Вводные такие 12 точек доступа RBD52G-5HacD2HnD расположены в офисе, расстановка достаточно плотная
Контроллер на CRS328-24P-4S+
DHCP сервер на другой машине
Идут постоянные переключения и отключения
Может быть подскажите куда начинать копать
Вот конфиг
/caps-man channel
add band=2ghz-b/g/n control-channel-width=20mhz extension-channel=Ce \
frequency=2422 name=channel-NHG tx-power=14
add band=2ghz-b/g/n control-channel-width=10mhz extension-channel=Ce \
frequency=2462 name=channel_guest tx-power=14
add band=5ghz-a/n/ac extension-channel=Ce name=channel5-NHG tx-power=14
add band=5ghz-n/ac control-channel-width=20mhz extension-channel=XXXX \
frequency=5180 name=ХХХХ5 secondary-frequency=\
5200,5220,5240,5260,5280,5300,5230,5500,5520,5540,5560 tx-power=14
add band=5ghz-n/ac extension-channel=Ce frequency=5180 name=\
"5Ghz - Channel 36"
add band=5ghz-n/ac extension-channel=Ce frequency=5200 name=\
"5Ghz - Channel 40" tx-power=14
add band=5ghz-n/ac extension-channel=Ce frequency=5220 name=\
"5Ghz - Channel 44"
add band=5ghz-n/ac extension-channel=Ce frequency=5240 name=\
"5Ghz - Channel 48"
add band=5ghz-n/ac extension-channel=Ce frequency=5260 name=\
"5Ghz - Channel 52"
add band=5ghz-n/ac extension-channel=Ce frequency=5280 name=\
"5Ghz - Channel 56" tx-power=14
add band=5ghz-n/ac extension-channel=Ce frequency=5300 name=\
"5Ghz - Channel 60"
add band=5ghz-a/n/ac control-channel-width=20mhz extension-channel=Ce \
frequency=5320 name="5Ghz - Channel 64" tx-power=14
add band=5ghz-a/n/ac extension-channel=Ce frequency=5500 name=\
"5Ghz - Channel 100" tx-power=14
add band=5ghz-a/n/ac extension-channel=Ce frequency=5520 name=\
"5Ghz - Channel 104" tx-power=14
add band=5ghz-a/n/ac extension-channel=Ce frequency=5540 name=\
"5Ghz - Channel 108" tx-power=14
frequency=5560 name="5Ghz - Channel 112" tx-power=14
frequency=5580 name="5Ghz - Channel 116" tx-power=14
add band=2ghz-g/n extension-channel=Ce frequency=2412 name=\
"2.4GHz - Channel 1"
add band=2ghz-g/n extension-channel=Ce frequency=2437 name=\
"2.4GHz - Channel 6"
add band=2ghz-g/n frequency=2462 name="2.4GHz - Channel 11"
add name=Bridge_Guest_WiFi
add admin-mac=C4:AD:34:D2:99:37 auto-mac=no comment=defconf name=bridge-LAN
set [ find default-name=ether1 ] comment="=to AP01="
set [ find default-name=ether2 ] comment="=to AP02="
set [ find default-name=ether3 ] comment="=to AP03="
set [ find default-name=ether4 ] comment="=to AP06=" poe-priority=100
set [ find default-name=ether5 ] comment="=to AP04="
set [ find default-name=ether6 ] comment="=to AP12="
set [ find default-name=ether7 ] comment="=to AP11="
set [ find default-name=ether8 ] comment="=to AP8="
set [ find default-name=ether9 ] comment="=to AP05="
set [ find default-name=ether10 ] comment="=to AP09=" poe-priority=100
set [ find default-name=ether11 ] comment="=to AP10="
