не работает WI-FI
Обсуждение ОС и пр.
haba
Re: не работает WI-FI
Сообщение haba » 06 сен 2012, 10:48
как-то так
# sep/ 6/2012 11:32:46 by RouterOS 5.20
# software id = M87A-ZMN2
# NAME TYPE SIZE CREATION-TIME
0 SYSTEM_5.NPK package 11 420 392 jan/02/1970 04:05:08
1 ISOLINUX/IS... .CFG file 84 jan/02/1970 04:04:33
2 TRANS.TBL .TBL file 5 204 jan/02/1970 04:05:08
3 KVM_5_12.NPK package 1 102 176 jan/02/1970 04:04:39
4 USER_MAN.NPK package 1 234 748 jan/02/1970 04:05:11
5 log.0.txt .txt file 3 833 sep/06/2012 11:29:44
6 WIRELESS.NPK package 1 459 920 jan/02/1970 04:05:15
7 LCD_5_12.NPK package 62 090 jan/02/1970 04:04:39
8 LICENSE.TXT .TXT file 129 378 jan/02/1970 04:04:39
9 MPLS_5_1.NPK package 246 167 jan/02/1970 04:04:40
10 GPS_5_12.NPK package 15 078 jan/02/1970 04:04:18
11 MULTICAS.NPK package 220 547 jan/02/1970 04:04:40
12 IPV6_5_1.NPK package 443 036 jan/02/1970 04:04:23
13 ISDN_5_1.NPK package 483 373 jan/02/1970 04:04:27
14 ISOLINUX/IN... .RGZ file 840 182 jan/02/1970 04:04:33
15 SECURITY.NPK package 459 424 jan/02/1970 04:04:43
16 ISOLINUX/IS... .BIN file 9 652 jan/02/1970 04:04:33
17 ISOLINUX directory jan/02/1970 04:04:15
18 ISOLINUX/LINUX file 974 752 jan/02/1970 04:04:37
19 UPS_5_12.NPK package 69 862 jan/02/1970 04:05:08
20 DEFPACKS file 48 jan/02/1970 04:04:16
21 HOTSPOT_.NPK package 240 410 jan/02/1970 04:04:20
22 NTP_5_12.NPK package 254 800 jan/02/1970 04:04:41
23 PPP_5_12.NPK package 444 563 jan/02/1970 04:04:41
24 ROUTERBO.NPK package 155 320 jan/02/1970 04:04:41
25 ISOLINUX/BO... .CAT file 2 048 jan/02/1970 04:04:27
26 pub directory jan/02/1970 04:17:20
27 ADVANCED.NPK package 203 801 jan/02/1970 04:04:16
28 CALEA_5_.NPK package 20 953 jan/02/1970 04:04:16
29 ROUTING_.NPK package 454 253 jan/02/1970 04:04:42
30 supout.rif .rif file 296 832 jan/02/1970 04:17:47
31 DHCP_5_1.NPK package 186 822 jan/02/1970 04:04:18
Sep/06/2012 11:34:48 script,warning log.0.txt
Sep/06/2012 11:35:21 system,info device changed by admin
Sep/06/2012 11:35:24 wireless,info 00:16:D4:6C:B1:E6@wlan1: connected
Sep/06/2012 11:35:28 dhcp,info default deassigned 192.168.88.250 from 00:16:D4:6C:B1:E6
Sep/06/2012 11:35:29 dhcp,info default assigned 192.168.88.250 to 00:16:D4:6C:B1:E6
Jan/02/1970 03:00:14 l2tp,ppp,info l2tp-out1: initializing...
Jan/02/1970 03:00:14 l2tp,ppp,info l2tp-out1: dialing...
Jan/02/1970 03:00:14 interface,info ether2-master-local link up (speed 100M, full duplex)
Jan/02/1970 03:00:14 interface,info ether1-gateway link up (speed 100M, full duplex)
Jan/02/1970 03:00:16 system,info dns changed
Jan/02/1970 03:00:16 dhcp,info dhcp-client on ether1-gateway got IP address 10.224.167.3
Jan/02/1970 03:00:18 l2tp,ppp,info l2tp-out1: terminating... - failed to authenticate ourselves to peer
Jan/02/1970 03:00:18 l2tp,ppp,info l2tp-out1: disconnected
Jan/02/1970 03:00:18 l2tp,ppp,info l2tp-out1: initializing...
Jan/02/1970 03:00:18 l2tp,ppp,info l2tp-out1: dialing...
Jan/02/1970 03:00:19 l2tp,ppp,info l2tp-out1: initializing...
Jan/02/1970 03:00:19 l2tp,ppp,info l2tp-out1: dialing...
Jan/02/1970 03:00:19 l2tp,ppp,info l2tp-out1: terminating... - failed to authenticate ourselves to peer
Jan/02/1970 03:00:19 l2tp,ppp,info l2tp-out1: disconnected
Jan/02/1970 03:00:20 l2tp,ppp,info l2tp-out1: initializing...
Jan/02/1970 03:00:20 l2tp,ppp,info l2tp-out1: dialing...
Jan/02/1970 03:00:20 l2tp,ppp,info l2tp-out1: terminating... - failed to authenticate ourselves to peer
Jan/02/1970 03:00:20 l2tp,ppp,info l2tp-out1: disconnected
Jan/02/1970 03:00:23 l2tp,ppp,info l2tp-out1: initializing...
