Со стороны клиента все хорошо, видим удаленную сеть.
Со стороны сервера видим только микротик по ip клиента.
Фаервол временно отключен
# oct/28/2019 18:46:05 by RouterOS 6.44.1
# software id = R8RK-BVJV
# model = RB951Ui-2nD
# serial number = *
add admin-mac=74:4D:28:95:71:8D auto-mac=no comment=defconf name=bridge
set [ find default-name=wlan1 ] band=2ghz-b/g/n channel-width=20/40mhz-XX \
disabled=no distance=indoors frequency=auto mode=ap-bridge ssid=Dor2 \
wireless-protocol=802.11
/interface list
add comment=defconf name=WAN
add comment=defconf name=LAN
set [ find default=yes ] authentication-types=wpa-psk,wpa2-psk mode=\
dynamic-keys supplicant-identity=MikroTik wpa-pre-shared-key=[*]\
wpa2-pre-shared-key=[*]
/ip hotspot profile
/ip ipsec profile
set [ find default=yes ] dh-group=modp1024 enc-algorithm=des
/ip ipsec proposal
set [ find default=yes ] auth-algorithms=sha1,md5 enc-algorithms=3des,des \
pfs-group=none
add name=dhcp ranges=192.168.7.10-192.168.7.254
add address-pool=dhcp disabled=no interface=bridge name=defconf
/ppp profile
set *0 local-address=192.168.101.5 use-compression=yes use-encryption=yes \
use-mpls=yes use-upnp=yes
set *FFFFFFFE change-tcp-mss=default use-compression=yes use-mpls=yes
/interface l2tp-client
add allow=pap connect-to=[*]disabled=no ipsec-secret=[*]\
keepalive-timeout=30 name=l2tp-out1 password=[*]profile=default \
use-ipsec=yes user=[*]
/interface list member
add list=WAN
add address=192.168.7.1/24 comment=defconf interface=ether2 network=192.168.7.0
/ip cloud
set ddns-update-interval=30m update-time=no
add comment=defconf dhcp-options=hostname,clientid disabled=no interface=ether1
add dhcp-options=hostname,clientid disabled=no
add address=192.168.7.0/24 comment=defconf gateway=192.168.7.1 netmask=24
set allow-remote-requests=yes
/ip dns static
add address=192.168.7.1 name=router.lan
add action=accept chain=input
add action=accept chain=output
invalid
in-interface-list=!LAN
ipsec-policy=in,ipsec
ipsec-policy=out,ipsec
add action=drop chain=forward comment="defconf: drop invalid" connection-state=\
invalid
add action=masquerade chain=srcnat comment="defconf: masquerade" disabled=yes \
ipsec-policy=out,none out-interface-list=WAN
add action=masquerade chain=srcnat dst-address=192.168.100.0/24 out-interface=\
all-ppp src-address=192.168.7.0/24
add check-gateway=ping distance=2 dst-address=192.168.100.0/24 gateway=\
l2tp-out1 pref-src=192.168.101.5
/system identity
set name=MikroTik
/tool mac-server
/tool mac-server mac-winbox
# serial number = *
/interface list
/ip hotspot profile
/ip ipsec profile
/ip ipsec proposal
pfs-group=none
/ppp profile
add list=WAN
/ip cloud
/ip dns static
invalid
invalid
/system identity
set name=MikroTik
/tool mac-server
