# mar/20/2017 13:58:20 by RouterOS 6.37.1
# software id = ********
add admin-mac=************ arp=reply-only name=bridge-guests-2GHz
add name=bridge-guests-5GHz
add auto-mac=no name=bridge-test
add admin-mac=************ auto-mac=no comment=defconf name=bridge1-lan
set [ find default-name=ether1 ] name=ether1-wan
set [ find default-name=ether2 ] name=ether2-master
set [ find default-name=ether3 ] master-port=ether2-master
set [ find default-name=ether4 ] master-port=ether2-master
set [ find default-name=ether5 ] master-port=ether2-master
/ip neighbor discovery
set ether1-wan discover=no
set sfp1 discover=no
set bridge-guests-2GHz discover=no
set bridge-guests-5GHz discover=no
set bridge-test discover=no
set bridge1-lan comment=defconf
add authentication-types=wpa2-psk eap-methods="" group-key-update=15m \
management-protection=allowed mode=dynamic-keys name=protect-home \
supplicant-identity="" wpa-pre-shared-key=******** wpa2-pre-shared-key=\
management-protection=allowed mode=dynamic-keys name=protect-guests \
wpa-pre-shared-key="*******" wpa2-pre-shared-key="*********"
add authentication-types=wpa-psk,wpa2-psk eap-methods="" \
management-protection=allowed name=free supplicant-identity=""
add authentication-types=wpa2-psk eap-methods="" group-key-update=10m \
management-protection=allowed mode=dynamic-keys name=protect-****** \
supplicant-identity="" wpa2-pre-shared-key="*********"
set [ find default-name=wlan1 ] band=2ghz-b/g/n channel-width=20/40mhz-Ce \
disabled=no distance=indoors frequency=2437 frequency-mode=superchannel \
mode=ap-bridge name=wlan-2GHz security-profile=protect-home ssid=\
MyRouter-2GHz tx-power=24 tx-power-mode=all-rates-fixed \
wireless-protocol=802.11 wps-mode=disabled
set [ find default-name=wlan2 ] band=5ghz-a/n/ac channel-width=20/40mhz-Ce \
disabled=no distance=indoors hw-protection-mode=rts-cts mode=ap-bridge \
name=wlan-5GHz security-profile=protect-home ssid=MyRouter-5GHz tx-power=\
27 tx-power-mode=all-rates-fixed wireless-protocol=802.11 wps-mode=\
disabled
add default-authentication=no default-forwarding=no mac-address=\
************** master-interface=wlan-2GHz mode=ap-bridge name=\
wlan-guests-2GHz security-profile=protect-guests ssid=\
MyRouter-Guests-2GHz wds-cost-range=0-150 wps-mode=disabled
add default-authentication=no default-forwarding=no keepalive-frames=disabled \
mac-address=************** master-interface=wlan-5GHz mode=ap-bridge \
multicast-buffering=disabled name=wlan-guests-5GHz security-profile=\
protect-guests ssid=MyRouter-Guests-5GHz wds-cost-range=0 \
wds-default-cost=0 wps-mode=disabled
mac-address=**************** master-interface=wlan-2GHz mode=ap-bridge \
multicast-buffering=disabled name=wlan-test security-profile=\
protect-***** ssid=******* wds-cost-range=0 wds-default-cost=0 \
wps-mode=disabled
set wlan-guests-2GHz discover=no
set wlan-guests-5GHz discover=no
set wlan-test discover=no
/ip hotspot profile
add name=pool-guests-2GHz ranges=10.1.1.2-10.1.1.50
add name=pool-****** ranges=10.255.255.2-10.255.255.50
add name=pool-guests-5GHz ranges=10.200.200.2-10.200.200.50
add address-pool=dhcp disabled=no interface=bridge1-lan lease-time=12h name=\
defconf
add add-arp=yes address-pool=pool-guests-2GHz disabled=no interface=\
bridge-guests-2GHz lease-time=30m name=dhcp_server-guests-2GHz
add add-arp=yes address-pool=pool-****** disabled=no interface=bridge-test \
lease-time=30m name=dhcp_server-******
add add-arp=yes address-pool=pool-guests-5GHz disabled=no interface=\
bridge-guests-5GHz lease-time=30m name=dhcp_server-guests-5GHz
/queue simple
add burst-limit=1M/3M burst-threshold=1M/2M burst-time=5s/5s max-limit=\
256k/512k name=queue-guests-2GHz target=bridge-guests-2GHz
add burst-limit=2M/3M burst-threshold=1M/2M burst-time=5s/5s max-limit=\
256k/512k name=queue-guests-5GHz target=bridge-guests-5GHz
add burst-limit=64k/64k burst-threshold=64k/64k burst-time=5s/5s max-limit=\
64k/64k name=queue-****** target=bridge-test
add bridge=bridge1-lan comment=defconf interface=ether2-master
add bridge=bridge1-lan comment=defconf interface=sfp1
add bridge=bridge1-lan comment=defconf interface=wlan-2GHz
add bridge=bridge1-lan comment=defconf interface=wlan-5GHz
add bridge=bridge-guests-2GHz interface=wlan-guests-2GHz
add bridge=bridge-test interface=wlan-test
add bridge=bridge-guests-5GHz interface=wlan-guests-5GHz
/interface ethernet switch host
add mac-address=************ redirect-to-cpu=yes share-vlan-learned=no \
switch=switch1 vlan-id=1
/interface wireless access-list
add forwarding=no interface=wlan-guests-2GHz vlan-mode=no-tag
add forwarding=no interface=wlan-test vlan-mode=no-tag
add forwarding=no interface=wlan-guests-5GHz vlan-mode=no-tag
add address=192.168.88.1/24 comment=defconf interface=ether2-master network=\
192.168.88.0
add address=10.1.1.1/24 interface=wlan-guests-2GHz network=10.1.1.0
add address=10.255.255.1/24 interface=wlan-test network=10.255.255.0