set [ find default-name=ether12 ] comment="=to AP07="
set [ find default-name=ether13 ] comment="=to IPBS2="
set [ find default-name=ether14 ] comment="Phone KvytkovskiyP" poe-priority=\
100
set [ find default-name=ether15 ] comment="Phone SabitovN" poe-priority=100
set [ find default-name=ether16 ] comment=Dell_540_Lan2 poe-priority=100
set [ find default-name=ether17 ] comment=Dell_540_Lan1
set [ find default-name=ether18 ] comment=Dell_440_Lan2
set [ find default-name=ether19 ] comment=Dell_440_Lan1
set [ find default-name=ether20 ] comment="Synology RS819_Lan1"
set [ find default-name=ether21 ] comment="Synology RS819_Lan2"
set [ find default-name=ether24 ] comment="to CO-SW-1"
/interface vlan
add interface=bridge-LAN name=vlan4 vlan-id=4
add interface=bridge-LAN name=vlan10 vlan-id=10
add interface=bridge-LAN name=vlan14 vlan-id=14
add interface=bridge-LAN name=vlan20 vlan-id=20
add interface=bridge-LAN name=vlan25 vlan-id=25
add interface=bridge-LAN name=vlan39 vlan-id=39
add interface=bridge-LAN name=vlan50 vlan-id=50
/caps-man datapath
add bridge=bridge-LAN client-to-client-forwarding=yes name=datapath-NHG
add bridge=Bridge_Guest_WiFi client-to-client-forwarding=no name=\
datapath_guest_wifi
/caps-man security
add authentication-types=wpa2-psk encryption=aes-ccm group-encryption=aes-ccm \
name=security-NHG passphrase=4995798586
name=security-guest passphrase=guestwifi
add authentication-types=wpa-psk,wpa2-psk comment="PSK for new SSIDs" \
encryption=aes-ccm group-encryption=aes-ccm name=ХХХХ passphrase=\
ХХХХ_2021!
/caps-man configuration
add channel=channel-NHG country=russia3 datapath=datapath-NHG distance=\
indoors frame-lifetime=0ms guard-interval=long hw-protection-mode=rts-cts \
hw-retries=7 mode=ap name=cfg-NHG rx-chains=0,1 security=security-NHG \
ssid=ХХХХ tx-chains=0,1
add channel=channel5-NHG country=russia3 datapath=datapath-NHG mode=ap name=\
cfg5-NHG rx-chains=0,1,2 security=security-NHG ssid=ХХХХ tx-chains=0,1,2
add channel=ХХХХ5 channel.band=5ghz-n/ac country=russia datapath=datapath-NHG \
mode=ap name=ХХХХ5 rx-chains=0,1,2,3 security=ХХХХ ssid=ХХХХ5 tx-chains=\
0,1,2,3
add channel="5Ghz - Channel 36" comment="5 GHz channel 36 cfg" country=\
russia3 datapath=datapath-NHG mode=ap name=ХХХХ5-Ch36 security=ХХХХ ssid=\
ХХХХ5
add channel="5Ghz - Channel 40" comment="5 GHz channel 40 cfg" country=\
russia3 datapath=datapath-NHG mode=ap name=ХХХХ5-Ch40 security=ХХХХ ssid=\
ХХХХ5
add channel="5Ghz - Channel 44" comment="5 GHz channel 44 cfg" country=\
russia3 datapath=datapath-NHG mode=ap name=ХХХХ5-Ch44 security=ХХХХ ssid=\
ХХХХ5
add channel="5Ghz - Channel 48" comment="5 GHz channel 48 cfg" country=\
russia3 datapath=datapath-NHG mode=ap name=ХХХХ5-Ch48 security=ХХХХ ssid=\
ХХХХ5
add channel="5Ghz - Channel 52" comment="5 GHz channel 52 cfg" country=\
