Есть объявленные функции
#address-list to ip
global ALtoIP do={
set $1 [ip firewall address-list print as-value where list=$1]
set $1 [tostr $1]
local start [find $1 "address="]
local end [find $1 ";comment="]
set $1 [pick [tostr $1] ($start+8) ($end)]
set $1 [toip $1]
#put ([typeof $1] . "=" . $1)
return $1
global IPtoMAC do={
set $1 [ip dhcp-server lease print as-value where active-address=$1]
set $1 [tostr $1]
local start [find $1 "mac-address="]
local end [find $1 ";server="]
set $1 [pick [tostr $1] ($start+12) ($end)]
#put ("mac=" . $1)
return $1
global WAKEonLAN do={
tool wol [$IPtoMAC [$ALtoIP "PC_wakeup"]]
@MikroTik] > $WAKEonLAN
invalid value of mac, mac address required
хотя MAC там передаётся
@MikroTik] > put [$IPtoMAC [$ALtoIP "PC_wakeup"]]
B4:2E:99:91:A2:7E
И при выполнении в командной строке не ругается(работает или нет неизвестно т.к. на компе wake on lan ещё не включен)
@MikroTik] > tool wol [$IPtoMAC [$ALtoIP "PC_wakeup"]]
[***@MikroTik] >