add address=10.200.200.1/24 interface=wlan-guests-5GHz network=10.200.200.0
add comment=defconf dhcp-options=hostname,clientid disabled=no interface=\
ether1-wan
add address=10.1.1.0/24 gateway=10.1.1.1 netmask=24
add address=10.200.200.0/24 dns-server=8.8.8.8,10.200.200.1 gateway=\
10.200.200.1 netmask=24
add address=10.255.255.0/24 dns-server=10.255.255.1,8.8.8.8 gateway=\
10.255.255.1 netmask=24
add address=192.168.88.0/24 comment=defconf gateway=192.168.88.1 netmask=24
set allow-remote-requests=yes
/ip dns static
add address=192.168.88.1 name=mikrouter
add address=127.0.0.1 comment=ADBlock name=s1.2mdn.net
add address=127.0.0.1 comment=ADBlock name=s0.2mdn.net
add address=127.0.0.1 comment=ADBlock name=googleads.g.doubleclick.net
add address=127.0.0.1 comment=ADBlock name=pubads.g.doubleclick.net
add address=127.0.0.1 comment=ADBlock name=ad.doubleclick.net
add address=127.0.0.1 comment=ADBlock name=static.doubleclick.net
add address=127.0.0.1 comment=ADBlock name=devads.skypeassets.net
add address=127.0.0.1 comment=ADBlock name=preads.skypeassets.net
add address=127.0.0.1 comment=ADBlock name=qawww.skypeassets.net
add address=127.0.0.1 comment=ADBlock name=static.skypeassets.com
add address=127.0.0.1 comment=ADBlock name=devapps.skype.net
add address=127.0.0.1 comment=ADBlock name=qaapi.skype.net
add address=127.0.0.1 comment=ADBlock name=preapps.skype.net
add address=127.0.0.1 comment=ADBlock name=apps.skype.com
add address=127.0.0.1 comment=ADBlock name=api.skype.com
add address=127.0.0.1 comment=ADBlock name=serving.plexop.net
add address=127.0.0.1 comment=ADBlock name=preg.bforex.com
add address=127.0.0.1 comment=ADBlock name=flex.msn.com
add address=127.0.0.1 comment=ADBlock name=rad.msn.com
add address=127.0.0.1 comment=ADBlock name=live.rads.msn.com
add address=127.0.0.1 comment=ADBlock name=ads1.msn.com
add address=127.0.0.1 comment=ADBlock name=g.msn.com
add address=127.0.0.1 comment=ADBlock name=ac3.msn.com
add address=127.0.0.1 comment=ADBlock name=ads1.msads.net
add address=127.0.0.1 comment=ADBlock name=ads2.msads.net
add address=127.0.0.1 comment=ADBlock name=a.ads2.msads.net
add address=127.0.0.1 comment=ADBlock name=b.ads2.msads.net
add address=127.0.0.1 comment=ADBlock name=sO.2mdn.net
add address=127.0.0.1 comment=ADBlock name=static.2mdn.net
add address=127.0.0.1 comment=ADBlock name=cdn.adnxs.com
add address=127.0.0.1 comment=ADBlock name=cdn.adnxs.com.edgesuite.net
add address=127.0.0.1 comment=ADBlock name=aka-cdn-ns.adtech.de
add address=127.0.0.1 comment=ADBlock name=cdn.atdmt.com
add address=127.0.0.1 comment=ADBlock name=ec.atdmt.com
add address=127.0.0.1 comment=ADBlock name=ad-emea.doubleclick.net
add address=127.0.0.1 comment=ADBlock name=secure.flashtalking.com
add address=127.0.0.1 comment=ADBlock name=msntest.serving-sys.com
add address=127.0.0.1 comment=ADBlock name=cdn.bitmedianetwork.com
add address=127.0.0.1 comment=ADBlock name=static.ap.bittorrent.com
add address=127.0.0.1 comment=ADBlock name=bundles.bittorrent.com
add address=127.0.0.1 comment=ADBlock name=apps.bittorrent.com
add address=127.0.0.1 comment=ADBlock name=ads.bittorrent.com
add address=127.0.0.1 comment=ADBlock name=offers.bittorrent.com
add address=127.0.0.1 comment=ADBlock name=services.bunndle.com
add address=127.0.0.1 comment=ADBlock name=cdn.ap.bittorrent.com
add address=127.0.0.1 comment=ADBlock name=beta.bundles.bittorrent.com
add address=127.0.0.1 comment=ADBlock name=cdn.mbstatic.org
add address=127.0.0.1 comment=ADBlock name=adselector.ru
add address=127.0.0.1 comment=ADBlock name=pluso.ru
add address=127.0.0.1 comment=ADBlock name=flash.begun.ru
add address=127.0.0.1 comment=ADBlock name=ad.adriver.ru
add address=127.0.0.1 comment=ADBlock name=lb.usemaxserver.de
add address=127.0.0.1 comment=ADBlock name=tracking.klickthru.com
add address=127.0.0.1 comment=ADBlock name=gsmtop.net
add address=127.0.0.1 comment=ADBlock name=click.buzzcity.net
add address=127.0.0.1 comment=ADBlock name=ads.admoda.com
add address=127.0.0.1 comment=ADBlock name=stats.pflexads.com
add address=127.0.0.1 comment=ADBlock name=a.glcdn.co
add address=127.0.0.1 comment=ADBlock name=wwww.adleads.com
add address=127.0.0.1 comment=ADBlock name=ad.madvertise.de
add address=127.0.0.1 comment=ADBlock name=apps.buzzcity.net
add address=127.0.0.1 comment=ADBlock name=ads.mobgold.com
add address=127.0.0.1 comment=ADBlock name=android.bcfads.com
add address=127.0.0.1 comment=ADBlock name=show.buzzcity.net
add address=127.0.0.1 comment=ADBlock name=api.analytics.omgpop.com
add address=127.0.0.1 comment=ADBlock name=r.edge.inmobicdn.net
add address=127.0.0.1 comment=ADBlock name=www.mmnetwork.mobi
add address=127.0.0.1 comment=ADBlock name=img.ads.huntmad.com
add address=127.0.0.1 comment=ADBlock name=creative1cdn.mobfox.com
add address=127.0.0.1 comment=ADBlock name=admicro2.vcmedia.vn
add address=127.0.0.1 comment=ADBlock name=admicro1.vcmedia.vn
add address=127.0.0.1 comment=ADBlock name=s3.phluant.com