russia3 datapath=datapath-NHG mode=ap name=ХХХХ5-Ch52 security=ХХХХ ssid=\
ХХХХ5
add channel="5Ghz - Channel 56" comment="5 GHz channel 56 cfg" country=\
russia3 datapath=datapath-NHG mode=ap name=ХХХХ5-Ch56 security=ХХХХ ssid=\
ХХХХ5
add channel="5Ghz - Channel 108" comment="5 GHz channel 108 cfg" country=\
russia3 datapath=datapath-NHG mode=ap name=ХХХХ5-Ch108 security=ХХХХ \
ssid=ХХХХ5
add channel="5Ghz - Channel 64" comment="5 GHz channel 64 cfg" country=\
russia3 datapath=datapath-NHG mode=ap name=ХХХХ5-Ch64 security=ХХХХ ssid=\
ХХХХ5
add channel="5Ghz - Channel 60" comment="5 GHz channel 60 cfg" country=\
russia3 datapath=datapath-NHG mode=ap name=ХХХХ5-Ch60 security=ХХХХ ssid=\
ХХХХ5
add channel="2.4GHz - Channel 1" channel.band=2ghz-g/n country=russia3 \
datapath=datapath-NHG mode=ap name="2.4GHz ch1- ХХХХ" security=\
add channel="2.4GHz - Channel 6" channel.band=2ghz-g/n country=russia3 \
datapath=datapath-NHG mode=ap name="2.4gHz ch 6 - ХХХХ" security=\
add channel="2.4GHz - Channel 11" datapath=datapath-NHG mode=ap name=\
"2.4GHz ch11 ХХХХ" rx-chains=0,1,2,3 security=security-NHG ssid=ХХХХ \
tx-chains=0,1,2,3
add channel=channel_guest channel.band=2ghz-b/g/n \
channel.control-channel-width=10mhz channel.extension-channel=Ce \
channel.frequency=2462 country=russia3 datapath=datapath_guest_wifi \
datapath.bridge=bridge-LAN name=guest_wifi security=security-guest ssid=\
GuestWiFi
/caps-man interface
add configuration="2.4GHz ch1- ХХХХ" disabled=no l2mtu=1600 mac-address=\
48:8F:5A:17:6F:E3 master-interface=none name=CO-AP01-1 radio-mac=\
48:8F:5A:17:6F:E3 radio-name=488F5A176FE3
add configuration=guest_wifi disabled=no l2mtu=1600 mac-address=\
4A:8F:5A:17:6F:E3 master-interface=CO-AP01-1 name=CO-AP01-1-1 \
radio-mac=00:00:00:00:00:00 radio-name=4A8F5A176FE3
add configuration=ХХХХ5-Ch48 disabled=no l2mtu=1600 mac-address=\
48:8F:5A:17:6F:E4 master-interface=none name=CO-AP01-2 radio-mac=\
48:8F:5A:17:6F:E4 radio-name=488F5A176FE4
4A:8F:5A:17:6F:E4 master-interface=CO-AP01-2 name=CO-AP01-2-1 \
radio-mac=00:00:00:00:00:00 radio-name=4A8F5A176FE4
add configuration="2.4GHz ch11 ХХХХ" disabled=no l2mtu=1600 mac-address=\
48:8F:5A:17:72:A6 master-interface=none name=CO-AP02-1 radio-mac=\
48:8F:5A:17:72:A6 radio-name=488F5A1772A6
4A:8F:5A:17:72:A6 master-interface=CO-AP02-1 name=CO-AP02-1-1 \
radio-mac=00:00:00:00:00:00 radio-name=4A8F5A1772A6
add configuration=ХХХХ5-Ch40 disabled=no l2mtu=1600 mac-address=\
48:8F:5A:17:72:A7 master-interface=none name=CO-AP02-2 radio-mac=\
48:8F:5A:17:72:A7 radio-name=488F5A1772A7
4A:8F:5A:17:72:A7 master-interface=CO-AP02-2 name=CO-AP02-2-1 \
radio-mac=00:00:00:00:00:00 radio-name=4A8F5A1772A7
add configuration="2.4gHz ch 6 - ХХХХ" disabled=no l2mtu=1600 mac-address=\
48:8F:5A:17:72:C2 master-interface=none name=CO-AP03-1 radio-mac=\
48:8F:5A:17:72:C2 radio-name=488F5A1772C2
