# dec/03/2018 20:30:40 by RouterOS 6.43.2
# software id = LDX1-YI8Q
# model = 951Ui-2HnD
# serial number = 8157070E9832
add forward-delay=5s igmp-snooping=yes name=bridge1
set [ find default-name=ether1 ] advertise="10M-half,10M-full,100M-half,100M-ful\
l,1000M-half,1000M-full,2500M-full,5000M-full,10000M-full" \
loop-protect-send-interval=2s
set [ find default-name=ether2 ] advertise="10M-half,10M-full,100M-half,100M-ful\
loop-protect-disable-time=1m loop-protect-send-interval=1s
set [ find default-name=ether3 ] advertise=\
10M-half,10M-full,100M-half,100M-full,1000M-half,1000M-full \
rx-flow-control=auto tx-flow-control=auto
set [ find default-name=ether4 ] advertise=\
set [ find default-name=ether5 ] advertise=\
band=2ghz-b/g/n country=russia disabled=no frequency=auto frequency-mode=\
superchannel mode=ap-bridge multicast-helper=full ssid=Prosto_Wi-Fi \
tx-power-mode=all-rates-fixed wireless-protocol=802.11 wmm-support=enabled
/interface wireless nstreme
set wlan1 enable-polling=no
/interface list
add name=WAN
add name=LAN
set [ find default=yes ] authentication-types=wpa-psk,wpa2-psk eap-methods="" \
group-ciphers=tkip,aes-ccm mode=dynamic-keys supplicant-identity=MikroTik \
unicast-ciphers=tkip,aes-ccm wpa-pre-shared-key=******** \
wpa2-pre-shared-key=********
add authentication-types=wpa-psk,wpa2-psk,wpa-eap,wpa2-eap eap-methods="" \
group-ciphers=tkip,aes-ccm management-protection=allowed name=Guest \
supplicant-identity="" unicast-ciphers=tkip,aes-ccm wpa-pre-shared-key=\
12345678 wpa2-pre-shared-key=12345678
add name=dhcp ranges=192.168.35.2-192.168.35.254
add name=dhcp_guest ranges=192.168.250.100-192.168.250.150
add address-pool=dhcp disabled=no interface=bridge1 lease-time=3d10m name=dhcp1
add add-arp=yes address-pool=dhcp_guest authoritative=after-2sec-delay \
lease-time=3d10m name=dhcp_guest
add address-pool=dhcp disabled=no name=server1
/queue simple
add burst-limit=2M/3M burst-threshold=768k/768k burst-time=10s/10s max-limit=\
1M/2M name=guest target=192.168.250.0/24
/interface bridge filter
add action=accept chain=output mac-protocol=ip out-interface=wlan1 packet-type=\
multicast
add bridge=bridge1 interface=ether2 trusted=yes
add bridge=bridge1 interface=wlan1 trusted=yes
/interface bridge settings
set use-ip-firewall=yes
/interface list member
add interface=ether1 list=WAN
add interface=ether1 list=LAN
/interface pptp-server server
set enabled=yes
add address=192.168.35.1/24 interface=ether2 network=192.168.35.0
add address=192.168.250.1/24 network=192.168.250.0
add dhcp-options=hostname,clientid disabled=no interface=ether1
/ip dhcp-server config
set store-leases-disk=never
add address=192.168.35.0/24 dns-server=8.8.8.8 gateway=192.168.35.1
add address=192.168.250.0/24 dns-server=8.8.8.8,192.168.250.1 gateway=\
192.168.250.1 netmask=24
set allow-remote-requests=yes servers=128.14.6.10,128.14.6.11
add action=accept chain=output comment="Allow IGMP (for IPTV)" disabled=yes \
out-interface=all-wireless protocol=igmp
add action=accept chain=input comment="Allow IGMP" disabled=yes in-interface=\
ether1 protocol=igmp
add action=accept chain=input comment="IPTV UDP incoming" disabled=yes \
dst-port=1234 in-interface=ether1 protocol=udp
add action=accept chain=forward comment="IPTV UDP forwarding" disabled=yes \
dst-port=1234 out-interface=all-wireless protocol=udp
add action=drop chain=forward dst-address=192.168.250.0/24 src-address=\
192.168.35.0/24
add action=drop chain=forward dst-address=192.168.35.0/24 src-address=\
192.168.250.0/24
add action=masquerade chain=srcnat out-interface-list=all
add distance=1 gateway=192.168.250.1
/ip service
set telnet disabled=yes
set ftp disabled=yes
set www address=192.168.35.0/24
set ssh disabled=yes
set api disabled=yes
set winbox address=192.168.35.0/24
set api-ssl disabled=yes
/ppp secret
add local-address=10.0.0.2 name=ppp1 password=ppp1 profile=default-encryption \
remote-address=10.0.0.3
/routing igmp-proxy
set query-interval=1m query-response-interval=5s quick-leave=yes
/routing igmp-proxy interface
add disabled=yes interface=wlan1
add alternative-subnets=0.0.0.0/0 disabled=yes interface=ether1 upstream=yes
set time-zone-name=Asia/Novosibirsk
/system routerboard settings
set silent-boot=no
/interface list
add name=WAN
add name=LAN
/queue simple
multicast
set enabled=yes
192.168.35.0/24
192.168.250.0/24
/ip service
/ppp secret
/routing igmp-proxy
set silent-boot=no