add address=127.0.0.1 comment=ADBlock name=c.vrvm.com
add address=127.0.0.1 comment=ADBlock name=go.vrvm.com
add address=127.0.0.1 comment=ADBlock name=static.estebull.com
add address=127.0.0.1 comment=ADBlock name=mobile.Banzai.it
add address=127.0.0.1 comment=ADBlock name=ads.xxxad.net
add address=127.0.0.1 comment=ADBlock name=img.ads.mojiva.com
add address=127.0.0.1 comment=ADBlock name=adcontent.saymedia.com
add address=127.0.0.1 comment=ADBlock name=ads.saymedia.com
add address=127.0.0.1 comment=ADBlock name=ftpcontent.worldnow.com
add address=127.0.0.1 comment=ADBlock name=img.ads.mocean.mobi
add address=127.0.0.1 comment=ADBlock name=bigmobileads.com
add address=127.0.0.1 comment=ADBlock name=banners.bigmobileads.com
add address=127.0.0.1 comment=ADBlock name=ads.mopub.com
add address=127.0.0.1 comment=ADBlock name=images.mpression.net
add address=127.0.0.1 comment=ADBlock name=images.millennialmedia.com
add address=127.0.0.1 comment=ADBlock name=oasc04012.247realmedia.com
add address=127.0.0.1 comment=ADBlock name=assets.cntdy.mobi
add address=127.0.0.1 comment=ADBlock name=ad.where.com
add address=127.0.0.1 comment=ADBlock name=i.tapit.com
add address=127.0.0.1 comment=ADBlock name=cdn1.crispadvertising.com
add address=127.0.0.1 comment=ADBlock name=cdn2.crispadvertising.com
add address=127.0.0.1 comment=ADBlock name=medrx.sensis.com.au
add address=127.0.0.1 comment=ADBlock name=rs-staticart.ybcdn.net
add address=127.0.0.1 comment=ADBlock name=img.ads.taptapnetworks.com
add address=127.0.0.1 comment=ADBlock name=adserver.ubiyoo.com
add address=127.0.0.1 comment=ADBlock name=c753738.r38.cf2.rackcdn.com
add address=127.0.0.1 comment=ADBlock name=edge.reporo.net
add address=127.0.0.1 comment=ADBlock name=adultmoda.com
add address=127.0.0.1 comment=ADBlock name=ads.smartdevicemedia.com
add address=127.0.0.1 comment=ADBlock name=b.scorecardresearch.com
add address=127.0.0.1 comment=ADBlock name=m.adsymptotic.com
add address=127.0.0.1 comment=ADBlock name=cdn.vdopia.com
add address=127.0.0.1 comment=ADBlock name=api.yp.com
add address=127.0.0.1 comment=ADBlock name=asotrack1.fluentmobile.com
add address=127.0.0.1 comment=ADBlock name=android-sdk31.transpera.com
add address=127.0.0.1 comment=ADBlock name=apps.mobilityware.com
add address=127.0.0.1 comment=ADBlock name=ads.mobilityware.com
add address=127.0.0.1 comment=ADBlock name=ads.admarvel.com
add address=127.0.0.1 comment=ADBlock name=netdna.reporo.net
add address=127.0.0.1 comment=ADBlock name=www.eltrafiko.com
add address=127.0.0.1 comment=ADBlock name=cdn.trafficforce.com
add address=127.0.0.1 comment=ADBlock name=gts-ads.twistbox.com
add address=127.0.0.1 comment=ADBlock name=static.cdn.gtsmobi.com
add address=127.0.0.1 comment=ADBlock name=ads.matomymobile.com
add address=127.0.0.1 comment=ADBlock name=ads.adiquity.com
add address=127.0.0.1 comment=ADBlock name=img.ads.mobilefuse.net
add address=127.0.0.1 comment=ADBlock name=as.adfonic.net
add address=127.0.0.1 comment=ADBlock name=media.mobpartner.mobi
add address=127.0.0.1 comment=ADBlock name=cdn.us.goldspotmedia.com
add address=127.0.0.1 comment=ADBlock name=ads2.mediaarmor.com
add address=127.0.0.1 comment=ADBlock name=cdn.nearbyad.com
add address=127.0.0.1 comment=ADBlock name=ads.ookla.com
add address=127.0.0.1 comment=ADBlock name=mobiledl.adobe.com
add address=127.0.0.1 comment=ADBlock name=ads.flurry.com
add address=127.0.0.1 comment=ADBlock name=gemini.yahoo.com
add address=127.0.0.1 comment=ADBlock name=d3anogn3pbtk4v.cloudfront.net
add address=127.0.0.1 comment=ADBlock name=d3oltyb66oj2v8.cloudfront.net
add address=127.0.0.1 comment=ADBlock name=d2bgg7rjywcwsy.cloudfront.net
add address=127.0.0.1 comment=ADBlock name=a.vserv.mobi
add address=127.0.0.1 comment=ADBlock name=admin.vserv.mobi
add address=127.0.0.1 comment=ADBlock name=c.vserv.mobi
add address=127.0.0.1 comment=ADBlock name=ads.vserv.mobi
add address=127.0.0.1 comment=ADBlock name=sf.vserv.mobi
add address=127.0.0.1 comment=ADBlock name=hybl9bazbc35.pflexads.com
add address=127.0.0.1 comment=ADBlock name=hhbekxxw5d9e.pflexads.com
add address=127.0.0.1 comment=ADBlock name=www.pflexads.com
add address=127.0.0.1 comment=ADBlock name=orencia.pflexads.com
add address=127.0.0.1 comment=ADBlock name=atti.velti.com
add address=127.0.0.1 comment=ADBlock name=ru.velti.com
add address=127.0.0.1 comment=ADBlock name=mwc.velti.com
add address=127.0.0.1 comment=ADBlock name=cdn.celtra.com
add address=127.0.0.1 comment=ADBlock name=ads.celtra.com
add address=127.0.0.1 comment=ADBlock name=cache-ssl.celtra.com
add address=127.0.0.1 comment=ADBlock name=cache.celtra.com
add address=127.0.0.1 comment=ADBlock name=track.celtra.com
add address=127.0.0.1 comment=ADBlock name=wv.inner-active.mobi
add address=127.0.0.1 comment=ADBlock name=cdn1.inner-active.mobi
add address=127.0.0.1 comment=ADBlock name=m2m1.inner-active.mobi