4A:8F:5A:17:72:C2 master-interface=CO-AP03-1 name=CO-AP03-1-1 \
radio-mac=00:00:00:00:00:00 radio-name=4A8F5A1772C2
add configuration=ХХХХ5-Ch52 disabled=no l2mtu=1600 mac-address=\
48:8F:5A:17:72:C3 master-interface=none name=CO-AP03-2 radio-mac=\
48:8F:5A:17:72:C3 radio-name=488F5A1772C3
4A:8F:5A:17:72:C3 master-interface=CO-AP03-2 name=CO-AP03-2-1 \
radio-mac=00:00:00:00:00:00 radio-name=4A8F5A1772C3
48:8F:5A:17:6F:EA master-interface=none name=CO-AP04-1 radio-mac=\
48:8F:5A:17:6F:EA radio-name=488F5A176FEA
4A:8F:5A:17:6F:EA master-interface=CO-AP04-1 name=CO-AP04-1-1 \
radio-mac=00:00:00:00:00:00 radio-name=4A8F5A176FEA
add configuration=ХХХХ5-Ch36 disabled=no l2mtu=1600 mac-address=\
48:8F:5A:17:6F:EB master-interface=none name=CO-AP04-2 radio-mac=\
48:8F:5A:17:6F:EB radio-name=488F5A176FEB
4A:8F:5A:17:6F:EB master-interface=CO-AP04-2 name=CO-AP04-2-1 \
radio-mac=00:00:00:00:00:00 radio-name=4A8F5A176FEB
48:8F:5A:17:6F:DC master-interface=none name=CO-AP05-1 radio-mac=\
48:8F:5A:17:6F:DC radio-name=488F5A176FDC
4A:8F:5A:17:6F:DC master-interface=CO-AP05-1 name=CO-AP05-1-1 \
radio-mac=00:00:00:00:00:00 radio-name=4A8F5A176FDC
48:8F:5A:17:6F:DD master-interface=none name=CO-AP05-2 radio-mac=\
48:8F:5A:17:6F:DD radio-name=488F5A176FDD
4A:8F:5A:17:6F:DD master-interface=CO-AP05-2 name=CO-AP05-2-1 \
radio-mac=00:00:00:00:00:00 radio-name=4A8F5A176FDD
48:8F:5A:EE:84:50 master-interface=none name=CO-AP06-1 radio-mac=\
48:8F:5A:EE:84:50 radio-name=488F5AEE8450
4A:8F:5A:EE:84:50 master-interface=CO-AP06-1 name=CO-AP06-1-1 \
radio-mac=00:00:00:00:00:00 radio-name=4A8F5AEE8450
add configuration=ХХХХ5-Ch56 disabled=no l2mtu=1600 mac-address=\
48:8F:5A:EE:84:51 master-interface=none name=CO-AP06-2 radio-mac=\
48:8F:5A:EE:84:51 radio-name=488F5AEE8451
4A:8F:5A:EE:84:51 master-interface=CO-AP06-2 name=CO-AP06-2-1 \
radio-mac=00:00:00:00:00:00 radio-name=4A8F5AEE8451
48:8F:5A:EE:84:19 master-interface=none name=CO-AP07-1 radio-mac=\
48:8F:5A:EE:84:19 radio-name=488F5AEE8419
4A:8F:5A:EE:84:19 master-interface=CO-AP07-1 name=CO-AP07-1-1 \
radio-mac=00:00:00:00:00:00 radio-name=4A8F5AEE8419
add configuration=ХХХХ5-Ch44 disabled=no l2mtu=1600 mac-address=\
48:8F:5A:EE:84:1A master-interface=none name=CO-AP07-2 radio-mac=\
48:8F:5A:EE:84:1A radio-name=488F5AEE841A
4A:8F:5A:EE:84:1A master-interface=CO-AP07-2 name=CO-AP07-2-1 \
radio-mac=00:00:00:00:00:00 radio-name=4A8F5AEE841A
48:8F:5A:EE:84:5F master-interface=none name=CO-AP08-1 radio-mac=\
48:8F:5A:EE:84:5F radio-name=488F5AEE845F
4A:8F:5A:EE:84:5F master-interface=CO-AP08-1 name=CO-AP08-1-1 \
radio-mac=00:00:00:00:00:00 radio-name=4A8F5AEE845F
48:8F:5A:EE:84:60 master-interface=none name=CO-AP08-2 radio-mac=\
48:8F:5A:EE:84:60 radio-name=488F5AEE8460
4A:8F:5A:EE:84:60 master-interface=CO-AP08-2 name=CO-AP08-2-1 \
