cAP AC частые дисконекты
jumpline
Привет, достаточно долго борюсь с проблемой отваливания клиентов от точки, никак не получается победить, может кто подскажет..
add authentication-types=wpa2-psk eap-methods="" mode=dynamic-keys name=ap \
supplicant-identity="" wpa-pre-shared-key=*** wpa2-pre-shared-key=\
add authentication-types=wpa2-psk eap-methods="" group-key-update=1h mode=\
dynamic-keys name=free-wifi supplicant-identity="" wpa2-pre-shared-key=\
band=2ghz-onlyn channel-width=20/40mhz-Ce country=russia3 disabled=no \
distance=indoors frequency=2437 frequency-mode=regulatory-domain \
guard-interval=long hw-protection-mode=rts-cts keepalive-frames=disabled \
mode=ap-bridge multicast-buffering=disabled multicast-helper=full \
security-profile=ap ssid=*** tx-power=14 tx-power-mode=all-rates-fixed \
wireless-protocol=802.11 wmm-support=enabled wps-mode=disabled
set [ find default-name=wlan2 ] adaptive-noise-immunity=ap-and-client-mode \
band=5ghz-a/n/ac channel-width=20/40/80mhz-eCee country=russia3 disabled=no \
disconnect-timeout=5s distance=indoors frequency=5200 frequency-mode=\
regulatory-domain guard-interval=long hw-protection-mode=rts-cts mode=\
ap-bridge multicast-buffering=disabled multicast-helper=disabled \
on-fail-retry-time=1s security-profile=ap ssid=*** tx-power=14 \
tx-power-mode=all-rates-fixed wireless-protocol=802.11 wmm-support=enabled \
wps-mode=disabled
add comment=guest disabled=no keepalive-frames=disabled mac-address=\
CE:2D:E0:BC:6D:B3 master-interface=wlan1 multicast-buffering=disabled name=\
wlan3 security-profile=free-wifi ssid=*** wds-cost-range=0 \
wds-default-cost=0 wps-mode=disabled
/interface wireless manual-tx-power-table
set wlan3 comment=guest
/interface wireless nstreme
set wlan1 enable-polling=no
set wlan2 enable-polling=no
vbsev
jumpline писал(а): 20 авг 2018, 12:42 tx-power=14 tx-power-mode=all-rates-fixed
День добрый.
Судя по картинке устройства подключаются с хорошим уровнем сигнала.
Не знаю на каком расстоянии от точки клиентские устройства находятся, но на мой взгляд 25мВт маловато. Хотя бы 17dBm поставить.
Band указан only N - устройства которые отваливаются не древние, поддерживают этот режим? Если b/g/n поставить - ситуация такая же?
jumpline
vbsev писал(а): 20 авг 2018, 22:36
День добрый.
Клиенты сидят ан расстоянии 2-10 метров от точки, wlan1 собственно не интересует, т.к. там принтеры и мобильники на нем висят, главная проблема в том, что отваливаются клиенты от 5ггц сети.
jumpline
День добрый.
да забыл добавить, точка в центре помещения, клиенты находятся в прямой видимости.