add address=127.0.0.1 comment=ADBlock name=bos-tapreq01.jumptap.com
add address=127.0.0.1 comment=ADBlock name=bos-tapreq02.jumptap.com
add address=127.0.0.1 comment=ADBlock name=bos-tapreq03.jumptap.com
add address=127.0.0.1 comment=ADBlock name=bos-tapreq04.jumptap.com
add address=127.0.0.1 comment=ADBlock name=bos-tapreq05.jumptap.com
add address=127.0.0.1 comment=ADBlock name=bos-tapreq06.jumptap.com
add address=127.0.0.1 comment=ADBlock name=bos-tapreq07.jumptap.com
add address=127.0.0.1 comment=ADBlock name=bos-tapreq08.jumptap.com
add address=127.0.0.1 comment=ADBlock name=bos-tapreq09.jumptap.com
add address=127.0.0.1 comment=ADBlock name=bos-tapreq10.jumptap.com
add address=127.0.0.1 comment=ADBlock name=bos-tapreq11.jumptap.com
add address=127.0.0.1 comment=ADBlock name=bos-tapreq12.jumptap.com
add address=127.0.0.1 comment=ADBlock name=bos-tapreq13.jumptap.com
add address=127.0.0.1 comment=ADBlock name=bos-tapreq14.jumptap.com
add address=127.0.0.1 comment=ADBlock name=bos-tapreq15.jumptap.com
add address=127.0.0.1 comment=ADBlock name=bos-tapreq16.jumptap.com
add address=127.0.0.1 comment=ADBlock name=bos-tapreq17.jumptap.com
add address=127.0.0.1 comment=ADBlock name=bos-tapreq18.jumptap.com
add address=127.0.0.1 comment=ADBlock name=bos-tapreq19.jumptap.com
add address=127.0.0.1 comment=ADBlock name=bos-tapreq20.jumptap.com
add address=127.0.0.1 comment=ADBlock name=web64.jumptap.com
add address=127.0.0.1 comment=ADBlock name=web63.jumptap.com
add address=127.0.0.1 comment=ADBlock name=web65.jumptap.com
add address=127.0.0.1 comment=ADBlock name=bo.jumptap.com
add address=127.0.0.1 comment=ADBlock name=i.jumptap.com
add address=127.0.0.1 comment=ADBlock name=a.applovin.com
add address=127.0.0.1 comment=ADBlock name=d.applovin.com
add address=127.0.0.1 comment=ADBlock name=pdn.applovin.com
add address=127.0.0.1 comment=ADBlock name=mobpartner.mobi
add address=127.0.0.1 comment=ADBlock name=go.mobpartner.mobi
add address=127.0.0.1 comment=ADBlock name=r.mobpartner.mobi
add address=127.0.0.1 comment=ADBlock name=uk-ad2.adinfuse.com
add address=127.0.0.1 comment=ADBlock name=adinfuse.com
add address=127.0.0.1 comment=ADBlock name=go.adinfuse.com
add address=127.0.0.1 comment=ADBlock name=ad1.adinfuse.com
add address=127.0.0.1 comment=ADBlock name=ad2.adinfuse.com
add address=127.0.0.1 comment=ADBlock name=sky.adinfuse.com
add address=127.0.0.1 comment=ADBlock name=orange-fr.adinfuse.com
add address=127.0.0.1 comment=ADBlock name=sky-connect.adinfuse.com
add address=127.0.0.1 comment=ADBlock name=uk-go.adinfuse.com
add address=127.0.0.1 comment=ADBlock name=orangeuk-mc.adinfuse.com
add address=127.0.0.1 comment=ADBlock name=intouch.adinfuse.com
add address=127.0.0.1 comment=ADBlock name=funnel0.adinfuse.com
add address=127.0.0.1 comment=ADBlock name=cvt.mydas.mobi
add address=127.0.0.1 comment=ADBlock name=lp.mydas.mobi
add address=127.0.0.1 comment=ADBlock name=golds.lp.mydas.mobi
add address=127.0.0.1 comment=ADBlock name=suo.lp.mydas.mobi
add address=127.0.0.1 comment=ADBlock name=aio.lp.mydas.mobi
add address=127.0.0.1 comment=ADBlock name=lp.mp.mydas.mobi
add address=127.0.0.1 comment=ADBlock name=media.mydas.mobi
add address=127.0.0.1 comment=ADBlock name=neptune.appads.com
add address=127.0.0.1 comment=ADBlock name=neptune1.appads.com
add address=127.0.0.1 comment=ADBlock name=neptune2.appads.com
add address=127.0.0.1 comment=ADBlock name=neptune3.appads.com
add address=127.0.0.1 comment=ADBlock name=saturn.appads.com
add address=127.0.0.1 comment=ADBlock name=saturn1.appads.com
add address=127.0.0.1 comment=ADBlock name=saturn2.appads.com
add address=127.0.0.1 comment=ADBlock name=saturn3.appads.com
add address=127.0.0.1 comment=ADBlock name=jupiter.appads.com
add address=127.0.0.1 comment=ADBlock name=jupiter1.appads.com
add address=127.0.0.1 comment=ADBlock name=jupiter2.appads.com
add address=127.0.0.1 comment=ADBlock name=jupiter3.appads.com
add address=127.0.0.1 comment=ADBlock name=req.appads.com
add address=127.0.0.1 comment=ADBlock name=req1.appads.com
add address=127.0.0.1 comment=ADBlock name=req2.appads.com
add address=127.0.0.1 comment=ADBlock name=req3.appads.com
add address=127.0.0.1 comment=ADBlock name=mc.yandex.ru
add address=127.0.0.1 comment=ADBlock name=an.yandex.ru
add address=127.0.0.1 comment=ADBlock name=swappit.tapad.com
add address=127.0.0.1 comment=ADBlock name=campaign-tapad.s3.amazonaws.com
add address=127.0.0.1 comment=ADBlock name=adsrv1.tapad.com
add address=127.0.0.1 comment=ADBlock name=ads1.mojiva.com
add address=127.0.0.1 comment=ADBlock name=ads2.mojiva.com
add address=127.0.0.1 comment=ADBlock name=ads3.mojiva.com
add address=127.0.0.1 comment=ADBlock name=ads4.mojiva.com
add address=127.0.0.1 comment=ADBlock name=ads5.mojiva.com
add address=127.0.0.1 comment=ADBlock name=c.w.inmobi.com
add address=127.0.0.1 comment=ADBlock name=adtracker.inmobi.com
add address=127.0.0.1 comment=ADBlock name=china.inmobi.com