radio-mac=00:00:00:00:00:00 radio-name=4A8F5AEE8460
48:8F:5A:17:75:2A master-interface=none name=CO-AP09-1 radio-mac=\
48:8F:5A:17:75:2A radio-name=488F5A17752A
4A:8F:5A:17:75:2A master-interface=CO-AP09-1 name=CO-AP09-1-1 \
radio-mac=00:00:00:00:00:00 radio-name=4A8F5A17752A
48:8F:5A:17:75:2B master-interface=none name=CO-AP09-2 radio-mac=\
48:8F:5A:17:75:2B radio-name=488F5A17752B
4A:8F:5A:17:75:2B master-interface=CO-AP09-2 name=CO-AP09-2-1 \
radio-mac=00:00:00:00:00:00 radio-name=4A8F5A17752B
48:8F:5A:17:6F:C0 master-interface=none name=CO-AP10-1 radio-mac=\
48:8F:5A:17:6F:C0 radio-name=488F5A176FC0
4A:8F:5A:17:6F:C0 master-interface=CO-AP10-1 name=CO-AP10-1-1 \
radio-mac=00:00:00:00:00:00 radio-name=4A8F5A176FC0
add configuration=ХХХХ5-Ch60 disabled=no l2mtu=1600 mac-address=\
48:8F:5A:17:6F:C1 master-interface=none name=CO-AP10-2 radio-mac=\
48:8F:5A:17:6F:C1 radio-name=488F5A176FC1
4A:8F:5A:17:6F:C1 master-interface=CO-AP10-2 name=CO-AP10-2-1 \
radio-mac=00:00:00:00:00:00 radio-name=4A8F5A176FC1
48:8F:5A:EE:A2:FA master-interface=none name=CO-AP11-1 radio-mac=\
48:8F:5A:EE:A2:FA radio-name=488F5AEEA2FA
4A:8F:5A:EE:A2:FA master-interface=CO-AP11-1 name=CO-AP11-1-1 \
radio-mac=00:00:00:00:00:00 radio-name=4A8F5AEEA2FA
48:8F:5A:EE:A2:FB master-interface=none name=CO-AP11-2 radio-mac=\
48:8F:5A:EE:A2:FB radio-name=488F5AEEA2FB
4A:8F:5A:EE:A2:FB master-interface=CO-AP11-2 name=CO-AP11-2-1 \
radio-mac=00:00:00:00:00:00 radio-name=4A8F5AEEA2FB
48:8F:5A:EE:84:D6 master-interface=none name=CO-AP12-1 radio-mac=\
48:8F:5A:EE:84:D6 radio-name=488F5AEE84D6
4A:8F:5A:EE:84:D6 master-interface=CO-AP12-1 name=CO-AP12-1-1 \
radio-mac=00:00:00:00:00:00 radio-name=4A8F5AEE84D6
48:8F:5A:EE:84:D7 master-interface=none name=CO-AP12-2 radio-mac=\
48:8F:5A:EE:84:D7 radio-name=488F5AEE84D7
4A:8F:5A:EE:84:D7 master-interface=CO-AP12-2 name=CO-AP12-2-1 \
radio-mac=00:00:00:00:00:00 radio-name=4A8F5AEE84D7
/system logging action
add name=Log remote=10.25.10.252 target=remote
/user group
set read policy="local,read,test,winbox,sniff,sensitive,romon,!telnet,!ssh,!ft\
p,!reboot,!write,!policy,!password,!web,!api,!dude,!tikapp"
set full policy="local,telnet,ssh,ftp,reboot,read,write,policy,test,winbox,pas\
sword,web,sniff,sensitive,api,romon,dude,tikapp"
/caps-man access-list
add action=reject allow-signal-out-of-range=10s comment=reject-acl disabled=\
no signal-range=-120..-85 ssid-regexp=ХХХХ5 time=\
0s-1d,sun,mon,tue,wed,thu,fri,sat
add action=accept allow-signal-out-of-range=10s comment=accept-acl disabled=\
no signal-range=-84..120 ssid-regexp=ХХХХ5 time=\
/caps-man manager
set enabled=yes
/caps-man provisioning
add action=create-enabled comment="AP01 5gHz" hw-supported-modes=ac,an \
master-configuration=ХХХХ5-Ch48 name-format=identity radio-mac=\
48:8F:5A:17:6F:E4 slave-configurations=guest_wifi
