-local
set [ find default-name=ether13 ] master-port=ether1-master-local name=ether13-slave-local
set [ find default-name=ether14 ] master-port=ether1-master-local name=ether14-slave-local
set [ find default-name=ether15 ] master-port=ether1-master-local name=ether15-slave-local
set [ find default-name=ether16 ] master-port=ether1-master-local name=ether16-slave-local
set [ find default-name=ether17 ] master-port=ether1-master-local name=ether17-slave-local
set [ find default-name=ether18 ] master-port=ether1-master-local name=ether18-slave-local
set [ find default-name=ether19 ] master-port=ether1-master-local name=ether19-slave-local
set [ find default-name=ether20 ] master-port=ether1-master-local name=ether20-slave-local
set [ find default-name=ether21 ] master-port=ether1-master-local name=ether21-slave-local
set [ find default-name=ether22 ] master-port=ether1-master-local name=ether22-slave-local
set [ find default-name=ether23 ] master-port=ether1-master-local name=ether23-slave-local
set [ find default-name=ether24 ] master-port=ether1-master-local name=ether24-slave-local
set [ find default-name=sfp-sfpplus1 ] auto-negotiation=no master-port=ether1-master-local name=sfp-sfpplus1-slave-local sfp-rate-select=low speed=1Gbps
set [ find default-name=sfpplus2 ] auto-negotiation=no master-port=ether1-master-local name=sfpplus2-slave-local speed=1Gbps
/ip hotspot user profile
set [ find default=yes ] idle-timeout=none keepalive-timeout=2m mac-cookie-timeout=3d
/port
set 0 name=serial0
add bridge=bridge1 interface=ether1-master-local
/interface ethernet switch port
set 26 per-queue-scheduling=strict-priority:1,strict-priority:2,strict-priority:4,strict-priority:0,strict-priority:0,strict-priority:0,strict-priority:0,strict-priority:0
add address=192.168.88.2/24 comment="default configuration" interface=ether1-master-local network=192.168.88.0
add address=192.168.88.2/8 network=192.0.0.0
add address=192.168.88.2/24 network=192.168.88.0
add dhcp-options=hostname,clientid interface=bridge1
set allow-remote-requests=yes
/ip dns static
/ip upnp
/lcd interface
set ether1-master-local interface=ether1-master-local
set ether2-slave-local interface=ether2-slave-local
set ether3-slave-local interface=ether3-slave-local
set ether4-slave-local interface=ether4-slave-local
set ether5-slave-local interface=ether5-slave-local
set ether6-slave-local interface=ether6-slave-local
set ether7-slave-local interface=ether7-slave-local
set ether8-slave-local interface=ether8-slave-local
set ether9-slave-local interface=ether9-slave-local
set ether10-slave-local interface=ether10-slave-local
set ether11-slave-local interface=ether11-slave-local
set ether12-slave-local interface=ether12-slave-local
set ether13-slave-local interface=ether13-slave-local
set ether14-slave-local interface=ether14-slave-local
set ether15-slave-local interface=ether15-slave-local
set ether16-slave-local interface=ether16-slave-local
set ether17-slave-local interface=ether17-slave-local
set ether18-slave-local interface=ether18-slave-local
set ether19-slave-local interface=ether19-slave-local
set ether20-slave-local interface=ether20-slave-local
set ether21-slave-local interface=ether21-slave-local
set ether22-slave-local interface=ether22-slave-local
set ether23-slave-local interface=ether23-slave-local
set ether24-slave-local interface=ether24-slave-local
set sfp-sfpplus1-slave-local interface=sfp-sfpplus1-slave-local
set sfpplus2-slave-local interface=sfpplus2-slave-local
/lcd interface pages
set 0 interfaces="ether1-master-local,ether2-slave-local,ether3-slave-local,ether4-slave-local,ether5-slave-local,ether6-slave-local,ether7-slave-local,ether8-slave-local,ether9-slave-local,ether10-slave-local,ether11-slave-local,ether\
12-slave-local"
set 1 interfaces="ether13-slave-local,ether14-slave-local,ether15-slave-local,ether16-slave-local,ether17-slave-local,ether18-slave-local,ether19-slave-local,ether20-slave-local,ether21-slave-local,ether22-slave-local,ether23-slave-loc\
al,ether24-slave-local"
/system leds
add interface=sfp-sfpplus1-slave-local leds=eth24-led1 type=interface-activity
add interface=sfp-sfpplus1-slave-local leds=eth24-led2 type=interface-speed
add interface=sfpplus2-slave-local leds=eth25-led1 type=interface-activity
add interface=sfpplus2-slave-local leds=eth25-led2 type=interface-speed