add address=127.0.0.1 comment=ADBlock name=japan.inmobi.com
add address=127.0.0.1 comment=ADBlock name=mdn1.phluantmobile.net
add address=127.0.0.1 comment=ADBlock name=mdn2.phluantmobile.net
add address=127.0.0.1 comment=ADBlock name=mdn3.phluantmobile.net
add address=127.0.0.1 comment=ADBlock name=mdn3origin.phluantmobile.net
add address=127.0.0.1 comment=ADBlock name=soma.smaato.net
add address=127.0.0.1 comment=ADBlock name=c29new.smaato.net
add address=127.0.0.1 comment=ADBlock name=c01.smaato.net
add address=127.0.0.1 comment=ADBlock name=c02.smaato.net
add address=127.0.0.1 comment=ADBlock name=c03.smaato.net
add address=127.0.0.1 comment=ADBlock name=c04.smaato.net
add address=127.0.0.1 comment=ADBlock name=c05.smaato.net
add address=127.0.0.1 comment=ADBlock name=c06.smaato.net
add address=127.0.0.1 comment=ADBlock name=c07.smaato.net
add address=127.0.0.1 comment=ADBlock name=c08.smaato.net
add address=127.0.0.1 comment=ADBlock name=c09.smaato.net
add address=127.0.0.1 comment=ADBlock name=c10.smaato.net
add address=127.0.0.1 comment=ADBlock name=c11.smaato.net
add address=127.0.0.1 comment=ADBlock name=c12.smaato.net
add address=127.0.0.1 comment=ADBlock name=c13.smaato.net
add address=127.0.0.1 comment=ADBlock name=c14.smaato.net
add address=127.0.0.1 comment=ADBlock name=c15.smaato.net
add address=127.0.0.1 comment=ADBlock name=c16.smaato.net
add address=127.0.0.1 comment=ADBlock name=c17.smaato.net
add address=127.0.0.1 comment=ADBlock name=c18.smaato.net
add address=127.0.0.1 comment=ADBlock name=c19.smaato.net
add address=127.0.0.1 comment=ADBlock name=c20.smaato.net
add address=127.0.0.1 comment=ADBlock name=c21.smaato.net
add address=127.0.0.1 comment=ADBlock name=c22.smaato.net
add address=127.0.0.1 comment=ADBlock name=c23.smaato.net
add address=127.0.0.1 comment=ADBlock name=c24.smaato.net
add address=127.0.0.1 comment=ADBlock name=c25.smaato.net
add address=127.0.0.1 comment=ADBlock name=c26.smaato.net
add address=127.0.0.1 comment=ADBlock name=c27.smaato.net
add address=127.0.0.1 comment=ADBlock name=c28.smaato.net
add address=127.0.0.1 comment=ADBlock name=c29.smaato.net
add address=127.0.0.1 comment=ADBlock name=c30.smaato.net
add address=127.0.0.1 comment=ADBlock name=c31.smaato.net
add address=127.0.0.1 comment=ADBlock name=c32.smaato.net
add address=127.0.0.1 comment=ADBlock name=c33.smaato.net
add address=127.0.0.1 comment=ADBlock name=c34.smaato.net
add address=127.0.0.1 comment=ADBlock name=c35.smaato.net
add address=127.0.0.1 comment=ADBlock name=c36.smaato.net
add address=127.0.0.1 comment=ADBlock name=c37.smaato.net
add address=127.0.0.1 comment=ADBlock name=c38.smaato.net
add address=127.0.0.1 comment=ADBlock name=c39.smaato.net
add address=127.0.0.1 comment=ADBlock name=c40.smaato.net
add address=127.0.0.1 comment=ADBlock name=c41.smaato.net
add address=127.0.0.1 comment=ADBlock name=c42.smaato.net
add address=127.0.0.1 comment=ADBlock name=c43.smaato.net
add address=127.0.0.1 comment=ADBlock name=c44.smaato.net
add address=127.0.0.1 comment=ADBlock name=c45.smaato.net
add address=127.0.0.1 comment=ADBlock name=c46.smaato.net
add address=127.0.0.1 comment=ADBlock name=c47.smaato.net
add address=127.0.0.1 comment=ADBlock name=c48.smaato.net
add address=127.0.0.1 comment=ADBlock name=c49.smaato.net
add address=127.0.0.1 comment=ADBlock name=c50.smaato.net
add address=127.0.0.1 comment=ADBlock name=c51.smaato.net
add address=127.0.0.1 comment=ADBlock name=c52.smaato.net
add address=127.0.0.1 comment=ADBlock name=c53.smaato.net
add address=127.0.0.1 comment=ADBlock name=c54.smaato.net
add address=127.0.0.1 comment=ADBlock name=c55.smaato.net
add address=127.0.0.1 comment=ADBlock name=c56.smaato.net
add address=127.0.0.1 comment=ADBlock name=c57.smaato.net
add address=127.0.0.1 comment=ADBlock name=c58.smaato.net
add address=127.0.0.1 comment=ADBlock name=c59.smaato.net
add address=127.0.0.1 comment=ADBlock name=c60.smaato.net
add address=127.0.0.1 comment=ADBlock name=f03.smaato.net
add address=127.0.0.1 comment=ADBlock name=f04.smaato.net
add address=127.0.0.1 comment=ADBlock name=f05.smaato.net
add address=127.0.0.1 comment=ADBlock name=f06.smaato.net
add address=127.0.0.1 comment=ADBlock name=f07.smaato.net
add address=127.0.0.1 comment=ADBlock name=f08.smaato.net
add address=127.0.0.1 comment=ADBlock name=f09.smaato.net
add address=127.0.0.1 comment=ADBlock name=f10.smaato.net
add address=127.0.0.1 comment=ADBlock name=f11.smaato.net
add address=127.0.0.1 comment=ADBlock name=f12.smaato.net
add address=127.0.0.1 comment=ADBlock name=f13.smaato.net
add address=127.0.0.1 comment=ADBlock name=f14.smaato.net
add address=127.0.0.1 comment=ADBlock name=f15.smaato.net
add address=127.0.0.1 comment=ADBlock name=f16.smaato.net
add address=127.0.0.1 comment=ADBlock name=f17.smaato.net
add address=127.0.0.1 comment=ADBlock name=f18.smaato.net
add address=127.0.0.1 comment=ADBlock name=f19.smaato.net
