Привет.
нужна помощь..
есть два микротика . основной и репитор (со своим DHCP)
проблема такова...
на втором микроике (который находиться на другом этаже) есть офис, всем пользователям которого запрещается лазить на сайтах кроме whatsupp, instagram, youtube. Кстати все они на телефонах.
# dec/13/2018 11:37:26 by RouterOS 6.43.7
# software id = GNYE-Q0GK
# model = 951Ui-2HnD
# serial number = 000000000000000
add admin-mac=00000000000 auto-mac=no name=bridge-local
set [ find default-name=ether1 ] advertise=\
10M-half,10M-full,100M-half,100M-full,1000M-half,1000M-full comment=WAN
set [ find default-name=ether2 ] advertise=\
10M-half,10M-full,100M-half,100M-full,1000M-half,1000M-full comment=LAN
set [ find default-name=ether3 ] advertise=\
set [ find default-name=ether4 ] advertise=\
set [ find default-name=ether5 ] advertise=\
add authentication-types=wpa-psk,wpa2-psk eap-methods="" \
management-protection=allowed mode=dynamic-keys name=Tuyuk \
supplicant-identity="" wpa-pre-shared-key=tuyuk@2018 wpa2-pre-shared-key=\
tuyuk@2018
set [ find default-name=wlan1 ] band=2ghz-b/g/n disabled=no mode=ap-bridge \
security-profile=Tuyuk ssid=Tuyuk
add name=dhcp_pool1 ranges=192.168.8.100-192.168.8.250
add address-pool=dhcp_pool1 disabled=no interface=bridge-local name=dhcp1
add bridge=bridge-local interface=ether2
add bridge=bridge-local interface=ether3
add address=192.168.1.189/24 interface=ether1 network=192.168.1.0
add address=192.168.8.254/24 interface=bridge-local network=192.168.8.0
add address=192.168.8.0/24 gateway=192.168.8.254
set allow-remote-requests=yes servers=8.8.8.8
/ip dns static
add address=192.168.88.1 name=router.lan
/ip firewall address-list
add address=whatsapp.com list=eljur
add address=instagram.com list=eljur
add address=youtube.com list=eljur
add action=accept chain=input dst-port=8291 in-interface=ether1 protocol=tcp
add action=reject chain=forward disabled=yes dst-address-list=!eljur \
protocol=tcp reject-with=tcp-reset src-address=192.168.8.0/24
add action=drop chain=forward dst-address-list=!eljur protocol=udp \
add action=accept chain=input connection-state=established in-interface=\
ether1
add action=accept chain=input connection-state=related in-interface=ether1
add action=drop chain=input in-interface=ether1
add distance=1 gateway=192.168.1.254
set time-zone-name=Asia/Bishkek
почему то блокирует весь трафик.
Помогите разобраться.
Либо есть альтернативные способы запрета всех "сайтов кроме..."
С уважением Nukew
Микротик 951Ui-2HnD сайты (запрет на все кроме...)
По сути эти правила читаются как Запретить весь tcp и udp Трафик из сети 192.168.88.0/24 кроме запросов на адреса в листе eljur
Тобиш этими правилами вы разрешили ходить только на адреса которые в листе eljur
