- У стационарного нет доступа в интернет. При том что с ноута и гаджетов доступ есть.
- Пробовал кабель от стационарного компьютера подключить к ноуту, при этом интернет есть. Прописал мак адрес от ноута на стационарный, но это не помогло.
- вот моя конфигурация
add admin-mac=D4:CA:6D:E5:BC:1B auto-mac=no l2mtu=1598 name=bridge-local \
protocol-mode=rstp
set 0 band=2ghz-b/g/n country=russia disabled=no distance=indoors \
ht-rxchains=0,1 ht-txchains=0,1 l2mtu=2290 mode=ap-bridge name=wlan \
tx-power=19 tx-power-mode=all-rates-fixed wireless-protocol=802.11
set 0 name=wan
set 1 name=ether2-master-local
set 2 master-port=ether2-master-local name=ether3-slave-local
set 3 master-port=ether2-master-local name=ether4-slave-local
set 4 master-port=ether2-master-local name=ether5-slave-local
set [ find default=yes ] authentication-types=wpa-psk,wpa2-psk mode=\
dynamic-keys supplicant-identity=MikroTik wpa-pre-shared-key=\
46990213F034 wpa2-pre-shared-key=46990213F034
/ip hotspot user profile
set [ find default=yes ] idle-timeout=none keepalive-timeout=2m
add name=lan-dhcp ranges=192.168.0.10-192.168.0.253
add address-pool=lan-dhcp disabled=no interface=bridge-local name=default
add bridge=bridge-local interface=wlan
add address=192.168.0.1/24 interface=wlan
/ip arp
add address=192.168.0.102 disabled=yes interface=bridge-local mac-address=\
00:1A:4D:94:59:B9
add disabled=no interface=wan
add address=192.168.0.0/24 dns-server=192.168.0.1 gateway=192.168.0.1 \
netmask=24
set allow-remote-requests=yes servers=8.8.8.8,8.8.4.4
/ip dns static
add address=192.168.0.1 disabled=yes name=router
/ip firewall address-list
add address=192.168.0.0/24 list=inet
add action=passthrough chain=unused-hs-chain comment=\
"place hotspot rules here" disabled=yes
add chain=input comment=icmp protocol=icmp
add chain=input comment=established connection-state=established
add chain=input comment=related connection-state=related
add chain=input comment=manage in-interface=bridge-local
add action=drop chain=input comment="all other drop" in-interface=wan
add action=drop chain=forward comment="Drop invalid connection packets" \
connection-state=invalid
add chain=forward comment="Allow established connections" connection-state=\
established
add chain=forward comment="Allow related connections" connection-state=\
related
add chain=forward comment="Allow acess to internet" in-interface=\
bridge-local out-interface=wan src-address-list=inet
add action=drop chain=forward comment="All other drop"
add action=masquerade chain=srcnat out-interface=wan to-addresses=0.0.0.0
add action=masquerade chain=srcnat comment="masquerade hotspot network" \
src-address=192.168.0.0/24
/ip hotspot user
add name=admin
/ip neighbor discovery
set wlan disabled=yes
add comment=isp disabled=yes distance=2 gateway=1.2.3.254
/ip service
set telnet disabled=yes
set ftp disabled=yes
/system clock manual
set time-zone=+04:00
/system identity
set name=vsonet
/system leds
set 0 interface=wlan
/system ntp client
set enabled=yes mode=unicast primary-ntp=193.1.193.157
DeskTop не может получить доступ в интернет
[*]Добрый вечер!
начните с того, что перевесьте адрес с wlan на bridge-local
в этом случае пропадает инет на ноуте, а на стационарном не появляется и доступ к роутеру с ноута пропадает, остается возможность подключиться только через winbox
Как организовано подключение к интернету? В конфигурации я вижу только dhcp-клиент на внешнем интерфейсе.
plin2s писал(а):Как организовано подключение к интернету? В конфигурации я вижу только dhcp-клиент на внешнем интерфейсе.
Так оно и есть меня провайдер пропускает по mac адресу, все остальные настройки приходят автоматом
simpl3x писал(а):и в этот момент перетащить адрес куда надо.
Это мне не очень понятно, если Вам не трудно поясните поподробней
Имелось в виду назначить локальный адрес не на wlan, а на бридж, при этом выключив все правила фаерволла.
А еще меня смущают строчки
Предлагаю удалить два правила masquerade и добавить
После этого нужно проверить сетевые настройки на компьютере (все ли правильно он получает) и пинги со стационарного компьютера на 8.8.8.8 и на 192.168.0.1.
add action=masquerade chain=srcnat comment=NAT disabled=no out-interface=\
wan
plin2s писал(а):После этого нужно проверить сетевые настройки на компьютере (все ли правильно он получает) и пинги со стационарного компьютера на 8.8.8.8 и на 192.168.0.1.
Сетевые настройки получают все устройства правильные при существующей конфигурации, а пинги полностью не проходят не с одного из устройств. Или теряется 2 пакета или 3.
svetkin писал(а):plin2s писал(а):После этого нужно проверить сетевые настройки на компьютере (все ли правильно он получает) и пинги со стационарного компьютера на 8.8.8.8 и на 192.168.0.1.
У вас не проходят пинги до 192.168.0.1?