add address=127.0.0.1 comment=ADBlock name=f20.smaato.net
add address=127.0.0.1 comment=ADBlock name=f21.smaato.net
add address=127.0.0.1 comment=ADBlock name=f22.smaato.net
add address=127.0.0.1 comment=ADBlock name=f23.smaato.net
add address=127.0.0.1 comment=ADBlock name=f24.smaato.net
add address=127.0.0.1 comment=ADBlock name=f25.smaato.net
add address=127.0.0.1 comment=ADBlock name=f26.smaato.net
add address=127.0.0.1 comment=ADBlock name=f27.smaato.net
add address=127.0.0.1 comment=ADBlock name=f28.smaato.net
add address=127.0.0.1 comment=ADBlock name=f29.smaato.net
add address=127.0.0.1 comment=ADBlock name=f30.smaato.net
add address=127.0.0.1 comment=ADBlock name=f31.smaato.net
add address=127.0.0.1 comment=ADBlock name=f32.smaato.net
add address=127.0.0.1 comment=ADBlock name=f33.smaato.net
add address=127.0.0.1 comment=ADBlock name=f34.smaato.net
add address=127.0.0.1 comment=ADBlock name=f35.smaato.net
add address=127.0.0.1 comment=ADBlock name=f36.smaato.net
add address=127.0.0.1 comment=ADBlock name=f37.smaato.net
add address=127.0.0.1 comment=ADBlock name=f38.smaato.net
add address=127.0.0.1 comment=ADBlock name=f39.smaato.net
add address=127.0.0.1 comment=ADBlock name=f40.smaato.net
add address=127.0.0.1 comment=ADBlock name=f41.smaato.net
add address=127.0.0.1 comment=ADBlock name=f42.smaato.net
add address=127.0.0.1 comment=ADBlock name=f43.smaato.net
add address=127.0.0.1 comment=ADBlock name=f44.smaato.net
add address=127.0.0.1 comment=ADBlock name=f45.smaato.net
add address=127.0.0.1 comment=ADBlock name=f46.smaato.net
add address=127.0.0.1 comment=ADBlock name=f47.smaato.net
add address=127.0.0.1 comment=ADBlock name=f48.smaato.net
add address=127.0.0.1 comment=ADBlock name=f49.smaato.net
add address=127.0.0.1 comment=ADBlock name=f50.smaato.net
add address=127.0.0.1 comment=ADBlock name=f51.smaato.net
add address=127.0.0.1 comment=ADBlock name=f52.smaato.net
add address=127.0.0.1 comment=ADBlock name=f53.smaato.net
add address=127.0.0.1 comment=ADBlock name=f54.smaato.net
add address=127.0.0.1 comment=ADBlock name=f55.smaato.net
add address=127.0.0.1 comment=ADBlock name=f56.smaato.net
add address=127.0.0.1 comment=ADBlock name=f57.smaato.net
add address=127.0.0.1 comment=ADBlock name=f58.smaato.net
add address=127.0.0.1 comment=ADBlock name=f59.smaato.net
add address=127.0.0.1 comment=ADBlock name=f60.smaato.net
add address=127.0.0.1 comment=ADBlock name=img.ads1.mojiva.com
add address=127.0.0.1 comment=ADBlock name=img.ads2.mojiva.com
add address=127.0.0.1 comment=ADBlock name=img.ads3.mojiva.com
add address=127.0.0.1 comment=ADBlock name=img.ads4.mojiva.com
add address=127.0.0.1 comment=ADBlock name=img.ads1.mocean.mobi
add address=127.0.0.1 comment=ADBlock name=img.ads2.mocean.mobi
add address=127.0.0.1 comment=ADBlock name=img.ads3.mocean.mobi
add address=127.0.0.1 comment=ADBlock name=img.ads4.mocean.mobi
add address=127.0.0.1 comment=ADBlock name=akamai.smartadserver.com
add address=127.0.0.1 comment=ADBlock name=cdn1.smartadserver.com
add address=127.0.0.1 comment=ADBlock name=diff.smartadserver.com
add address=127.0.0.1 comment=ADBlock name=diff2.smartadserver.com
add address=127.0.0.1 comment=ADBlock name=diff3.smartadserver.com
add address=127.0.0.1 comment=ADBlock name=eqx.smartadserver.com
add address=127.0.0.1 comment=ADBlock name=im2.smartadserver.com
add address=127.0.0.1 comment=ADBlock name=itx5-publicidad.smartadserver.com
add address=127.0.0.1 comment=ADBlock name=itx5.smartadserver.com
add address=127.0.0.1 comment=ADBlock name=tcy.smartadserver.com
add address=127.0.0.1 comment=ADBlock name=ww129.smartadserver.com
add address=127.0.0.1 comment=ADBlock name=ww13.smartadserver.com
add address=127.0.0.1 comment=ADBlock name=ww14.smartadserver.com
add address=127.0.0.1 comment=ADBlock name=ww234.smartadserver.com
add address=127.0.0.1 comment=ADBlock name=ww251.smartadserver.com
add address=127.0.0.1 comment=ADBlock name=ww264.smartadserver.com
add address=127.0.0.1 comment=ADBlock name=ww302.smartadserver.com
add address=127.0.0.1 comment=ADBlock name=ww362.smartadserver.com
add address=127.0.0.1 comment=ADBlock name=ww370.smartadserver.com
add address=127.0.0.1 comment=ADBlock name=ww381.smartadserver.com
add address=127.0.0.1 comment=ADBlock name=ww392.smartadserver.com
add address=127.0.0.1 comment=ADBlock name=ww55.smartadserver.com
add address=127.0.0.1 comment=ADBlock name=ww57.smartadserver.com
add address=127.0.0.1 comment=ADBlock name=ww84.smartadserver.com
add address=127.0.0.1 comment=ADBlock name=www.smartadserver.com
add address=127.0.0.1 comment=ADBlock name=www2.smartadserver.com
add address=127.0.0.1 comment=ADBlock name=www3.smartadserver.com
add address=127.0.0.1 comment=ADBlock name=www4.smartadserver.com
add address=127.0.0.1 comment=ADBlock name=ads.mobclix.com
add address=127.0.0.1 comment=ADBlock name=data.mobclix.com
add address=127.0.0.1 comment=ADBlock name=s.mobclix.com
add address=127.0.0.1 comment=ADBlock name=ads.mdotm.com