add action=create-enabled comment="AP02 5gHz" hw-supported-modes=an,ac \
master-configuration=ХХХХ5-Ch40 name-format=identity radio-mac=\
48:8F:5A:17:72:A7 slave-configurations=guest_wifi
add action=create-enabled comment="AP03 5gHz" hw-supported-modes=an,ac \
master-configuration=ХХХХ5-Ch52 name-format=identity radio-mac=\
48:8F:5A:17:72:C3 slave-configurations=guest_wifi
add action=create-enabled comment="AP04 5gHz" hw-supported-modes=ac,an \
master-configuration=ХХХХ5-Ch36 name-format=identity radio-mac=\
48:8F:5A:17:6F:EB slave-configurations=guest_wifi
add action=create-enabled comment="AP05 5gHz" hw-supported-modes=an,ac \
48:8F:5A:17:6F:DD slave-configurations=guest_wifi
add action=create-enabled comment="AP06 5gHz" hw-supported-modes=an,ac \
master-configuration=ХХХХ5-Ch56 name-format=identity radio-mac=\
48:8F:5A:EE:84:51 slave-configurations=guest_wifi
add action=create-enabled comment="AP07 5gHz" hw-supported-modes=an,ac \
master-configuration=ХХХХ5-Ch44 name-format=identity radio-mac=\
48:8F:5A:EE:84:1A slave-configurations=guest_wifi
add action=create-enabled comment="AP08 5gHz" hw-supported-modes=an,ac \
48:8F:5A:EE:84:60 slave-configurations=guest_wifi
add action=create-enabled comment="AP09 5gHz" hw-supported-modes=an,ac \
48:8F:5A:17:75:2B slave-configurations=guest_wifi
add action=create-enabled comment="AP10 5gHz" hw-supported-modes=an,ac \
master-configuration=ХХХХ5-Ch60 name-format=identity radio-mac=\
48:8F:5A:17:6F:C1 slave-configurations=guest_wifi
add action=create-enabled comment="AP11 5gHz" hw-supported-modes=an,ac \
48:8F:5A:EE:A2:FB slave-configurations=guest_wifi
add action=create-enabled comment="AP12 5gHz" hw-supported-modes=ac,an \
48:8F:5A:EE:84:D7 slave-configurations=guest_wifi
add action=create-enabled comment="AP01 2.4gHz" hw-supported-modes=gn \
master-configuration="2.4GHz ch1- ХХХХ" name-format=identity radio-mac=\
48:8F:5A:17:6F:E3 slave-configurations=guest_wifi
add action=create-enabled comment="AP02 2.4GHz" hw-supported-modes=gn \
master-configuration="2.4GHz ch11 ХХХХ" name-format=identity radio-mac=\
48:8F:5A:17:72:A6 slave-configurations=guest_wifi
add action=create-enabled comment="AP03 2.4GHz" hw-supported-modes=gn \
master-configuration="2.4gHz ch 6 - ХХХХ" name-format=identity radio-mac=\
48:8F:5A:17:72:C2 slave-configurations=guest_wifi
add action=create-enabled comment="AP04 2.4GHz" hw-supported-modes=gn \
48:8F:5A:17:6F:EA slave-configurations=guest_wifi
add action=create-enabled comment="AP05 2.4GHz" hw-supported-modes=gn \
48:8F:5A:17:6F:DC slave-configurations=guest_wifi
add action=create-enabled comment="AP06 2.4GHz" hw-supported-modes=gn \
48:8F:5A:EE:84:50 slave-configurations=guest_wifi
add action=create-enabled comment="AP07 2.4GHz" hw-supported-modes=gn \
48:8F:5A:EE:84:19 slave-configurations=guest_wifi
