"Не заводится" DHCP-сервер на RouterBOARD 450G
Mr.Marmaduke
Сообщение Mr.Marmaduke » 13 сен 2011, 11:01
Взяли на пробу один RouterBOARD 450G, начал с ним разбираться и сразу наткнулся на какую-то странную проблему:
[egor@MikroTik] > ip addr print
 #   ADDRESS            NETWORK         BROADCAST       INTERFACE
 0  XXX.XXX.95.12/29   XXX.XXX.95.8    XXX.XXX.95.15    ether1-gateway
 1   192.168.1.1/24     192.168.1.0     192.168.1.255   ether2-local
[egor@MikroTik] > ip pool add name=ether2-pool ranges=192.168.1.65-192.168.1.254
[egor@MikroTik] > ip dhcp-server add name=ether2-dhcp address-pool=ether2-pool interface=ether2-local disabled=no
[egor@MikroTik] > ip dhcp-server network add address=192.168.1.0/24 gateway=192.168.1.1 dns-server=192.168.1.1 comment="Ethernet2 DHCP server"
failure: such network already exists
Через ip dhcp-server setup тот же самый результат. Что я неправильно делаю?
[egor@MikroTik] > system routerboard print
       routerboard: yes
             model: "450G"
     serial-number: "XXXXXXXXXXXX"
  current-firmware: "2.29"
  upgrade-firmware: "2.27"
Mr.Marmaduke
Re: "Не заводится" DHCP-сервер на RouterBOARD 450G
Сообщение Mr.Marmaduke » 13 сен 2011, 12:04
С причиной той ошибки разобрался, но тем не менее:
[egor@MikroTik] > ip dhcp-server print
Flags: X - disabled, I - invalid
 #   NAME                                           INTERFACE                                         RELAY           ADDRESS-POOL                                         LEASE-TIME ADD-ARP
[egor@MikroTik] > ip dhcp-server network print
 # ADDRESS            GATEWAY         DNS-SERVER      WINS-SERVER     DOMAIN
[egor@MikroTik] > ip pool print
 # NAME        RANGES
[egor@MikroTik] > ip dhcp-server setup
Select interface to run DHCP server on
dhcp server interface: ether2-local
Select network for DHCP addresses
dhcp address space: 192.168.1.0/24
Select gateway for given network
gateway for dhcp network: 192.168.1.1
If this is remote network, enter address of DHCP relay
There is no such IP network on selected interface
dhcp relay: 192.168.1.1
Select pool of ip addresses given out by DHCP server
addresses to give out: 192.168.1.65-192.168.1.254
Select DNS servers
dns servers: 89.207.94.34,89.207.95.18
Select lease time
lease time: 3d
 0 I dhcp1                                          ether2-local                                      192.168.1.1     dhcp_pool1                                           3d
Спрашивается, почему "There is no such IP network on selected interface"?
pmilovidov
Сообщение pmilovidov » 23 сен 2011, 10:14
Mr.Marmaduke писал(а):С причиной той ошибки разобрался, но тем не менее:
 # NAME        RANGES
Select DNS servers
Select lease time
lease time: 3d
Relay не нужен в принципе.
[p@MikroTik] >> ip address print
# ADDRESS NETWORK INTERFACE
0 ;;; LAN
192.168.1.1/24 192.168.1.0 ether2-local-master
такая вещь есть?