add address=127.0.0.1 comment=ADBlock name=cdn.mdotm.com
add address=127.0.0.1 comment=ADBlock name=ads2.greystripe.com
add address=127.0.0.1 comment=ADBlock name=adsx.greystripe.com
add address=127.0.0.1 comment=ADBlock name=c.greystripe.com
add address=127.0.0.1 comment=ADBlock name=aax-us-east.amazon-adsystem.com
add address=127.0.0.1 comment=ADBlock name=aax-us-west.amazon-adsystem.com
add address=127.0.0.1 comment=ADBlock name=s.amazon-adsystem.com
add address=127.0.0.1 comment=ADBlock name=admarvel.s3.amazonaws.com
add address=127.0.0.1 comment=ADBlock name=html5adkit.plusmo.s3.amazonaws.com
add address=127.0.0.1 comment=ADBlock name=\
inneractive-assets.s3.amazonaws.com
add address=127.0.0.1 comment=ADBlock name=strikeadcdn.s3.amazonaws.com
add address=127.0.0.1 comment=ADBlock name=a.admob.com
add address=127.0.0.1 comment=ADBlock name=analytics.admob.com
add address=127.0.0.1 comment=ADBlock name=c.admob.com
add address=127.0.0.1 comment=ADBlock name=media.admob.com
add address=127.0.0.1 comment=ADBlock name=p.admob.com
add address=127.0.0.1 comment=ADBlock name=met.adwhirl.com
add address=127.0.0.1 comment=ADBlock name=mob.adwhirl.com
add address=127.0.0.1 comment=ADBlock name=ad-g.doubleclick.net
add address=127.0.0.1 comment=ADBlock name=ad.mo.doubleclick.net
add address=127.0.0.1 comment=ADBlock name=doubleclick.net
add address=127.0.0.1 comment=ADBlock name=pagead.googlesyndication.com
add address=127.0.0.1 comment=ADBlock name=pagead1.googlesyndication.com
add address=127.0.0.1 comment=ADBlock name=pagead2.googlesyndication.com
add address=127.0.0.1 comment=ADBlock name=events.foreseeresults.com
add address=127.0.0.1 comment=ADBlock name=survey.foreseeresults.com
add address=127.0.0.1 comment=ADBlock name=m.quantserve.com
add address=127.0.0.1 comment=ADBlock name=ad.leadboltmobile.net
add address=127.0.0.1 comment=ADBlock name=mobileads.msn.com
add address=127.0.0.1 comment=ADBlock name=img.adecorp.co.kr
add address=127.0.0.1 comment=ADBlock name=us0.adlibr.com
add address=127.0.0.1 comment=ADBlock name=ad.parrot.mable-inc.com
add address=127.0.0.1 comment=ADBlock name=aos.wall.youmi.net
add address=127.0.0.1 comment=ADBlock name=au.youmi.net
add address=127.0.0.1 comment=ADBlock name=coconuts.boy.jp
add address=127.0.0.1 comment=ADBlock name=iacpromotion.s3.amazonaws.com
add address=127.0.0.1 comment=ADBlock name=plugin.2easydroid.com
add address=127.0.0.1 comment=ADBlock name=adimg3.search.naver.net
add address=127.0.0.1 comment=ADBlock name=st.a-link.co.kr
add address=127.0.0.1 comment=ADBlock name=cdn.ajillionmax.com
add address=127.0.0.1 comment=ADBlock name=dispatch.admixer.co.kr
add address=127.0.0.1 comment=ADBlock name=ifc.inmobi.com
add address=127.0.0.1 comment=ADBlock name=thinknear-hosted.thinknearhub.com
add address=127.0.0.1 comment=ADBlock name=ads.adadapted.com
add address=127.0.0.1 comment=ADBlock name=analytics.localytics.com
add address=127.0.0.1 comment=ADBlock name=a.medialytics.com
add address=127.0.0.1 comment=ADBlock name=c.medialytics.com
add address=127.0.0.1 comment=ADBlock name=cdn.creative.medialytics.com
add address=127.0.0.1 comment=ADBlock name=p.medialytics.com
add address=127.0.0.1 comment=ADBlock name=px.cdn.creative.medialytics.com
add address=127.0.0.1 comment=ADBlock name=t.medialytics.com
add address=127.0.0.1 comment=ADBlock name=google-analytics.com
add address=127.0.0.1 comment=ADBlock name=googlesyndication.com
add address=127.0.0.1 comment=ADBlock name=applift.com
add address=127.0.0.1 comment=ADBlock name=trackersimulator.org
add address=127.0.0.1 comment=ADBlock name=eviltracker.net
add address=127.0.0.1 comment=ADBlock name=do-not-tracker.org
add action=accept chain=input comment="defconf: accept established,related" \
add action=drop chain=input comment="defconf: drop all from WAN" \
in-interface=ether1-wan
add action=accept chain=forward comment="defconf: accept established,related" \
connection-state=invalid
connection-state=new in-interface=ether1-wan
out-interface=ether1-wan
add action=masquerade chain=srcnat out-interface=ether1-wan
/ip route rule
add action=unreachable dst-address=10.1.1.0/24 src-address=192.168.88.0/24
add action=unreachable dst-address=192.168.88.0/24 src-address=10.1.1.0/24
/ip service
set telnet disabled=yes
set ftp disabled=yes
set www address=192.168.88.0/24
set ssh disabled=yes port=51742
set www-ssl certificate=cert1 port=51742
set api disabled=yes
set winbox address=192.168.88.0/24
set api-ssl disabled=yes
/ip upnp
set enabled=yes
/ip upnp interfaces
add interface=ether1-wan type=external
add interface=bridge1-lan type=internal
/system identity
set name=MikRouter
/system leds
set 1 interface=wlan-5GHz
/system ntp client
set enabled=yes primary-ntp=48.8.40.31 secondary-ntp=91.206.16.4
/system package update
set channel=release-candidate
/system routerboard settings
set protected-routerboot=disabled
/system scheduler