add action=create-enabled comment="AP08 2.4GHz" hw-supported-modes=gn \
48:8F:5A:EE:84:5F slave-configurations=guest_wifi
add action=create-enabled comment="AP09 2.4GHz" hw-supported-modes=gn \
48:8F:5A:17:75:2A slave-configurations=guest_wifi
add action=create-enabled comment="AP10 2.4GHz" hw-supported-modes=gn \
48:8F:5A:17:6F:C0 slave-configurations=guest_wifi
add action=create-enabled comment="AP11 2.4GHz" hw-supported-modes=gn \
48:8F:5A:EE:A2:FA slave-configurations=guest_wifi
add action=create-enabled comment="AP12 2.4GHz" hw-supported-modes=gn \
48:8F:5A:EE:84:D6 slave-configurations=guest_wifi
add action=create-dynamic-enabled hw-supported-modes=b,gn \
master-configuration=cfg-NHG name-format=identity slave-configurations=\
guest_wifi
add action=create-dynamic-enabled hw-supported-modes=ac,an \
master-configuration=cfg5-NHG name-format=identity slave-configurations=\
guest_wifi
add bridge=bridge-LAN comment=defconf interface=ether1
add bridge=bridge-LAN comment=defconf interface=ether2
add bridge=bridge-LAN comment=defconf interface=ether3
add bridge=bridge-LAN comment=defconf interface=ether4
add bridge=bridge-LAN comment=defconf interface=ether5
add bridge=bridge-LAN comment=defconf interface=ether6
add bridge=bridge-LAN comment=defconf interface=ether7
add bridge=bridge-LAN comment=defconf interface=ether8
add bridge=bridge-LAN comment=defconf interface=ether9
add bridge=bridge-LAN comment=defconf interface=ether10
add bridge=bridge-LAN comment=defconf interface=ether11
add bridge=bridge-LAN comment=defconf interface=ether12
add bridge=bridge-LAN comment=defconf interface=ether13
add bridge=bridge-LAN comment=defconf interface=ether14
add bridge=bridge-LAN comment=defconf interface=ether15
add bridge=bridge-LAN comment=defconf interface=ether16
add bridge=bridge-LAN comment=defconf interface=ether17
add bridge=bridge-LAN comment=defconf interface=ether18
add bridge=bridge-LAN comment=defconf interface=ether19
add bridge=bridge-LAN comment=defconf interface=ether20
add bridge=bridge-LAN comment=defconf interface=ether21
add bridge=bridge-LAN comment=defconf interface=ether22
add bridge=bridge-LAN comment=defconf interface=ether23
add bridge=bridge-LAN comment=defconf interface=ether24
add bridge=bridge-LAN comment=defconf interface=sfp-sfpplus1
add bridge=bridge-LAN comment=defconf interface=sfp-sfpplus2
add bridge=bridge-LAN comment=defconf interface=sfp-sfpplus3
add bridge=bridge-LAN comment=defconf interface=sfp-sfpplus4
"5Ghz - Channel 36"
"5Ghz - Channel 44"
"5Ghz - Channel 48"
"5Ghz - Channel 52"
"5Ghz - Channel 60"
100
/interface vlan
/caps-man datapath
datapath_guest_wifi
/caps-man security
ХХХХ_2021!
0,1,2,3
ХХХХ5
ХХХХ5
ХХХХ5
ХХХХ5
ХХХХ5
ХХХХ5
ssid=ХХХХ5
ХХХХ5
ХХХХ5
tx-chains=0,1,2,3
GuestWiFi
/caps-man interface
/user group
/caps-man manager
set enabled=yes
guest_wifi
guest_wifi
