всех с наступившим новым годом!
Прошу сразу не бить сапогом в живот по моему вопросу,
по случаю достался для домашнего использования RB952Ui-5ac2nD, в место почившего DIR615.
5гигагерцовый диапазон и все такое - решил поставлю.
Настроил с нуля конфигурацию по мануалам с просторов сети:
# jan/01/2020 22:10:18 by RouterOS 6.46.1
# software id = VGD1-XWV0
# model = RB952Ui-5ac2nD
# serial number = 92490A744F30
add fast-forward=no name=bridge_lan
set [ find default-name=ether2 ] name=lan1
set [ find default-name=ether3 ] name=lan2
set [ find default-name=ether4 ] name=lan3
set [ find default-name=ether5 ] advertise=10M-half,10M-full,100M-half,100M-full,1000M-half,1000M-full name=lan4 poe-out=off
set [ find default-name=ether1 ] advertise=10M-half,10M-full,100M-half,100M-full,1000M-half,1000M-full name=wan
set [ find default-name=wlan1 ] adaptive-noise-immunity=ap-and-client-mode antenna-gain=0 band=2ghz-onlyn channel-width=20/40mhz-XX country=russia disabled=no distance=indoors frequency=auto hw-protection-mode=rts-cts keepalive-frames=disabled mode=\
ap-bridge multicast-buffering=disabled multicast-helper=disabled name=wlan2GHz noise-floor-threshold=-110 ssid=ALkA2 wireless-protocol=802.11 wmm-support=enabled wps-mode=disabled
set [ find default-name=wlan2 ] adaptive-noise-immunity=ap-and-client-mode antenna-gain=0 band=5ghz-onlyac channel-width=20/40/80mhz-XXXX country=russia disabled=no distance=indoors frequency=auto hw-protection-mode=rts-cts keepalive-frames=disabled \
mode=ap-bridge multicast-buffering=disabled multicast-helper=disabled name=wlan5GHz ssid=ALkA5 wireless-protocol=802.11 wps-mode=disabled
/interface wireless nstreme
set wlan2GHz enable-polling=no
set wlan5GHz enable-polling=no
/interface list
add name=WAN
add name=LAN
set [ find default=yes ] authentication-types=wpa2-psk disable-pmkid=yes eap-methods="" mode=dynamic-keys supplicant-identity=MikroTik
/ip hotspot profile
add name=pool_dhcp ranges=192.168.0.101-192.168.0.150
add address-pool=pool_dhcp disabled=no interface=bridge_lan lease-time=30m name=server_dhcp
/tool user-manager customer
set admin access=own-routers,own-users,own-profiles,own-limits,config-payment-gw
/interface bridge filter
add action=drop chain=output mac-protocol=ip out-interface=wlan2GHz packet-type=multicast
add action=drop chain=output mac-protocol=ip out-interface=wlan5GHz packet-type=multicast
add action=drop chain=output out-interface=lan1 packet-type=multicast
add action=drop chain=output out-interface=lan2 packet-type=multicast
add action=drop chain=output out-interface=lan3 packet-type=multicast
add bridge=bridge_lan interface=lan1
add bridge=bridge_lan interface=lan2
add bridge=bridge_lan interface=lan3
add bridge=bridge_lan interface=lan4 priority=0x50
add bridge=bridge_lan interface=wlan2GHz
add bridge=bridge_lan interface=wlan5GHz
add bridge=bridge_lan disabled=yes interface=wan
/interface list member
add interface=wan list=WAN
add interface=bridge_lan list=LAN
add address=192.168.0.1/24 interface=bridge_lan network=192.168.0.0
add address=1.0.0.1/30 interface=wan network=1.0.0.0
add disabled=no interface=wan
/ip dhcp-server lease
add address=192.168.0.50 client-id=ALkABook mac-address=00:90:A9:B0:F1:8E server=server_dhcp
add address=192.168.0.0/24 dns-server=192.168.0.1 gateway=192.168.0.1
set allow-remote-requests=yes
add action=accept chain=input in-interface=wan protocol=igmp
add action=accept chain=forward dst-port="" in-interface=wan protocol=udp
add action=drop chain=input connection-state=invalid,new in-interface=wan
add action=masquerade chain=srcnat src-address=192.168.0.0/24
/ip firewall service-port
set irc disabled=yes
set sip disabled=yes
/ip service
set telnet disabled=yes
set ftp disabled=yes
set ssh disabled=yes
set api disabled=yes
set api-ssl disabled=yes
/ip upnp
set enabled=yes
/ip upnp interfaces
add interface=wan type=external
add interface=bridge_lan type=internal
/routing igmp-proxy
set query-interval=5s quick-leave=yes
/routing igmp-proxy interface
add alternative-subnets=0.0.0.0/0 interface=wan upstream=yes
set time-zone-name=Europe/Ulyanovsk
/tool user-manager database
set db-path=flash/user-manager
/interface list
add name=WAN
add name=LAN
/ip hotspot profile
/ip service
/ip upnp
set enabled=yes
/ip upnp interfaces
/routing igmp-proxy
Грешил на недостаток ширины канала провайдера, но попробовал в конфигурации:
# jan/01/2020 21:46:27 by RouterOS 6.46.1
# serial number = 92490A******
/interface list
add name=WAN
add name=LAN
/ip hotspot profile
add bridge=bridge_lan interface=wan
# DHCP client can not run on slave interface!
# in/out-interface matcher not possible when interface (wan) is slave - use master instead (bridge_lan)
/ip service
/ip upnp
set enabled=yes
/ip upnp interfaces
/routing igmp-proxy
/interface list
add name=WAN
add name=LAN
/ip hotspot profile
/ip service
/ip upnp
set enabled=yes
/ip upnp interfaces
/routing igmp-proxy
на данный момоент подключена только приставка на порт 4, и юзеры на wifi обоих диапазонов,
все остальное отключено (в частности сетевой накопитель 192.168.0.50)
Что делаю не так?
Спасибо!
