Один имеет белый IP, второй находится за NAT (серый IP). При первоначальной настройке все работало отлично. Потом отвалилось и больше не поднимается. Настройки не менял.
Серый (внутренний IP 100.*.*.*, внешний IP 194.*.*.*)
/ip ipsec proposal
add enc-algorithms=3des name=Moscow-Ntel-proposal pfs-group=none
/ip ipsec peer
add address=77.*.*.*/32 dh-group=modp1024 exchange-mode=ike2 policy-template-group=group1 secret=secret
/ip ipsec policy
add dst-address=192.168.108.0/22 proposal=Moscow-Ntel-proposal sa-dst-address=77.*.*.* sa-src-address=194.*.*.* (пробовал и 100.*.*.*) src-address=192.168.100.0/22 tunnel=yes
/ip ipsec proposal
add enc-algorithms=3des name=Istra-Beeline-proposal pfs-group=none
/ip ipsec peer
add address=194.*.*.*/32 dh-group=modp1024 exchange-mode=ike2 passive=yes policy-template-group=group1 secret=secret
/ip ipsec policy
add dst-address=192.168.100.0/22 proposal=Istra-Beeline-proposal sa-dst-address=194.*.*.* sa-src-address=77.*.*.* src-address=192.168.108.0/22 tunnel=yes
19:07:40 ipsec ike2 initialize send for: 77.*.*.*
19:07:40 ipsec adding payload: NOTIFY
19:07:40 ipsec => (size 0x1c)
19:07:40 ipsec adding payload: NONCE
19:07:40 ipsec adding payload: KE
19:07:40 ipsec => (size 0x88)
19:07:40 ipsec adding payload: SA
19:07:40 ipsec => (size 0x38)
19:07:40 ipsec,debug ===== sending 304 bytes from 100.*.*.*[4500] to 77.*.*.*[4500]
19:07:40 ipsec,debug 1 times of 308 bytes message will be sent to 77.*.*.*[4500]
19:07:47 ipsec ike2 init retransmit
19:07:47 ipsec,debug ===== sending 304 bytes from 100.*.*.*[4500] to 77.*.*.*[4500]
19:07:47 ipsec,debug 1 times of 308 bytes message will be sent to 77.*.*.*[4500]
19:07:52 ipsec ike2 init retransmit
19:07:52 ipsec,debug ===== sending 304 bytes from 100.*.*.*[4500] to 77.*.*.*[4500]
19:07:52 ipsec,debug 1 times of 308 bytes message will be sent to 77.*.*.*[4500]
19:07:57 ipsec ike2 init retransmit
19:07:57 ipsec,debug ===== sending 304 bytes from 100.*.*.*[4500] to 77.*.*.*[4500]
19:07:57 ipsec,debug 1 times of 308 bytes message will be sent to 77.*.*.*[4500]
19:08:02 ipsec ike2 init timeout
Я думал бы на провайдера, если бы до этого не работало с такими же настройками. В фаерволе все разрешено, в том числе udp 500, 4500, 1701, ipsec-ah, ipsec-esp.
Если поставить IKEv1 + NAT-Traversal, то в логах на белом я вижу попытки, он отправляет ответ, который никуда не доходит (так как серый находится за NAT). Также при IKEv2 отсутствует информация в Remote Peers (на обоих роутерах). Такое ощущение, что IKEv2 криво реализован или провайдер то фильтрует, то не фильтрует 4500 UDP.
P.S. Попробовать с маршрутизатора с серым IP сделать подключение IPsec IKEv2 к роутеру другой фирмы (домашний Zyxel keenetic), завелось все моментально. Порт тот же, UDP 4500. Так что провайдер исключается.