Jan/02/1970 03:00:23 l2tp,ppp,info l2tp-out1: dialing...
Jan/02/1970 03:00:23 l2tp,ppp,info l2tp-out1: authenticated
Jan/02/1970 03:00:23 l2tp,ppp,info l2tp-out1: connected
Jan/02/1970 03:00:28 system,info,account user admin logged in from 192.168.88.251 via winbox
Sep/06/2012 11:37:26 wireless,info A8:92:2C:CB:AE:A3@wlan1: connected
Sep/06/2012 11:37:31 dhcp,info default deassigned 192.168.88.249 from A8:92:2C:CB:AE:A3
Sep/06/2012 11:37:31 dhcp,info default assigned 192.168.88.249 to A8:92:2C:CB:AE:A3
Sep/06/2012 11:37:39 wireless,info A8:92:2C:CB:AE:A3@wlan1: disconnected, received disassoc: sending station leaving (8)
Sep/06/2012 11:38:09 wireless,info A8:92:2C:CB:AE:A3@wlan1: connected
Sep/06/2012 11:38:14 dhcp,info default deassigned 192.168.88.249 from A8:92:2C:CB:AE:A3
Sep/06/2012 11:38:14 dhcp,info default assigned 192.168.88.249 to A8:92:2C:CB:AE:A3
Jan/02/1970 03:00:15 interface,info ether2-master-local link up (speed 100M, full duplex)
Jan/02/1970 03:00:16 interface,info ether1-gateway link up (speed 100M, full duplex)
Jan/02/1970 03:00:21 l2tp,ppp,info l2tp-out1: dialing...
Jan/02/1970 03:00:21 l2tp,ppp,info l2tp-out1: terminating... - failed to authenticate ourselves to peer
Jan/02/1970 03:00:21 l2tp,ppp,info l2tp-out1: disconnected
Jan/02/1970 03:00:22 system,info,account user admin logged in from 192.168.88.251 via winbox
Jan/02/1970 03:00:24 l2tp,ppp,info l2tp-out1: initializing...
Jan/02/1970 03:00:24 l2tp,ppp,info l2tp-out1: dialing...
Jan/02/1970 03:00:27 system,info device changed by admin
Jan/02/1970 03:00:48 l2tp,ppp,info l2tp-out1: terminating... - session closed
Jan/02/1970 03:00:48 l2tp,ppp,info l2tp-out1: disconnected
Jan/02/1970 03:00:55 l2tp,ppp,info l2tp-out1: initializing...
Jan/02/1970 03:00:55 l2tp,ppp,info l2tp-out1: dialing...
Jan/02/1970 03:00:55 l2tp,ppp,info l2tp-out1: authenticated
Jan/02/1970 03:00:55 l2tp,ppp,info l2tp-out1: connected
Sep/06/2012 11:40:30 system,info log action added by admin
Sep/06/2012 11:41:19 system,info log rule added by admin
Sep/06/2012 11:42:07 system,info log rule added by admin
Sep/06/2012 11:42:31 system,info log rule added by admin
Sep/06/2012 11:42:58 system,info device changed by admin
Sep/06/2012 11:43:04 wireless,info 00:16:D4:6C:B1:E6@wlan1: connected
Sep/06/2012 11:43:07 dhcp,info default deassigned 192.168.88.250 from 00:16:D4:6C:B1:E6
Sep/06/2012 11:43:07 dhcp,info default assigned 192.168.88.250 to 00:16:D4:6C:B1:E6
Jan/02/1970 03:00:15 l2tp,ppp,info l2tp-out1: initializing...
Jan/02/1970 03:00:15 l2tp,ppp,info l2tp-out1: dialing...
Jan/02/1970 03:00:16 interface,info ether2-master-local link up (speed 100M, full duplex)
Jan/02/1970 03:00:17 system,info dns changed
Jan/02/1970 03:00:18 dhcp,info dhcp-client on ether1-gateway got IP address 10.224.167.3
Jan/02/1970 03:00:21 l2tp,ppp,info l2tp-out1: initializing...
Jan/02/1970 03:00:22 l2tp,ppp,info l2tp-out1: dialing...
Jan/02/1970 03:00:22 l2tp,ppp,info l2tp-out1: terminating... - failed to authenticate ourselves to peer
Jan/02/1970 03:00:22 l2tp,ppp,info l2tp-out1: disconnected
Jan/02/1970 03:00:25 l2tp,ppp,info l2tp-out1: initializing...
Jan/02/1970 03:00:25 l2tp,ppp,info l2tp-out1: dialing...
Jan/02/1970 03:00:25 l2tp,ppp,info l2tp-out1: authenticated
Jan/02/1970 03:00:25 l2tp,ppp,info l2tp-out1: connected
Jan/02/1970 03:00:37 wireless,info 00:16:D4:6C:B1:E6@wlan1: connected
aliant
Сообщение aliant » 06 сен 2012, 11:11
скрин бы еще варлеса
haba
Сообщение haba » 06 сен 2012, 11:32
вот
(128.39 КБ) 18 скачиваний
(94.19 КБ) 18 скачиваний
(100.1 КБ) 19 скачиваний
haba
Сообщение haba » 06 сен 2012, 11:34
и вот
(83.07 КБ) 18 скачиваний