add disabled=yes interval=10s name="AutoADBlock(Script)" on-event=\
"system script run AutoADBlock" policy=\
ftp,reboot,read,write,policy,test,password,sniff,sensitive,romon \
start-date=mar/10/2017 start-time=18:00:17
add disabled=yes interval=1w name="Auto_Backup(Script)" on-event=\
"system script run Auto_Backup" policy=\
start-date=mar/10/2017 start-time=19:25:27
/system script
add name=AutoADBlock owner=Nikita policy=\
ftp,reboot,read,write,policy,test,password,sniff,sensitive,romon source=":\
local hostScriptUrl \"http://stopad.generate.club/\?sources=https%3A%2F%2F\
cdn.rawgit.com%2Ftarampampam%2Fstatic%2Fmaster%2Fhosts%2Fblock_shit.txt,ht\
tp%3A%2F%2Fadaway.org%2Fhosts.txt&format=routeros&version=0.1.0&exceptions\
=localhost&limit=1500\";\r\
\n\r\
\n:local scriptName \"stop_ad.script\";\r\
\n:local backupFileName \"before_stopad\";\r\
\n:local logPrefix \"[StopAD]\";\r\
\n\r\
\ndo {\r\
\n /tool fetch mode=http url=\$hostScriptUrl dst-path=(\"./\".\$scriptName\
);\r\
\n :if ([:len [/file find name=\$scriptName]] > 0) do={\r\
\n /system backup save name=\$backupFileName;\r\
\n :delay 1s;\r\
\n :if ([:len [/file find name=(\$backupFileName.\".backup\")]] > 0) do=\
{\r\
\n /ip dns static remove [/ip dns static find comment=ADBlock];\r\
\n /import file-name=\$scriptName;\r\
\n /file remove \$scriptName;\r\
\n :log info \"\$logPrefix AD block script imported, backup file (\\\"\
\$backupFileName.backup\\\") created\";\r\
\n } else={\r\
\n :log warning \"\$logPrefix Backup file not created, importing AD bl\
ock script stopped\";\r\
\n }\r\
\n } else={\r\
\n :log warning \"\$logPrefix Backup file not downloaded, script stopped\
\";\r\
\n }\r\
\n} on-error={\r\
\n :log warning \"\$logPrefix AD block script download FAILED\";\r\
\n};"
add name=Auto_Backup owner=Nikita policy=\
ftp,reboot,read,write,policy,test,password,sniff,sensitive,romon source="{\
\r\
\n:log info \"Starting Backup Script...\";\r\
\n\r\
\n:local sysname [/system identity get name];\r\
\n:local sysver [/system package get system version];\r\
\n\r\
\n:log info \"Flushing DNS cache...\";\r\
\n\r\
\n/ip dns cache flush;\r\
\n:delay 2;\r\
\n\r\
\n:log info \"Deleting last Backups...\";\r\
\n\r\
\n:foreach i in=[/file find] do={:if ([:typeof [:find [/file get \$i name]\
\_\"\$sysname-backup-\"]]!=\"nil\") do={/file remove \$i}};\r\
\n\r\
\n:delay 2;\r\
\n\r\
\n:local smtpserv [:resolve \"my.profile.qwerty@gmail.com\"];\r\
\n\r\
\n:local Eaccount \"******************\";\r\
\n:local pass \"*************\";\r\
\n\r\
\n:local backupfile (\"\$sysname-backup-\" . [:pick [/system clock get dat\
e] 7 11] . [:pick [/system clock get date] 0 3] . [:pick [/system clock ge\
t date] 4 6] . \".backup\");\r\
\n:log info \"Creating new Full Backup file...\";\r\
\n/system backup save name=\$backupfile;\r\
\n:delay 5;\r\
\n:log info \"Sending Full Backup file via E-mail...\";\r\
\n\r\
\n/tool e-mail send from=\"<\$Eaccount>\" to=\$Eaccount server=\$smtpserv \
port=587 user=\$Eaccount password=\$pass start-tls=yes file=\$backupfile s\
ubject=(\"\$sysname Full Backup (\" . [/system clock get date] . \")\") bo\
dy=(\"\$sysname full Backup file see in attachment.\r\
\nRouterOS version: \$sysver\r\
\nTime and Date stamp: \" . [/system clock get time] . \" \" . [/system cl\
ock get date]);\r\
\n\r\
\n:delay 30;\r\
\n\r\
\n:local exportfile (\"\$sysname-backup-\" . [:pick [/system clock get dat\
t date] 4 6] . \".rsc\");\r\
\n:log info \"Creating new Setup Script file...\";\r\
\n/export file=\$exportfile;\r\
\n\r\
\n:delay 5;\r\
\n\r\
\n:log info \"Sending Setup Script file via E-mail...\";\r\
\n\r\
port=587 user=\$Eaccount password=\$pass tls=yes file=\$exportfile subject\
=(\"\$sysname Setup Script Backup (\" . [/system clock get date] . \")\") \
body=(\"\$sysname Setup Script file see in attachment.\r\
ock get date]);\r\
\n\r\
\n:delay 30;\r\
\n\r\
\n:log info \"All System Backups emailed successfully.\r\
\nBackuping completed.\";\r\
\n\r\
\n}"
/system watchdog
set auto-send-supout=yes send-email-to=my.profile.qwerty@gmail.com \
watch-address=*************
/tool e-mail
set address=************** from="<************>" password=********* port=****** \
start-tls=yes user=***************
/tool mac-server
/tool mac-server mac-winbox
disabled
wps-mode=disabled
/ip hotspot profile
defconf
/queue simple
192.168.88.0
ether1-wan
/ip dns static
/ip route rule
/ip service
/ip upnp
set enabled=yes
/ip upnp interfaces
/system identity
set name=MikRouter
/system leds
/system ntp client
/system scheduler
/system script
\n\r\
\n\r\
\ndo {\r\
);\r\
\n :delay 1s;\r\
{\r\
\n } else={\r\
\n }\r\
\n } else={\r\
\";\r\
\n }\r\
\n} on-error={\r\
\n};"
\r\
\n\r\
\n\r\
\n\r\
\n:delay 2;\r\
\n\r\
\n\r\
\n\r\
\n:delay 2;\r\
\n\r\
\n\r\
\n\r\
\n:delay 5;\r\
\n\r\
ock get date]);\r\
\n\r\
\n:delay 30;\r\
\n\r\
\n\r\
\n:delay 5;\r\
\n\r\
\n\r\
ock get date]);\r\
\n\r\
\n:delay 30;\r\
\n\r\
\n\r\
\n}"
/system watchdog
/tool e-mail
/tool mac-server
